Samsung 40inch lcd tv backlight goes off sound good
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    Model lns4051dx/xaa
    tv powers on fine and picture is great but after a random amount of time while watching tv the backlight will go off and the sound stays on
    this can be 5 minutes 10 minutes 30 minutes 1 hr ...2hrs etc...it varies from day to day....
    I have tested the output voltages on the cables from ps and they all check good...there seems to be 2 inverter boards and i get 12v going to both from the lower power cable....but there is a transformer with 2 wires going to top of i assume the master inverter and not sure how to check for voltages there...nothing marked...one wire is blue and one is white....its marked with ????? On photo
    any ideas what the problem could be? Inverter bad? Backlight bad?..if it is a bad inverter how can i tell if its master or slave inverter..
  • shelby5041
    • Feb 2009
    • 1505
    Re: Samsung 40inch lcd tv backlight goes off sound good
    Here are photos
    • shelby5041
      • Feb 2009
      • 1505
      forgot to mention when the backlight does go off i get good voltages coming from ps.....just not sure how to check the blue and white wires from what appears to be a transformer on ps to master inverter.........
        • 12192
        • U.S.
        not sure, but just read some of those transformers can carry 2000 volts, enough to fry a multimeter and kill a man.
        • shelby5041
          • Feb 2009
          • 1505
          yes.....but shouldnt i be able to test the output power via the blue white wires coming out of transformer going to master inverter?
            • 12192
            • U.S.
            not sure about your particular setup, if you can or not.
            • shelby5041
              • Feb 2009
              • 1505
              nope there is nothing on the board at all...just the blue and white wire coming out from trans going to master inverter.....
              • shelby5041
                • Feb 2009
                • 1505
                ok well maybe someone can answer this..what is the purpose of two power lines going to inverter...the 12v on bottom and the wires coming from trans on top?
                  • 12192
                  • U.S.
                  wrong post.
                    • 12192
                    • U.S.
                    just noticed, this is the exact model Im working on.
                      • 12192
                      • U.S.
                      see the other wire going to the inverter? it should say 12 v on legend, you can check that.
                        • 12192
                        • U.S.
                        this is the one I cant find a manual for, maybe I can find one thats close.
                        • shelby5041
                          • Feb 2009
                          • 1505
                          yes if you read my post and look at my pic it says i got 12v from that cable
                            • 12192
                            • U.S.
                            check these, http://www.toms-service-manuals.com/...h=Submit+Query
                            • shelby5041
                              • Feb 2009
                              • 1505
                              i get good voltages on all wires from power supply other than not checking the wires coming from large transformer
                                Those two long boards connected to the lamps are the Balancer boards, the 12V is normal, bad< = 10VDC.
                                Try disconnecting the cable between the main board and the power supply/inverter board combo and see if the backlights will come on and stays on the minute you plug the power cord into the outets.
                                Do not touch or try to measure the high voltage from the power supply/inverter board high voltage out put or you will blow up your meter.
                                What is the P/N of that power supply/inverter board? BN44-??????
                                  • 12192
                                  • U.S.
                                  we need a repair or training manual for this model, havent been able to find one.
                                    • 12192
                                    • U.S.
                                    mine is bn44-00134a.
                                    • shelby5041
                                      • Feb 2009
                                      • 1505
                                      thanks budm....ok so the two long boards are not typical inverter boards?....yes i do get 12v coming from ps as shwon in my photo......so you want me to disconnect the power supply connection to the main/input board? and then fire up the tv?....the tv shouldnt power up....that has all the voltages on it....correct?
                                      note: i saw a youtube video where a few people had exact same tv and the treansformer had bad solders which would cause intermittent backlight issues....just like mine...
                                      • shelby5041
                                        • Feb 2009
                                        • 1505
                                        the pn is in one of my photos.posted ill check now..
                                          09-07-2024, 05:50 AM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                          09-06-2024, 11:40 PM
