Samsung 40inch lcd tv backlight goes off sound good
    Re: Samsung 40inch lcd tv backlight goes off sound good
    Originally posted by shelby5041
    screen cracked.....i think the companies should have clear plastic screens on front.....why dont they?
    Creates excess reflections. Some older plasmas had such screens. You can buy retrofit protective screens if you want... the reflections on the screen, and the haloing around text annoys me personally but others may be ok with it.
    • Rmasters3
      • Mar 2010
      • 126
      #82
      FWIW: Had the same erratic shut down to black screen with audio remaining. Touched up the PS transformer solder joints--even though all looked OK. I had also previously replaced the 22 uf@450V PS cap with a used one, which seemed to help helped somewhat. Again replaced this cap with another used I had. Set now seems to be OK, running 12 hours with no problems.
      I had previously swapped the left side (seen from rear) inverter board with no effect.
        09-07-2024, 05:50 AM
      • Ierwin
        by Ierwin
        05-13-2025, 03:31 PM
      • jchang
        Samsung UN70NU6900F no picture and no sound
        by jchang
        Hi all
        I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
        Symptom:
        No picture no sound.
        When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
        No sound at all.
        What I tried:
        1. I tried unplugging the left or right ribbon...
        01-09-2023, 06:28 PM
      • ChaosLegionnaire
        by ChaosLegionnaire
        09-13-2022, 09:02 AM
        09-06-2024, 11:40 PM
