Hi guys ive been asked to look at this tv by a neighbour. She said to me that she called the argos helpline as that is where she purchased from and they said it was because she shut the tv off while the Netflix app was open. When you switch the tv on it goes to a blue screen for 5 -10 seconds then shuts off and back on continously. The red LED on the front blink on and off repeatedly through the whole thing. Could anyone point me in the right direction for repair ? I have attached pictures of the 2 boards in the tv.
restart problem with Bush LED TV
Tags: None
Re: restart problem with Bush LED TV
It's probably corrupted firmware. Maybe try flashing new firmware with USB stick. Vestel has a lot of issues with firmware corruption.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
Ive tried looking for the firmware Via google. Cant seem to find it.Comment
No longer under warranty? It will probably need a new main board then.
Try and tell your neighbour not to buy another Vestel again, it's throw away garbage.
Might be worth checking some PSU voltages, perhaps try pressing down on the CPU see if it's got a cold joint on the BGA. Check LDOs: U14, U6.
Schematic of PSU:
Last edited by tom66; 02-11-2015, 04:52 AM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
No Tim unfortunatly it was 1 month out of warranty when it happened. I will try to search for firmware again. Thanks.Comment
I think she'd have a case under SOGA, it's unreasonable to expect a TV to only last 13 months. Argos needs to destroy these Vestel pieces of junk and send them back to the hell they came from.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I know it seems to always be tvs with Vestel boards i come across. Especially with the PSU there so shit.Comment
They're built for the consumer society. Built to fail. Nothing else.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Have you tried to ring them,
be nice and polite
And see if they will help you..
Its looks very likely firmeware corrupt.
some nice info http://www.ledtvs.net/faulty-led-tv/
they should help you out... as all it may need is a software updateComment
got new board through and installed in TV and still not working, tv doesnt shut off like before but still have no picture, changed Tcon board and still the same, could it be a possible faulty panel ?Comment
So what new board did you try ?
what voltages have u checked so far ?Comment
Be aware that there are many board variants and you need the exact one. Also, you should still have at least the original symptoms (shutting off) if the main board was good and something else is causing the fault... the fact that you don't would indicate the main board you have received is bad.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Ive had trouble trying different 17MB95 boards....
It MUST be the exact same one Ive found from the same sub-make (Alba, Hitachi etc) to work, and have the same paper label number.
I fitted one--and let the smoke out as the panel was a different version to the one it was made for!
Utter Shite, Vestel Vomit!TELEFIX
PLEASE DO NOT EMAIL ME PRIVATELY FOR REPAIR ADVICE. QUESTIONS BELONG ON THE FORUM!Comment
TELEFIX
this is gonna sound so daft, but ive lost original board as i have loads of them so its been thrown in with the rest of them.Comment
Ah--But! You have a picture--With The Number--at the top on this thread!!TELEFIX
is it the white label ? and has all the numbers got too match ?Comment
yes i try to match up the model of the tv and also the board number and the white label as well due to there being so many differnet versions of vestel boards aroundComment
by theone111I have an LG Plasma TV 60PM6700 for the past ~12 years.
In the last ~3-4 months I have been having some issues.- Problem: It started with random picture disappearing (sound still worked).
Solution: Had to turn off TV wait a few seconds before turning it on again. - Problem: Then it got worse and the TV started to shut down and when turning on the no picture just sound.
Solution: Had to turn off TV wait about 10-20 seconds and turn it on again to solve. - Problem: TV shuts down
1 Photo - Problem: It started with random picture disappearing (sound still worked).
by VikramBFirst thread here on this forum, excuse me if I miss something in my first post.
I have the 55” variant of the Frame TV which is essentially a QLED tv. There's a weird problem where it would keep on restarting on its own. Funny thing is it might work perfectly for couple of days and then decides to go down the restart route. A few pointers:
1. If I let the TV sit idle for a day, for the very first time it boots after that time period it usually keeps working for 5 minutes before restarting. After that it restarts every 5 seconds.
2. I've tried the tape method and... -
by Zeonalbastai have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double... -
by GfilipeZHi,
I'm working on a A1989 820-00850 Logic Board.
The customer complained that the machine restarted randomly.
From the analysis I made to the Logic Board, I detected a small corrosion in the IC U7430.
Although the diode values are all correct, I replaced the IC with another one. But the machine kept the same problem.
However, I noticed that whenever I use the Heaven software, the machine restarts after a few seconds. That is, it is enough to have an increase in graphics processing for the machine to restart.
Has anyone had a situation... -
by Gibon378PC Specs:
- CPU: Ryzen 5 1600
- GPU: GTX 1080 Palit JetStream
- MOBO: ASRock ab350 PRO4
- RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
- PSU: XFX 650W (don't remember what model)
- OS SSD: ADATA SP920
- OS: Windows 10 21H2
Problem description:
Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders... - Loading...
