Philips 42PFL5522D/05 Not Powering
    Re: Philips 42PFL5522D/05 Not Powering
    The diode is in parallel with a resistor, to test it you need to partially lift off the diode. As for the resistor, the only R604 is bottom below chip, do you mean that one?
    • liamoc74
      • Feb 2015
      • 80
      • Ireland
      yeah the resistor underneath it, can you see markings on it in 2nd pic.?
      Lifted the diode, lifted pin nearest resistor..with red on lifted black on other im getting 580 but it fluctuates
      Other way im getting 130..
        Are you testing across the diode you partially removed? Or just the board?
        • liamoc74
          • Feb 2015
          • 80
          • Ireland
          just across the diode, one pin still attachted to the board - will i remove it altogether and test.?
            One pin should be fine. Diode could be leaky then so worth replacing. Something like 1N4148W would work.
            • liamoc74
              • Feb 2015
              • 80
              • Ireland
              #26
              Okay - got the bits today, MOSFET, IC and diode - popped them all in, replaced fuse..
              Powered on, and a spark came from the board, not 100% sure as it was pretty quick but i think it was from one of the thermistors above the bridge rectifier, it definetly came from something around that area..
              Any ideas on where i start re-testing or am i just fighting a losing battle.?
              • CapLeaker
                Leaking Member
                • 8226
                I am just saying... at SJ I think you can buy a replacement board for 35$. Depends on you if you want to continue on fixing the old or just replace.
                Check the inner to pins of the bridge rectifier for a short.
                • liamoc74
                  • Feb 2015
                  • 80
                  • Ireland
                  #28
                  Yeah i saw that, be the handiest option alright but id rather be able to fix these things, but i guess replacing the boards will have to do until i learn the craic..
                  • liamoc74
                    • Feb 2015
                    • 80
                    • Ireland
                    #29
                    Got the new board from SJ, working grand initially but then the tv starts making noise, and then starts flashing, gets really quick then finishes with a black line down the middle and no flashing..
                    Any ideas..?
                    • CapLeaker
                      Leaking Member
                      • 8226
                      pics or a vid maybe?
                      • liamoc74
                        • Feb 2015
                        • 80
                        • Ireland
                        #31
                        http://youtu.be/28yYWISZKE0
                        Cheers!!
                        • CapLeaker
                          Leaking Member
                          • 8226
                          Can you make a pic of your Tcon board?
                          • liamoc74
                            • Feb 2015
                            • 80
                            • Ireland
                            #33
                            Will do - be an hour or so, until then ive uploaded a vid of the sound it makes when flashing - may be some help, sound is coming from psu..
                            this is a board from sj and i still have old one so i can switch a few components if need be..
                            thanks again..
                            http://youtu.be/OMRaaZqUkfI
                            • ph445
                              Philips 40PFH6510/88 not powering on
                              by ph445
                              I have a Philips 40PFH6510/88 TV which is not switching on. No no standby led, no nothing. There was no bang, no smoke, it was simply switched off and next day it did not switch on.
                              I got the power PCB out and visually checked it, I did not see anything unusal on it, the fuse is OK and no cracked, burned components on either side, capacitors looks OK to me.
                              Both big 450V capacitors are charging up to around 330V but on the secondary side I can't get any reasonal voltage on any output pins. Most are around 0.2-0.3 V. (not sure which one is standby,...
                              10-23-2023, 08:00 AM
                            • Protker
                              Philips 47PFH4109 blinking 2 times when powering
                              by Protker
                              Hello!
                              So i have a Philips 47PFH4109, and when i powering on the tv just blinks once, then after a 2 seconds blinks again, and does not turning on.
                              I mean i measuring voltages such like 30V on the leds and the 12 volts on the other panels, which seems to be okay.
                              I checked the backlight no issues with the leds.
                              I checked every component such as all the mosfets, all the diodes, i dont see any bad capacitors (unfortunatelly i only can measure up to 200uF).
                              I even took out the LD7591 chip and without it doing the same as before.
                              Im just seeking for advice,...
                              12-23-2021, 12:33 PM
                            • G33RT
                              Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                              by G33RT
                              Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                              It does power up when pressing the power button.
                              I already try the power button while plugin the plug with no result.
                              Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                              Could this be an PSU or eMMC issue ?
                              07-19-2025, 03:43 AM
                            • double_DD
                              Philips curling iron - is this a common AC cable?
                              by double_DD
                              Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                              As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                              Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                              08-18-2025, 10:04 AM
                            • janos6662000
                              Philips 47PFS7509/12 LCD TV problem
                              by janos6662000
                              Hi
                              I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                              When i applied cable signal to check image, i had normal picture, but TV was restarting.
                              I downloaded original firmware and applied the update, but the problem remained.
                              From a colleague i received a "factory package software" which is a lot bigger.
                              I made another firmware update, but still did not solve the problem.
                              Somewhere on the way the error got worse, because at the moment the...
                              08-12-2025, 12:54 PM
