Sony KDL-40EX503 bad panel?
  • PowerAmpFreak
    • 982
    • Sweden
    Hi all.
    I need you to help me diagnose this one.
    Bad panel?
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Sony KDL-40EX503 bad panel?
    That's a crap shoot. The complete green band looks almost like a tcon problem. Also the band looks to be extremely wide to be one tape carrier bond out. Looks like two bonds are not active. The chance of two out at the same area are rare. I'm going to say tcon. Lets see what others say.
    Edit: I looked closely at the picture and it looks like the ribbon on the far right is only producing half the image. So that makes me more likely to say tcon. Slight chance it could be a faulty connection on the ribbons going to the panel. You could try reseating them.
    • PowerAmpFreak
      • 982
      • Sweden
      Hello.
      I was so lucky finding another T-con of the same model. And it appeared the T-con was at fault. Thanx!
      • freakaftr8
        • Oct 2012
        • 3743
        Good to hear
          Wow, very surprised. I would have said panel any day of the week. Good fix!
          • rimwall
            Sony KD-65x8500b - bad Tcon or panel?
            by rimwall
            Hi, hoping for some views on this one which I've not come across before. The TV generates an image that has 12 noticeable bands across it. The image is still there and accurate, but the colour (or perhaps the brightness) changes gradually across each band which creates a noticeable 'step change' at the edge of each band. Given it's a 4K TV with 2160 rows of pixels, I'm guessing the 12 bands correspond to 12 gate drivers of 180 rows each. If this guess is right, then perhaps:
            a) all the gate drivers are malfunctioning the same way (which seems unlikely), or
            b) the Tcon board is malfunctioning,...
            10-24-2023, 07:58 PM
          • x_orange90_x
            TCL 50S535 bad tcon or panel issue?
            by x_orange90_x
            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
            03-29-2025, 11:02 PM
          • swrb898
            Sony KD-70X690E Bravia; Bad TCON? Bad panel?
            by swrb898
            What's wrong with my TV: the TCON, the panel, or something else? I'm stuck.
            Problem:
            Last week, my Sony KD-70X690E 70" stopped displaying a picture. The TV powers on, and the back lights power on. However, the TV doesn't seem to boot up. I say this because the SONY splash-screen logo does not display, nor does any picture display, nor can I invoke a menu by pressing "Menu" on the remote. Other than back-light bleed, the screen is black.
            My troubleshooting got me this far:
            With the left-hand TCON to bottom-board ribbon cable...
            12-28-2021, 08:12 PM
          • advant
            by advant
            02-03-2020, 12:25 AM
          • Daren87
            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
            by Daren87
            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
            08-13-2023, 03:25 PM
