Re: Panasonic TX-P42GT20E 3D , does not turn on!
hola, un saludo para todos, sucede que tengo esta mainboard TNPH0899 1A, me gustaria saber si alguien aca me puede facilitar el diagrama de esta placa, o saber donde van los voltages de cadda cable que ingresa de la fuente a la placa, donde estaria stb y el power on, porfavor me podrian ayudar? Les agradeceria esa colaboracion. Gracias.
I gave up , those caps are TO small to change! My solderiron is to big for those caps ....need a thin iron to replace those!
New mainboard is coming this week...will let you know how it works
Must be one of the caps then that is pulling the voltage down at pin 8Leave a comment:
I replaced IC1100 and still does not turn on. Voltages are the same.
Will remove and replace the other ones.Leave a comment:
Thx for the big help Neelix , I will just replace IC1100 to see if it will turn on or not. ( Would save me alot of time removing all caps/replacing them. )Leave a comment:
We're making progress! 3.27V and high resistance is what you must measure at pin 8. With L1100 in the board, you measure 0V and low resistance. By removing L1100 you took IC1100 and all those little caps out of the circuit and now you measure 3.27V and high resistance at pin 8 which is right. That means that IC1100 or the caps is shorted and when in the circuit, is pulling the voltage at pin 8 down to 0V. Next is to find out if it's the IC or the caps that's shorted and which caps. I suggested previously that you remove the caps one by one, but that's going to take too long and the connectors might break from all the unplugging and pluggin in of the board. So I suggest you remove all the caps(C1102, C1103, C1104, C1108, C1109, C1123, C1114, C1112) at the same time, solder L1100 back into the board and measure again the voltage and resistance at pin 8. If you the measure 0V and low resistance, then IC1100 is shorted and must be replaced. If you measure 3.27V and high resistance, then one or more of the caps you removed is shorted and you must measure the resistance of each to find the shorted onesLast edited by Neelix; 02-05-2015, 02:17 PM.Leave a comment:
But also , I cant just simply remove all components untill the shorts are gone right? They are there for a reason...... ( Got a spare mainboard to replace components ).Leave a comment:
L5481 is soldered into place , L1100 is removed and mm now measuring 3.27V + 4.7V again! Im now measuring "OL" Ohm again , so there is another short right?Leave a comment:
Ok , searched for it again on a windows machine and now i find the L1100 ..... thx!
Huh? I did haha , when i type L1100 i only find the 1 thats near the IC1100? I already thought it was on the opposite side of the board as it goes to the small cap that goes to 2 small "rings"......
Do i use the wrong reader for the manual? I dont get itLeave a comment:
use the pdf manual and the find function. it's on the opposite side of the board near the Sd slot and in between that and cn8700, c1102 is next to itLeave a comment:
I don't know which 1 is L1100. Its a conductor and its connected to pin 88 of ic1100 but i don't see it on the print itself. I do see a cap going to pin 88 but i think its a capacitor?Attached Filesif you find these attachements useful please consider making a small donation to the site
L5481 is in right place yes. Had a look at the schematic again and if you remove L1100 then IC1100 and all those caps on the supply line is not connectd to the STB3.3V anymore. So remove L1100 and measure the voltage and resistance again at pin 8 of IC5482Leave a comment:
That are a lot of caps! Im looking at the schematic but i don't really see any caps that would stand out for being removed…..
L5481 must be where it is right? any suggestions where to start?Leave a comment:
3.27V is ok, but with L5481 solderered into the board, we're back to 0V at pin 8. That means that something else besides C5487 is also faulty and pulling the STB3.3V down. The STB3.3V supplies the processor(IC1100) and it's EEPROM(IC1101) with power. Any of of those two ICs or caps on the supply line around IC1100 can pull the STB3.3V down. Only way to find out which IC or cap, is to remove them one and one until the voltage at pin 8 is right againLast edited by Neelix; 02-04-2015, 01:58 PM.Leave a comment:
No did not loose it but now I'm measuring 0v and 326 Ohm. Other voltages are lower also ( 4.5v ).Leave a comment:
The STB3.3V supplies the processor that must switch the TV on with power and without L5481, the STB3.3V can't get to the processor. So yes you need it. Did you loose L5481 also?
by PNI E.Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
by stecosHi everyone!
For my passion for technology I'm now collecting several... -
I've been working on this awful project with a Panasonic FZ-55, basically I'm trying to intercept the eDP signal from the main board, and replace it with my own eDP signal connected from an lcd driver. The problem is, for some reason the 30 pin ribbon pinout is really unusual and not playing nice with my LCD controller. Long story short, I managed to fuck up my board and pull off some pads on the eDP out port, I'm hoping to find either another eDP out source somewhere else on the laptop, or figure out this goddamn pin layout so I can just replace the whole native display complex with my controller...
Channel: Schematic Requests ONLY!
by SluggerBYes it's a 17 year old Panasonic plasma!
I was watching TV when there was a huge lighting strike nearby my house that shook the house. When that happened, the picture on the TV froze and the TV wouldn't turn off except by pulling the power cable. Now if you plug in the TV, it seems to turn on (it makes the turn on "clikcs" it always does, the red power light comes on but there is no picture, although I can see the back light around the edges. And the TV doesn't respond to the power button on the remote to turn off, and doesn't respond to the manual power button on the front... -
by dgnisbetI have a Panasonic viera plasma Tx-P50G20B which has a faulty main board. The picture freezes after about 30s and appears to lose vertical hold before finally going black. The main board part number - TNPH0838 (1) A - is common to several Panasonic tvs across a number of ranges however there is a second part number (TXN/A1LTUB for the 50") which is unique to each model.
My question is, given that the TX-P50G20B 50" differs from the TX-P46G20B 46" only in the physical size of the screen, is it possible to use the main board from the TX-P46G20B in a 50"? The secondary... - Loading...
