Toshiba 46SL412U (no video, no sound)
  • brianr20v
    • Apr 2013
    • 43
    • Trinidad
    Hi all, I will like some assistance with a problem I am receiving with a Toshiba, model number #46SL412U. I recently acquired a Toshiba television, no video and no sound. So obviously on assumptions, I though it was T-con board, so I ordered it and replaced it, still the same problem. A few weeks ago my friend lent his television same model as mine, so I said I will swap the boards to see what the problem is. The first thing I did was to swap the main input board. My friend television still work, mine didn't, same problem so I knew the main input board was good. The next step I did was to swap the power supply board, same problem. The power board was good. Next I swap the T-con board, my television didn't work neither did his so I swap back his original T-con board and now both television are doing the same thing. The back light is coming on bright for 2 seconds then its dimming down and staying on. Now I don't know what to do because I am clueless. Can someone please assist me?
  • brianr20v
    • Apr 2013
    • 43
    • Trinidad
    Re: Toshiba 46SL412U (no video, no sound)
    Anyone!!!!!!!! Please
    • powerflow
      • 43
      You may get a better response if you post some pics of the boards. Also take some voltage readings and post those as well.
      • proaudiosoft
        • Apr 2012
        • 68
        Sounds like your t-control board Is shorting out other components. Bad components can damage other components, even on different boards.
          • 12276
          • U.S.
          wrong thread.
            May be you have bad component on the LCD such as TFT driver ICs, MLCC that shorted out and took out the T-CON board since now your friend T-CON also does not work in his TV any more.
              • 12276
              • U.S.
              uh o, you screwed up your buddies tv.
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                Do you have the service manual for this set??
                • steviewonder
                  • Dec 2013
                  • 183
                  • england
                  I would say,with almost certainty,you have a defective panel (screen) that has eaten the T-con.if you are lucky,then maybe just the surface mount fuse has failed,located next to where the LVDS cable fits to the T-con.
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    I want to agree with Budm Post#6, But will a defective T-CON affect the audio as well? Shouldn't the audio work since the Main and Power Bds are OK? Does anyone have a Service Manual they can share??
                      09-06-2024, 05:27 AM
                    • ChaosLegionnaire
                      by ChaosLegionnaire
                      09-13-2022, 09:02 AM
                      09-06-2024, 05:59 AM
