Vizio E422AR turns on, with V on screen than shuts off
  • tibimakai
    • Jan 2012
    • 3680
    I have picked this up really cheap and it seems like a corrupted EEPROM, but nobody sells an EEPROM for this TV.
    When the TV is turned on, the Vizo logo in the bezel turns white, the V logo shows on the screen for a couple of seconds, than shuts off.
    The only thing that I can do, is replace the mainboard?
  • nomoresonys
    • 12323
    • U.S.
    Re: Vizio E422AR turns on, with V on screen than shuts off
    was reading earlier, pretty sure it was about a vizio, where they shorted out 2 pins on eeprom, then went into service menu, and adjusted some settings, I'll see if I can find it again.
    • tibimakai
      • Jan 2012
      • 3680
      It would be nice, if it would be so simple.
      • nomoresonys
        • 12323
        • U.S.
        crap my bad, it is for a samsung, not sure if it would translate, its here. http://techreport.com/forums/viewtop...2360&start=570
        • nomoresonys
          • 12323
          • U.S.
          not sure its a little deep for me.
          • nomoresonys
            • 12323
            • U.S.
            can you do a firmware update?
            • nomoresonys
              • 12323
              • U.S.
              I think I need to try something like this on this samsung, I think a surge messed up the firmware, naturally samsung dont have its firmware on their little site, plus I cant see the menu, screen is too snowy, unless its a component/s failure on mainboard.
              • tibimakai
                • Jan 2012
                • 3680
                Vizio, does not offer firmwares.
                • nomoresonys
                  • 12323
                  • U.S.
                  ouch
                  • tibimakai
                    • Jan 2012
                    • 3680
                    Maybe there is something available, while the TV is connected to a network, but there is nothing for download.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      There is a buzz on the power supply while it is on.
                      The voltages look OK.
                      The PS_ON is almost 0V, when it is on and 3.27V while in standby.
                      Both 12V are there.
                      I'm thinking that the EEPROM is the problem, since the PS_ON it's switching states.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        If the V logo, shows on the screen for like ten seconds and than shuts down, it's 100% a main board issue?
                        • Shinju
                          • Mar 2014
                          • 1239
                          humor me and disconnect the speakers from the mainboard and see what happens when it boots up. This was how I found out my JVC (Amtran) Vizio made LED panel had a pinched wire and the JVC logo would post then shut down once the mainboard initialized and shut down due to the short in the speaker leads.
                          • tibimakai
                            • Jan 2012
                            • 3680
                            Interesting, I will try it out when I get home.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              Speakers were disconnected(they are on the back cover).
                              I have got another main board and the TV it's working great.
                              Thank you,
                              Tibor
                              • nomoresonys
                                • 12323
                                • U.S.
                                glad to hear it Tibimakai.
                                  Another Vizio with main board issues, wow.
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    I'm pretty positive, that it was an EEPROM problem, but nobody sells one.
                                      It will be the flash memory IC (EEPROM is a misnomer, but similar technology), probably failed because they write too much to it and data gets corrupted as the flash memory wears out.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        Most likely, you are right.
                                        I'm dealing with Kenwood Nav unit's nand flash as well, which they get corrupted and they go in to a reboot loop cycle.
                                        The only way to fix this, is to replace the nand flash(2GB).
                                        Do you know, usually what is on these flash ICs? It is the firmware?
