Panasonic TH-42PZ77U 10 Blink status
  • ryanfan03
    • Apr 2014
    • 45
    I just started working on this tv and found some helpful advice from some of the other threads. First this had a 7 blink SOS status. I found a shorted FET on the SC board. I lifted both legs and replaced the board to see if it would turn on. The TV now has a 10 blink SOS status. I unhooked the SC board from the power supply and no more blinking. I then replaced just the top (SC2) connector and tried again, no blinks (solid red light). Only when I connect the bottom connector (SC20) does the 10 blink SOS status start. I think I followed this wire to the tuner board (DG?). Does this probably mean that the DG board is dead?
    Thanks for the help.
    Doing this on the side to make some extra money for my daughters dance competition.
  • lookimback
    • Aug 2013
    • 1489
    Re: Panasonic TH-42PZ77U 10 Blink status
    I would suspect the SC, as you've already found shorted components on it.
    ------------signature starts here------------
    • tw2005
      • Oct 2011
      • 6458
      5 & 15V is supplied via SC20 so resistance check those and see if one is shorted or low in ohms.That's where I'd start
      • tw2005
        • Oct 2011
        • 6458
        Pin1= P5v, pins 30,31 15v at the Sc20. you could probe those whilst turning the Tv on and see what voltage is there at startup. There is a TP15V point on the board off an inductor L6592
        • tw2005
          • Oct 2011
          • 6458
          15v goes directly to IC6521, FET driver, maybe that's toast?
          • tw2005
            • Oct 2011
            • 6458
            might want to study schematic, also goes to a couple of transistors Q6531,6521 that drive the 2PG001 & RJP6065
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
              After all of...
              07-13-2024, 08:14 PM
            • canadaboy25
              Panasonic TC-P54VT25 No image. A or D board?
              by canadaboy25
              I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
              I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
              01-17-2021, 01:06 AM
            • tiku
              Panasonic TH-L32C30D P-Board (1 Blink-Backlight_SOS)
              by tiku
              Hello Friends, i am having this model Panasonic TH-L32C30D, suddenly when i switch on, it went on One Blink, after looking at the service manual it says Backlight_SOS, I can see the menu on the tv screen for few seconds in the dark with the help of flashlight Before it goes into blinking cycle.
              I was having a backup P-Board which i replaced it and now its working fine, but i need to repair my faulty P-Board, as now its getting dificult to find any type of spares of this model, so can any friend who is master in Panasonic Repair, be kind enough to guide me or tell me which component should...
              09-05-2021, 05:02 AM
