Vizio E422AR turns on, with V on screen than shuts off
  • nomoresonys
    • 12206
    • U.S.
    Re: Vizio E422AR turns on, with V on screen than shuts off
    read here that a guy fixed his tv with a memory dump, was saturday I think, not sure what brand it was.
    • tibimakai
      • Jan 2012
      • 3680
      Which thread?
        Yep, it's what's known as the "main app" storage. The TV's not completely dead because the bootloader is present, that's what makes the start-up logo appear. Bootloader is usually on either a smaller second NOR chip or on a protected area of the main NAND chip.
        Once it tries to read off the main app, it encounters a corrupted portion and aborts (either due to bad checksum, or because the corrupted code causes a processor exception to occur.)
        I have been working on a project like this at work, testing flash memory to destruction. Simple fact is two main things kill flash ICs: high temperature, and lots of program/erase cycles. Modern smart TVs do a lot of writes to these flash devices leading to failures in the memory. And they keep reducing the size of the flash memory cells. Wasn't so much of a problem with 40nm flash cells but they're on 16nm now, each halving in size is 1/4 the expected lifetime.
        You could probably temporarily get NANDs working by making them very cold or very hot - might help the charge levels settle to a state where they are close enough to what they actually need to be.
        • SS454
          vizio e650i-a2 backlight flashes then turns off
          by SS454
          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
          panel: au optronics T650HVN05.4
          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
          https://www.shopjimmy.com/vizio-56-0...-power-supply/
          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
          08-20-2020, 03:57 PM
        • Super360
          Vizio E701i-A3 Vizio logo flashing then turns off
          by Super360
          Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
          07-25-2024, 07:06 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • ossroy
          Vizio M60-C3 powers on, perfect logo, turns off
          by ossroy
          Vizio M60-C3 powers on, perfect logo, turns off. If you don't touch anything it will repeat this process by itself until it is unplugged. Not the "button board" since I disconnected the cables to the main board and the problem persisted. So I'm fairly positive something is going on with the main board, but want to know if there is a fix for this other than replacing the expensive mainboard, which may eventually have the same problem. Also, heat sink was hot as hell when this all started. Unplugged for a few days and same thing happens.
          My kids are getting antsy waiting...
          08-03-2022, 08:11 PM
        • Stephen
          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
          by Stephen
          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
          03-15-2024, 09:37 AM
