Sceptre X322BV-HD*XVNO5 blue light only
  • jumpingjoeusa
    • Feb 2015
    • 11
    My TV just suddenly went out. When you turn it on the blue light comes on only and then the only way to turn off is by unplugging TV.
  • Hamie
    • Apr 2014
    • 1383
    Re: Sceptre X322BV-HD*XVNO5 blue light only
    quick search shows the powersupply is subject to capacitor failure.
    • Hamie
      • Apr 2014
      • 1383
      is this the powersupply?
      • jumpingjoeusa
        • Feb 2015
        • 11
        yes that is the one. also I am not getting continuity from the ground at the plug in to the grounds at the connectors on the power supply.
        Con 1 J 13 Specified VOLT Actual OFF Actual ON
        Pin 1 GRD 122.7 122.5
        Pin 2 GRD 122.5 122.5
        Pin 3 5V 122.5 122.5
        Pin 4 5V 122.8 9.4
        Pin 5 on 122.9 122.6
        Pin 6 off 122.9 122.6
        Pin 7 5V 123 9.98
        Pin 8 5V 122.7 122.6
        Pin 9 GRD 122.8 122.5
        Pin 10GRD 122.8 122.6
        Pin 11GRD 122.9 122.7
        Pin 12 12V 122.8 122.7
        Pin 13 12V 122.9 122.8
        Con 2 EC 35 Specified VOLT Actual OFF Actual ON
        Pin 1 24 V 123 123
        Pin 2 24 V 123 123
        Pin 3 GRD 122.8 123
        Pin 4 GRD 122.7 123
        Con 3 J 13
        Specified VOLT
        Pin 1 GRD 122.6 122
        Pin 2 GRD 122.6 122.6
        Pin 3 GRD 10 ↓ 13.3
        Pin 4 GRD 122.3 122.8
        Pin 5 24 V 122.2 121.7
        Pin 6 24 V 122.2 121.7
        Pin 7 24 V 122.3 121.4
        Pin 8 24 V 122.2 121.4
        Any help would be appreciated.
        Thank you
        jumpingjoeusa is online now Report Post Edit/Delete Message
        • jumpingjoeusa
          • Feb 2015
          • 11
          Any ideas of the list of caps I need to replace and which ones.
          • jumpingjoeusa
            • Feb 2015
            • 11
            Sceptre TV X322BV-HD*XVNO5
            AY118P-4HF01 (REV 1)
            power supply
              • 12330
              • U.S.
              read the stickies, first posts in the list, and throw up some good clear pics. of each board and one of all of m so people can see how theyr all connected.
              • jumpingjoeusa
                • Feb 2015
                • 11
                I am having some trouble getting the pics posted here and am going to a faster connection location.
                  Isn' this another thread tat you already asked for help? Did you read the other thread that you already posted?
                  https://www.badcaps.net/forum/showth...602#post528602
                  It is not good to post the same question on more than one thread, hard to follow.
                  • jumpingjoeusa
                    • Feb 2015
                    • 11
                    Sorry I have never posted before it is true that there was a vage earlier post that did not provide thr information needed. Thanks for pointed out the other thread response and its true I need to test on dc not ac will post more in the next day or 2 as I am out of town. I hope the pics post ok as I am new to thumb nails also.
                    Thank you
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      Thank you
                      "KM" caps seem to be the worst for being bad while not visibly bad!
                      Replace them on sight!
                      ASRock B550 PG Velocita
                      Ryzen 9 "Vermeer" 5900X
                      Arc A770 16 GB
                      eVGA Supernova G3 750W
                      Alienware AW3423DWF OLED
                      • jumpingjoeusa
                        • Feb 2015
                        • 11
                        test results
                          • 12330
                          • U.S.
                          yep, recap is a good place to start, can't test caps accurately without esr meter, replace then you can at least move on with testing without having to wonder if theyr good or bad.
                            I think you need to give us the valid voltage readings first since what you have shown on post 4 are way off.
                            • jumpingjoeusa
                              • Feb 2015
                              • 11
                              Yes sorry about that. I have corrected that in a few posts up.
                                It better to post right in the page like you did on post 4.
                                The power supply is working from what I see in the spread sheet.
                                So you need to remove that black insulator sheet off the inverter board and give use good clear pictures of the inverter board, especially around the connector that goes back to the power supply board.
                                We need to see if it has any blown fuses on the inverter board.
                                • jumpingjoeusa
                                  • Feb 2015
                                  • 11
                                  I hope this what you requested.. This the inverter board. I thought this lit the screen. I have and still a little ill. Let me know if the pics are right
                                  • jackfishbay
                                    • Apr 2014
                                    • 12
                                    • canada
                                    go here https://www.badcaps.net/forum/showth...ght=blue+light
                                    same problem...its the chip
                                    • weinernation101
                                      • Oct 2015
                                      • 4
                                      • US
                                      My voltage reading coming out of the T.RSC8.10B 12305 board going into the TV BACKLIGHT INVERTER BOARD - VIC91801.BZ seems to be good. My question is "what should my voltage be coming out of the VIC91801.BZ board (see pictured) pink & white wires?
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 5093
                                        • New Zealand
                                        Those are the lamp outputs - they probably run at least 1.5kV, with about 3kV start voltage! Unless you have a meter capable of measuring at least 5kV I wouldn't even try.
                                        The lamps themselves are the best way to test if the inverter is functioning.
                                        -David VanHorn
                                        • Tomylee
                                          Nintendo 2DS XL – Orange light, no blue light, signs of overheating
                                          by Tomylee
                                          Hi everyone, I have a Nintendo 2DS XL that shows the orange charging light when plugged in, but nothing happens when I press the power button — no blue light, no screen, no sound.
                                          Here's what I've observed:
                                          All ribbon cables are properly connected
                                          Battery is present and in good condition
                                          No reaction even with screens disconnected
                                          There's a visible burn mark / overheating sign on the metal shield, right above the CPU
                                          I’m suspecting an issue with the CPU, PMIC, NAND, or a power...
                                          06-26-2025, 02:33 PM
                                        • tom_h
                                          Sceptre X505BV, blue LED, no display
                                          by tom_h
                                          Hello all,
                                          I have a Sceptre X505BV-FMDR8HJ1PE8 tv that had been gradually over time taking longer
                                          and longer to come on, now it will no longer display any image. Original symptoms
                                          are the red standby LED would turn to blue immediately when pressing the power on
                                          button, but there would be a delay for the "SCEPTRE" image to appear on the screen
                                          and backlight to come on. The delay kept getting longer, then it would go from blue
                                          LED back to red. Then when I pressed the power on button again it would bring the
                                          display up and work fine....
                                          10-05-2023, 06:53 PM
                                        • blind2reply
                                          proscan 40ld45q - no pic -no sound - no backlight - blue light turns off
                                          by blind2reply
                                          proscan 40ld45q
                                          Have tried published resets with no help. (unplug for 10, push on-off for 30, push menu and vol +, etc.)
                                          After being plugged in, red light comes on. Push power button and blue light comes on for ~five seconds then goes out. Power button does not turn the unit on a second time - have to unplug/re-plug before power button will try to start with blue light.
                                          No sound, no picture (used flashlight test).
                                          No bulging cap, no burn spots, no burn smells, nothing visual (cold joints/breaks/bugs).
                                          Digital voltmeter;...
                                          06-06-2021, 01:16 PM
                                        • TurboTundra
                                          PS5 EDM-033 Blue Light 2 Sec then Powers Off
                                          by TurboTundra
                                          Hi, I am waiting for my uart tool so I can grab an error code and narrow down where my issue is, but I decided to measure capacitors and fuses to insure everything was okay.
                                          The PS5 turns on with a blue light and a beep for 1-2 seconds then turns off. I noticed a grey capacitor measures no voltage on standby or input power. Does this indicate a problem with the capacitor or something down on the line? I’m getting 3.3v on input with the red cap next to the grey one, and 5.2v on input with the red cap further away from the grey cap.
                                          Thank you for any input...
                                          06-10-2025, 08:51 PM
                                        • icareservicezone
                                          Synology DS918+ blue light blink
                                          by icareservicezone
                                          Synology DS918+
                                          Model name : GDI41L2
                                          p/N: 08-06GDI4116
                                          Version: V1.6
                                          Problem : blue light blink...
                                          05-24-2025, 11:53 PM
