anyone have the print for the powersupply on a pn50a550fx1za powersupply? I need to jump some traces where a transistor blew. even buy a non working one if traces are good thanks for any help here.
bn0044-237a powersupply problems
Re: bn0044-237a powersupply problems
Diagram provided by tom66.Attached FilesNever stop learning
on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
i verified the driver of the pΓ©ripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
i don't understand the reasons of the white stripe at the bottom of the screen below the task... -
by HondamanRecently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
(I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...-
by clabrNeed help to solve some problems with this laptop.
After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
Before this had happened I observed some other problems:
When I tried replacing original mecanical HDD with a SSD HDD could not get them... -
by CapacitorialHello guys,
I have a Philips 240B7QPJEB. The monitor seems completely dead.
I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
The weird thing is, that the Power LED is powered over the TCON board.
On The TCON...-
12-28-2024, 02:12 PM -
by jeremy96Hi everyone,
I recently bought a used PS4 and discovered that the power button is broken. Upon closer inspection, I found that the traces for the power button on the PCB are damaged and torn.
Does anyone know where these traces lead or have any advice on how to repair them?
Thanks in advance for your help!β...1 Photo - Loading...
