Philips 40PFL7505d/F7 Clicks & White Light Flash
  • barryra
    • Aug 2013
    • 107
    I am working on a Philips 40PFL7505d/F7 where the center white light flashes 11 times & then there's a click like it powers off & back on.. then it repeats. Any ideas? Thanks
  • barryra
    • Aug 2013
    • 107
    Re: Philips 40PFL7505d/F7 Clicks & White Light Flash
    I unplugged the power board from the main board & the light blinking & clicking stops.
    I post questions here pretty often. I want to say.. if I cannnot repair a tv (including this one) and someone here helps me through it. I will send you $20 via paypal... check or money order.
    • CapLeaker
      Leaking Member
      • 8214
      Not that I want your $20, I just rather want to return help to the forum in which others have helped me.
      First check if all fuses are good and check for shorts on diodes and transistors on the power supply. With everything disconnected from the power supply, try to force it on (jumpering PSON to 5V STBY with a 1k ohm resistor) and check all the voltages. When the power supply is off,only the standby voltage is on, all other voltages are off.
      • barryra
        • Aug 2013
        • 107
        Thanks CapLeaker.... fuses are good... I am going to have some time tonight & check the other items.
        • CapLeaker
          Leaking Member
          • 8214
          You may want to read this:
          https://www.badcaps.net/forum/showthread.php?t=36533
          • barryra
            • Aug 2013
            • 107
            Thanks... it says in posts that its the main & or power board. What do you think it is?
            • CapLeaker
              Leaking Member
              • 8214
              dunno yet. There are a few possibilities. Either the main board is turning the power supply on and off all the time, could be that the power supply senses a short on the secondary and does the cycle process, or there is something else plugged into the power supply that is shorted, just to name a few. Without doing any testing and voltage measurements, my guess is as good as yours! Start with my post #3 and see if the power supply stays on.
              • freakaftr8
                Asus a15 FA507RE-A15.R73050T failure
                by freakaftr8
                So this laptop seems to have some kind of failure. I bought it second hand and originally the previous owner said that they went to turn it on and it was presented with a quick flash of the power light the keyboard lit up and then the keyboard shut off and the power light went off as well but the battery indicator was white and after about 5 to 7 Seconds flashes orange really quick then shuts off and goes back to White. If the power button is pressed again the keyboard lights up really quick and then repeats. When I got it I could press the power button multiple times the keyboard light would...
                03-28-2024, 10:58 PM
              • ekozeko333
                [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                by ekozeko333
                I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                🔥 The Problem Started After Suspected ESD/PD Fault
                I experienced a power issue or ESD event through a USB-C charger
                After that, the NX20P5090 power switch was visibly burned and was replaced
                Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                🧠 What I’ve Done So Far
                Flashed...
                06-21-2025, 02:48 AM
                RAB Lighting 30 and 48 White LED 9-12VDC Blinding Light Bars—> Very nice light bar
                by sam_sam_sam
                I bought these LED light bars from Electronic Goldmine surplus store online
                These light bars are the nicest LED light bars I have ever seen in there online store
                I read the description of these light bars and said yeah right there bright at 9 volts
                Let just see if this is the case or not and just how bright is bright because I bought some of there light bars that they said were very bright and were ok but I would not say they were as bright as they claim
                But I thought I would give these a try only because they had both light bars on sale as a bundle...
                02-11-2021, 10:03 AM
              • ruletero
                HP Omen only do not turn on, only flashes white light
                by ruletero
                Hi everyone
                Please help me with this laptop
                HP Omen 15-dc0003la , MB DAG3DBMB8D0 REV. D
                It doesn't turn on, when I connect the charger with battery orange light appears on power jack and without battery white light appear, it is fine I think
                But if I press power button, power led flashes white once, only that, not consumes anything power, not start, nothing more.
                Bios was programmed with a working version, no changes.
                Voltages
                +3vS5 = 3v when I connect charger, next goes to 0 (I think is fine)...
                06-07-2023, 10:11 AM
              • djordje
                Philips 55 oled 804/12 red light blink
                by djordje
                Hello all,
                I have Philips Oled 55 (804/12) with black screen and red light blink.
                I have opened TV and tested voltages based on similar oled topics, on power supply board i am getting ps_o/f 3.3v and 5v for t-con_o/f while panel_o/f is 0v. And i get black screen.
                Also i have done self psb test and i am getting on psb +12V_t and also + 24V for panel. (Measurements on dmm are + 12.3V fot t-con and 22.4 for panel)
                When i power only psb and tcon with 4 ribbons for panel i only get black screen.
                My questions is what should i do next...
                01-03-2025, 04:00 PM
