Sony KDL-46W4000 (2 blink code)
  • funtastic
    • Nov 2012
    • 63
    • New Zealand
    Picked this set up for $10 hoping I could fix but was hoping it was the caps haha. Don't have too much knowledge about what to test.
    It's an LCD and when powering it on the relay clicks once with a green light and then gives red two blink code and relay clicks again. After it's just a constant two blink.
    Photo attached of the PSU & Main board
    Read that it's an over current protection error.
    Checked the voltage on the pins that connect to the main board and starting from the white wire it's 0.01v, 3.34, 3.38 then the rest is 0v.
    Disconnected the inverter board and t-con and it still gives blink code so that rules out them.
    Any ideas what I should do now?
  • funtastic
    • Nov 2012
    • 63
    • New Zealand
    Re: Sony KDL-46W4000 (2 blink code)
    anyone?
    • AFajitas
      • 183
      There should be a legend printed on the PCB for the connector going from the psu to main board that tells you what each pin should be. I think it's to the right of the connector and not visible in your pic. Can you take a picture of that? Also check fuses on PSU.
      • funtastic
        • Nov 2012
        • 63
        • New Zealand
        Here's the pictures of the connectors.
        Could anyone please give me an idea of what the fuses will look like or where they are? I suck i know :P
        • funtastic
          • Nov 2012
          • 63
          • New Zealand
          The underside of the PSU
          • AFajitas
            • 183
            Are you testing the voltages with the main board cable plugged in? Seems like you are missing some voltages.
            • funtastic
              • Nov 2012
              • 63
              • New Zealand
              Yes, when I tested it all cables were plugged in. Just unplugged for the pictures. Will test voltages again when green light is lit to see what is getting through
                https://www.badcaps.net/forum/attach...2&d=1422064925
                We need the Voltage reading of each pin number with its pin name next to each pin readings. The cables must be in place.
                The Voltage reading will be when the TV is plugged in but power switch is not activated, then after power switch is activated.
                We also need the pictures of the whole back side of the TV so we can see how all the boards are connected together.
                • funtastic
                  • Nov 2012
                  • 63
                  • New Zealand
                  Plugged in with switch off
                  Power on - 0v
                  AC-OFF-DET - 3.37v
                  3.3V Standby - 3.37v
                  UNREG_15v - 0v
                  - 0v
                  UNREG_15v_GND - 0v
                  - 0v
                  REG12v_GND - 0v
                  - 0v
                  - 0v
                  REG12v - 0v
                  - 0v
                  - 0v
                  Top right connector
                  BALANCER-ERR - 0v
                  GND - 0v
                  INV-ERR - 0.06v
                  BACK-LIGHT-ON/OFF - 0v
                  DIMMER - 0.07v
                  Switched on
                  Power on - 3.30v then 0.01v
                  AC-OFF-DET - 3.35v
                  UNREG_15v - 0v
                  - 0v
                  UNREG_15v_GND - 0v
                  - 0v
                  REG12v_GND - 0v
                  - 0v
                  - 0v
                  REG12v - 0.01v then 0.00v
                  - 0v
                  - 0v
                  Top right connector
                  BALANCER-ERR - 0v
                  GND - 0v
                  INV-ERR - 0.27v then 0.06v
                  DIMMER - 0.30v then 0.07v
                  • funtastic
                    • Nov 2012
                    • 63
                    • New Zealand
                    Thank you Budm, very helpful.
                    You and Tom66 helped me out fixing a tv a few years ago.
                      I am still trying to locate the diagram of the power supply board (A-1549-338-B), it looks like the PS_ON is present and then drops out.
                      • funtastic
                        • Nov 2012
                        • 63
                        • New Zealand
                        any help? it has the same psu in it.
                        Page 44 & 45
                          Did you hear the relay click when you activate the power switch?
                          BTW, I found the SCH of the power supply on the second file I down load from elektrotanya.
                          • funtastic
                            • Nov 2012
                            • 63
                            • New Zealand
                            Yes, it clicks once when switch is pressed and after the first set of 2 blinks it clicks again and that's when the above voltages change.
                              OK, please check the fusible resistor that I circle to see if it shows <1 Ohm, if it does then check the DC Voltage on the filter cap I circle, it should jump up to about 390VDC from 330V before it goes into shutdown, you will have to be real careful on this one since you are working on the primary side..
                              • funtastic
                                • Nov 2012
                                • 63
                                • New Zealand
                                After looking at the diagram and board for 30 minutes I need help locating the two parts you've circled.
                                Is the filter cap the largest capacitor?
                                How do I test a cap and ohms with the multimeter?
                                I've only ever tested voltage with putting negative on the chassis and positive on the pins.
                                Last time I tested something with 240v I made a cloud of black smoke haha so I'm a little cautious now.
                                  OK, you can test the resistor and Boosted Voltage on the primary side on the top side of the board, so it is easier, just do not touch anything with your hands.
                                  So check the resistor R6500 first (no power apply), then check the voltage when you hit the switch and watch your meter closely to see if the voltage does jump up >360VDC.
                                  • funtastic
                                    • Nov 2012
                                    • 63
                                    • New Zealand
                                    316v with switch off - 394v switched on.
                                    • funtastic
                                      • Nov 2012
                                      • 63
                                      • New Zealand
                                      As soon as relay clicks the second time it goes back to 316v
                                        OK, that is good, the PFC Voltage booster is working but it goes into shutdown due to missing 12V power supply which runs on the boosted Voltage.
                                        So is the fusible resistor OK? R6500.
                                        • cloo
                                          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                          by cloo
                                          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                          After doing a factory reset this problem was gone and the picture was back to...
                                          01-06-2025, 06:02 AM
                                        • reporter1979
                                          2 red blink code on old led tv Sony KDL-40W2000
                                          by reporter1979
                                          Hi all, the TV KDL-40W2000 was flashed by a lightning.
                                          Firstly I got the 3 red blink code.
                                          Following other threads I changed the power supply board and got always 3 blinks.
                                          So I changed also the mainboard and now I get 2 blinks error code. Tried also with the other ps board, still getting 2 blinks.
                                          The TV turns on for a minute or two with green led and blank screen, if I press buttons the green led blinks fast. It turns to 2 red blinking led after a while.
                                          What else can I do?...
                                          02-17-2023, 11:50 AM
                                          LCD LED TV Service Menu Codes
                                          ALL LCD LED TV SERVICE MENU CODES
                                          Service Menu Code with Board Name
                                          China Universal Board / Jumper Board Service Menu Code
                                          Changhong Ruba Service Menu Code
                                          Ecostar LED TV Service Menu Code
                                          Orient LED TV Service Menu Code
                                          Haier LED TV Service Menu Code
                                          TCL LED TV Service Menu Code
                                          Samsung LED TV Service Menu Code
                                          LG LED TV Service Menu Code
                                          Videocon LED TV Service Menu Code
                                          Supra LED TV Service Menu Code
                                          Toshiba LED TV Service Menu Code
                                          Symphony LED TV Service Menu Code
                                          Veste/ LED TV Service Menu Code...
                                          10-31-2024, 03:58 AM
                                        • Storyteller12
                                          Sony XBR-65X900E 4 Blink Code
                                          by Storyteller12
                                          I have this set. It turns on and is watchable for a few minutes but then shuts off and flashes 4 red lights.
                                          I don't work on Sony much but assumed it was backlights from what I read.
                                          Opened up the TV and tested all the backlights with led tester and the all work.
                                          I know sometimes that doesn't mean anything since it's not running at full current but I hate to spend $120 on backlights (shopjimmy) is the only one that even has them just to find out I missed something.
                                          So anyway to test these lights similar to the way we test...
                                          12-31-2022, 02:17 PM
                                        • EazyBone
                                          Sony 85x90CK 4 red blink
                                          by EazyBone
                                          So I got this Sony and purchased it working.. got it home and it was 4 blinks red. Seller actually refunded me thankfully. Now it's massive to take apart and I know 4 blink can be the panel sometimes but not always..
                                          But I found a method through other ways with grounding out the bl error pin on the LD driver board. Now the tv turns on and works.
                                          Pin is number 27. It was either remove the resistor right next to the solder pad or solder the pad to ground. I soldered the pad.
                                          Now what is this going to do to the tv? Is it just going to die shortly down the road?...
                                          07-18-2025, 12:53 PM
