Plasma Model PS51E530A3W No Picture please help?
  • Bilbo44uk
    • Jun 2014
    • 11
    I have been repairing TV SETS A long time, but occasionally I GET ONE IN THAT beats me, this is that one, this set came to me from a chap that said he was watching it, went to kitchen, came back and it had no picture again, my immediate thoughts are Ysus panel, however this is doing such strange things I am confussed, i am better on lcd sets but when i get a plasma it always causes me a headache, this is also now doing so.
    Samsung Plasma.
    Problems I have so far, I have checked all the ICs on the buffer boards and can't find any shorts, i presume my method of setting my meter to beep test, putting one probe to a buffer ground and running along the output nodes is pretty standard test, no beeps, no sign heat ups on ICs, so next I check all mosfets, diodes and capacitors on Ysus main, stiull nothing that stands out, next I check the output from the main PSU VS and VA, the issue is now that on switch on the VS volts rise to 206 V but then just drop and drop until it settles around 10 volts, the VA which is usually around 60 volts seems to do the same dance, but is in millivolts by the end of the sequence, my next thought is a bad capacitor or short on the output, but again after 2 hours testing i find nothing, i then disconnect the output from the psu to the xmain which is then connected to the ysus main so ive now got nothing connected but a main board, as before there is sound, but not much else, the psu va and vs dont do anything now, no start up, I am guessing because there is nothing connected to the psu output ?? OK, so now im connecting it all back up and it does the same again, the VS VA ramps up to voltage for a second or two then drops like a stone again, voltage to the Ysus input is also sitting at 10 volts so i know its getting through, just far too low to fire up the panel, I have read as much as I can but as this is a 2012 TV there isnt any fault info I can find online.
    Adding more information now, I need to find out if the fault is on the psu itself as this is where the volts are just not coming out of, or if its just a PWM chip detecting a fault and clamping down the switching rate to the transformer, thus lowering volts on output, ok, so I have 3 vs 2 va, couple grounds, a 15 volt and a 4.8 volt pin, the 15 volts stable as is the 4.8 volt outputs, the other pins are vs_on VA_on I think, and another one which is possibly VSN_on not sure im not with the tv now so from memory. I need to tell this psu to switch on with no panels conected so i can eliminate if the psu is fully functioning or at fault, does anyone have any ideas, or ask me anything and I will reply as I am getting desperate now having spent nearly 8hrs on this set and got nowhere, thank you, Tim Bilbo.
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: Plasma Model PS51E530A3W No Picture please help?
    Pictures of boards and chassis please.
    Most people won't even read this unless provided
    • Bilbo44uk
      • Jun 2014
      • 11
      I dont have the ability to take pictures now, however i will see what i can do, it seems the smps is shutting down as detecting a fault.
      • MagicSmoke
        • Feb 2011
        • 275
        What is part number on Y main?
        • jeffegg2
          • Feb 2015
          • 27
          I read here that it is normal when disconnecting x and y for the psu to boot and then coast to 0. I'm checking the x and y boards and found a shorted mosfet.
          • KYBOSH
            Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
            by KYBOSH
            Saved this beast from the landfill this weekend.
            Manfactured July 2013 in Mexico.
            I love working on plasma TVs.
            Its been a while but I was lucky enough to find 2 this week.
            The TV powers on and stays on but no picture. Havent checked for sound yet.
            No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
            Will start troubleshooting tonight.
            10-17-2024, 01:17 PM
          • mmartell
            RCA Virtuoso RHOS581SM-D Picture Fault
            by mmartell
            Picture looks stretched out and it looks like every other vertical line is not being drawn though hard to see that in the pics.
            I've disconnected each half of the panel and the fault remains exact save for the disconnected side being white.
            The original complaint was the tuner stopped working so the main was replaced however the new and old board exhibit the same picture defect.
            Nothing is getting hot and pushing on the panel drivers effects no change in the picture.
            So with that does anyone know how to enter the Service Menu on this...
            02-05-2022, 10:53 AM
          • Tr0ll
            by Tr0ll
            Original T-con:
            First replacement T-con:
            10-07-2023, 07:48 PM
          • PlasMatt
            LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
            by PlasMatt
            I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
            09-20-2025, 06:50 PM
          • JJAAMM
            by JJAAMM
            Problem
            07-06-2023, 06:01 AM
