Panasonic TC-P42S1 Plasma "A" board issue
  • Dhamlin
    • Aug 2013
    • 26
    Hey guys, thanks in advance for your help!! I have gotten some great info and help from U guys!!
    Ok, so, this tv has the 9 blinks error. " No communication between Sys MPU and Panel MPU"
    Both these chips are located on the "a" board. Sys MPU is IC1100/ Panel MPU is IC9003. I am no electronics tech but I am super cheap and I deal with low voltage controls every day. I did some basic checking and I found that the STD_3.3VDC is comming from the "K" board (I think). The 3.3vdc is just fine comming in on the connector. When I check the 3.3vdc on the Panel MPU it comes on with startup but then goes off after error. That voltage comes on and goes to 2.49VDC before it shuts down. There is enough time for it to settle out before it shuts off.
    I know from my own experience that devices shouldn't tolerate 10% higher or lower than design voltage. So, I was hoping to make a jumper to power up that chip in stead of finding the bad component in the switched circuit. I know this is not sound troubleshooting or repair. Was thinking of cutting the trace that supplies that area vith the 3.3vdc, make the jumper and see what happens....
    Am I nuts? Worth a shot?
    Better Ideas?
    Its a very nice tv...They want $155 for a used "A" board on ebay....
  • Dhamlin
    • Aug 2013
    • 26
    Re: Panasonic TC-P42S1 Plasma "A" board issue
    Also wanted to say thanks to Tom66 for the schematics!!!!!
    • tw2005
      • Oct 2011
      • 6458
      http://www.ebay.com/itm/151560282881...881%26_rdc%3D1
      • Neelix
        • Oct 2013
        • 145
        • South Africa
        Had a quick peek at the service manual and STB_3.3V which supplies the Panel MPU actually comes from the DC-DC converter inside IC9004 and the converter is turned on or off by the System MPU. You should not jump parts because you can cause more damage that way. STB3.3V is dropping because STB_5V is dropping or because it's being pulled down or because the System MPU detected a error and then turned the converter off
        • Dhamlin
          • Aug 2013
          • 26
          well luckily my "better judgement" got thr best of me
          I looked at both dc-dc converters and saw steady 5vdc comming in and 3.3vdc comming out(before power supply shut down. I am still hunting and pecking to find some kind of issue.
          BTW, thanks for taking the time to look! I know it took me 15 min just to find the components I was looking for in there!!
          • tw2005
            • Oct 2011
            • 6458
            A corrupt eeprom or flash IC can cause 1 blink so it's not necessarily going to be obvious what is causing it.
            • Dhamlin
              • Aug 2013
              • 26
              Thanks TW but its 9Blinks.
              I am aware that there could be corrupt or damage IC's....I am really hoping to find a repairable component ...
              • tw2005
                • Oct 2011
                • 6458
                Ah, yes, I'm 8 blinks shy. I did manage to get a board to 9 once swapping that 48 pin flash ic and accidentally creating a short on one of the paths to that chip.
                • Dhamlin
                  • Aug 2013
                  • 26
                  Yep I've done a couple of those. Almost feels like ur eyes are playin tricks on you when ur lookin at them later....Everything looks like a possible bridge
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • stecos
                    Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                    by stecos
                    Hi everyone!
                    I happened several times, in the search for help from the web, to consult this very interesting forum.
                    So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                    Having said that I come to the gist of my post on the forum as the title suggests.
                    For my passion for technology I'm now collecting several...
                    11-28-2022, 11:39 AM
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                    After all of...
                    07-13-2024, 08:14 PM
                  • canadaboy25
                    Panasonic TC-P54VT25 No image. A or D board?
                    by canadaboy25
                    I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                    I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                    01-17-2021, 01:06 AM
