LG 60PV450 plasma burning/melting plastic on z-sustain
  • progrmmer
    • Jan 2015
    • 8
    I originally had the issue outlined in this thread - Lg 60pv450 colors flashing . I was able to fix it by re-soldering a couple joints on the ERC inductors as suggested by Tom. That worked fine for a few weeks, but this past week I started to notice the smell of burning plastic so I took the back off and discovered a part of the z-sustain sub board was indeed melting. Pic attached.
    I've decided to just buy a new z-sustain board (my soldering was poor at best) but am having trouble detaching the copper ribbon in the pic from the melted part. It looks like the melted clip is not all the way un-fastened and I cannot push it in or out due to the melting. Any ideas on how to free it w/o damaging the ribbon?
  • Shinju
    • Mar 2014
    • 1239
    Re: LG 60PV450 plasma burning/melting plastic on z-sustain
    I would replace that Zsus buffer board too if you didn't already order one. As far as getting the ribbon out, take the zsus out, detach the buffer board and try pulling out the ribbon by moving the free floating board back and forth gently.
    Did you take any VZB voltages while it was in this state?
      Looks like the Zsus common ribbon was not properly seated and this has caused a lot of heating on the contact surface. How many ribbons does this set use on the Z side?
      • mmartell
        • Oct 2013
        • 3189
        Maybe get a screwdriver GENTLY in there and use a twisting motion (with board still mounted) to unlock the connector. Hope it's not melted in there or could make the panel toast.
        • Shinju
          • Mar 2014
          • 1239
          3 zsus panel ribbons.
          • freakaftr8
            • Oct 2012
            • 3743
            If you can get the ribbon loose I would look a the ribbon and if it has burn marks on the copper take a very mild scotchbrite and clean the copper contact
              From my testing on multiple panels the ribbons are all common to each other both on the Z-sub board and on the panel (that is, if you continuity-meter them, they'll show short.) In theory these panels should work ok with a single ribbon only. But looking at the glass on other panels before, there's very little electrode width connecting them... i.e. a lot of resistance... this could mean that if the other ribbons were loose or poorly seated, one ribbon took the majority of the drive current...
              • Shinju
                • Mar 2014
                • 1239
                Going to ask an obvious question. You had ALL the Sustain screws in and tight right? You cannot have even one missing or it will cause issues.
                to me it looks like his ribbon lock wasn't locked but in the unlocked state.
                • Kemer
                  Led status indicator light transfer plastic
                  by Kemer
                  Hello, the LED status indicators on my Lenovo Z580 are not working. Actually the motherboard LEDs are working but the light doesn''t coming to the front view. The plastic part is which you can see in photo must transfer the light to the frontview but just half of the plastic is illuminating.
                  There are three status indicators on the front (power, battery, caps lock), and none of them are illuminated.
                  The plastic piece doesn't appear to be broken.
                  1. What are your suggestions for resolving this issue?
                  2. Is the plastic piece made of special ma...
                  08-19-2025, 07:02 PM
                • progrmmer
                  LG 60PV450 plasma burning/melting plastic on z-sustain, salvagable?
                  by progrmmer
                  Hi, I have an LG 60PV450 plasma that had a perfect picture but started to smell like it was burning. Took back panel off and saw plastic was all melted on the Z-sustain part that connects to the ribbons cables. Well, now I have the ribbons cables disconnected from the board but as you can see in the pics, one is looking a little rough.
                  So I have two questions, first, can I even source one of these z-sustain boards anymore? If so, where? Everywhere I've looked just says discontinued. And secondly, is the ribbon cable still usable? I mean, before removing it from the board the TV...
                  10-21-2016, 08:01 PM
                • stormanimal83
                  Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
                  by stormanimal83
                  Hey....
                  Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
                  my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
                  01-18-2024, 02:15 PM
                • ignacio.ino27
                  Vaio DA0HK1MB6E0 MBX-247 Burning any EC
                  by ignacio.ino27
                  Hello to all.
                  I have this Sony Vaio QUANTA HK1 DA0HK1MB6E0 MBX-247 that is burning the NUVOTON EC when you connect it to power supply.
                  1) The +3vpcu line is going to a direct short after connecting the motherboard to power supply.
                  2) I discovered the EC NUVOTON was shorted. After removing it the short gone out on that line (+3vpcu) but... (If i quit the EC the 3.3v are pressent on +3vpcu because the shorted component was quited)
                  3) There were no shorts after soldering the new EC NUVOTON. But after connecting the board to power supply the EC keeps burning...
                  05-07-2022, 05:24 PM
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
