Panasonic TX-P42GT20E 3D , does not turn on!
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Hey guys ,
    Got this tv , it does not turn on after lightning struck the house. ( completely dead ).
    I had a spare power supply and replaced it but still the same , then i took a spare main board from a different set ( same series , not 3D ).
    Set turned on with original power supply but i got a white screen. ( LVDS cable not connected due to size ).
    So i took the original main board and did not connect the "lvds" cable and the set turns again on with a white screen.
    When i connect the LVDS cable , the set does not turn on.
    So its either the main board OR the small board in the middle?
    The original main board had a blow IC next to the USB input.
    Pictures coming in a few minutes.
    What do you guys think?
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Panasonic TX-P42GT20E 3D , does not turn on!
    Here are the pictures! The screen looks like it has stripes , thats because of the camera! Screen is white.
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      The LVDS cable I'm talking about is the white cable going from the main board to the control board in the middle.
      When i turn the tv on with the cable connected the set stays off. When i flip the black lock on the cable the set turns on with a white screen , hope this helps.
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        Im suspecting its the A board? But I'm curious how lighting blew the A board ( small board ).
        I would suspect the main board OR power supply…….
        Any suggestions?
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          So i also replaced the SC board , issue is still the same.
          The spare parts are from the TX-P42V20E , all boards are the same but i don't know if the P42V20E also has a control board/A board , i couldn't find it between my spare boards……
          I could try to replace the SS board also , but i don't think thats the problem.
          Anyone?
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            I downloaded the service manual from the TC-P42GT30A , it has the same main board as the P42V20E.
            So the visual difference between these tv's its that GT20E has a control board. Could i use the GT30A main board in THIS tv? The GT30A/V20E have the same layout in lvds cables going to the SC board/panel…….
            • Moreno83
              • Jun 2014
              • 2008
              • The Netherlands
              Ok , i removed the A board and replaced the main board with the main board from the V20E.
              Installed it using different lvds cables and set turns on and i get a picture! It then turns off and blinks 11 times….
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                Nobody got any suggestions?
                • tw2005
                  • Oct 2011
                  • 6458
                  changing so much stuff randomly makes it hard to follow what you're thinking.
                  If it does not turn on, dead, no LED, no clicks of the relay, I'm thinking A board. The small board you talk about is the D board and unique to the 3D models.
                  Without looking the VT20E has fans hence the 11 blinks shutdown since this has no fans and the board is looking for a return signal indicating the fans are spinning.
                  The burnt blown IC is probably a good clue, a clear focussed picture of that may be handy. good chance whatever it is is shorting the board, may even be possible to remove it and clear the short for the board to work again. A long shot but it's dead anyway, nothing to lose.
                  • tw2005
                    • Oct 2011
                    • 6458
                    Just so there's no confusion, this is the board layout
                    • Moreno83
                      • Jun 2014
                      • 2008
                      • The Netherlands
                      Thx TW2005 for the reply! Im sorry , english is not my first language so i probably make some mistakes!
                      So i'll try to explain what i've done.
                      When i turn on the TX-P42GT20E with all original parts the set does NOT turn on , completely dead.
                      When i remove the white lvds cable from A board to D board the set turns on , the relay clicks and i get a white screen. ( even with the small IC thats blown ).
                      I then used a working mainboard from the VT20E , its almost the same except the connections for the LVDS ( Because of the D board ).
                      I turned the tv on with lvds cable removed and again i get a white screen. This makes me think the original A board is still ok?
                      So i wanted to know if the rest of the parts were ok so instead of fixing the TX-P42GT20E i modified the tv using all parts from the VT20E. You might ask , why?
                      ALL PARTS of the tv are exactly the same as the TX-P42GT20E.
                      So what happens is that the tv is working fine except the 11 blinks due to the fans missing ( I wasnt sure it had fans , but i knew 11 blinks was fan problem).
                      So now im wondering , does the TX-P42GT20E need a new D board? The only time it doesnt work is when the D board is connected.......
                      Hope its more clear for you now
                      • tw2005
                        • Oct 2011
                        • 6458
                        No, I'm thinking A-board, that's where the blown IC is , yes? the D board controls the panel so my line of thinking is because you've isolated it from the A board then it automatically is turning the panel on.
                        A board is dead.
                        there is a 3D training guide although for the 50" however principle of operation is the same. When the LVDS ribbon is removed the TV is meant to turn on, white screen.
                        So that confirms all else is good, it's not the D board that is faulty
                        Yes it's a strange one with the 42" having the same panel for 2D & 3D. definitely not the case with the larger panel. So it does make sense to convert to 2D if all you want is a Tv that works.
                        Would be interesting to fault find the original A board, any pictures of that burnt IC.
                        "Method To Turn On the Panel Drive Circuit Only (A Board is Isolated)
                        It's possible to have the “Panel Drive Section” running with the “Signal Processing Section” (A board)
                        disconnected.
                        By separating the 2 sections, it could be determined if the symptom on the TV is created by the A
                        board or one of the boards on the Panel Drive Section.
                        Note: Disconnecting D3/A32 and D5/A31 allows the TV to turn on by itself with a white screen after
                        it is plugged in to the AC line. This procedure does not disable the A board.
                        To completely disable the A board:
                        1. Unplug the TV.
                        2. Remove connectors P6 and P7 from the power supply. (See note on previous slide.)
                        3. Plug in the TV (Do not press the power button).
                        • The TV partially turns on by itself.
                        • The screen stays black.
                        • No fan operation.
                        • The LEDs on the SS board and SC board are on.
                        To force the TV to display a white screen:
                        1. Unplug the TV.
                        2. With P6 and P7 disconnected, disconnect D5 from the from the D/A board.
                        3. Plug in the TV.
                        4. Now the TV turns on by itself with a white screen."
                        • Moreno83
                          • Jun 2014
                          • 2008
                          • The Netherlands
                          thx for the reply. I already ordered the D board because i thought it had a short! ( Because when i connect it it doesnt work ).
                          Any way to find the fault on the A board? I'll make a picture of the burned IC but that component is not the problem.
                          I already tried to desolder the same part from the other mainboard to this board and issue is still the same. Tv works without that ic. IC says "D2508", its next to the USB port.
                          • tw2005
                            • Oct 2011
                            • 6458
                            Ok so it's a diode. What do you mean it works without that part though? You said the TV will not work with that A board or are we talking about the board you have removed it from?
                            yes it probably would but on the blown board it's probably taken out something else and shorted .
                            • tw2005
                              • Oct 2011
                              • 6458
                              I guess too late to cancel the purchase and you got the same revision board for 42"?
                              • Moreno83
                                • Jun 2014
                                • 2008
                                • The Netherlands
                                Im talking about both boards.
                                At first i used the mainboard from the VT20E without the LVDS cable and it turns on.
                                Then i used the original mainboard from the GT and it also turned on without the LVDS cable and this board had a blown diode.
                                I removed the diode from the VT20E board and placed it on the GT board but fault is still the same.
                                • Neelix
                                  • Oct 2013
                                  • 145
                                  • South Africa
                                  Is the blown part a IC or diode? Don't see a D5208 in the service manual?
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    Ok, so all that proves is the TV will turn on with the LVDS lead disconnected and produce a white screen which is correct operation of the D board.
                                    the A board is not turning the panel on when connected.
                                    You'll confirm for sure once you have the replacement D board but I'm confident I'm right but either way if it fixes it then great , I don't have a problem being wrong and learning but that's my gut feeling with this one.
                                    I'll upload the 3 d manual for you as it describes the operation at turn on.
                                    • Moreno83
                                      • Jun 2014
                                      • 2008
                                      • The Netherlands
                                      Not sure if its a diode or ic , it does have that part number on it. Its viscible on the mainboard picture , in the upper right corner.
                                      • Moreno83
                                        • Jun 2014
                                        • 2008
                                        • The Netherlands
                                        Im also thinking your right TW2005 , im still learning!
                                        Is it the cpu on the mainboard? But why does it turn on without the D board?
                                        Or is it a short somewhere?
                                        • PNI E.
                                          Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                          by PNI E.
                                          Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                          03-17-2025, 04:23 AM
                                        • stecos
                                          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                          by stecos
                                          Hi everyone!
                                          For my passion for technology I'm now collecting several...
                                          11-28-2022, 11:39 AM
                                        • David Smedley
                                          Panasonic FZ-55 Toughbook main board schematic request
                                          by David Smedley
                                          I've been working on this awful project with a Panasonic FZ-55, basically I'm trying to intercept the eDP signal from the main board, and replace it with my own eDP signal connected from an lcd driver. The problem is, for some reason the 30 pin ribbon pinout is really unusual and not playing nice with my LCD controller. Long story short, I managed to fuck up my board and pull off some pads on the eDP out port, I'm hoping to find either another eDP out source somewhere else on the laptop, or figure out this goddamn pin layout so I can just replace the whole native display complex with my controller...
                                          09-04-2024, 02:57 PM
                                        • SluggerB
                                          Panasonic TH-50PX80 killed by lightning strike, help me save her!
                                          by SluggerB
                                          Yes it's a 17 year old Panasonic plasma!
                                          I was watching TV when there was a huge lighting strike nearby my house that shook the house. When that happened, the picture on the TV froze and the TV wouldn't turn off except by pulling the power cable. Now if you plug in the TV, it seems to turn on (it makes the turn on "clikcs" it always does, the red power light comes on but there is no picture, although I can see the back light around the edges. And the TV doesn't respond to the power button on the remote to turn off, and doesn't respond to the manual power button on the front...
                                          06-04-2025, 07:02 PM
                                        • dgnisbet
                                          Panasonic Tx-P50G20B faulty main board
                                          by dgnisbet
                                          I have a Panasonic viera plasma Tx-P50G20B which has a faulty main board. The picture freezes after about 30s and appears to lose vertical hold before finally going black. The main board part number - TNPH0838 (1) A - is common to several Panasonic tvs across a number of ranges however there is a second part number (TXN/A1LTUB for the 50") which is unique to each model.
                                          My question is, given that the TX-P50G20B 50" differs from the TX-P46G20B 46" only in the physical size of the screen, is it possible to use the main board from the TX-P46G20B in a 50"? The secondary...
                                          02-03-2022, 02:01 PM
