LG 42lg30-UD... no picture
  • stratos976
    • Apr 2014
    • 21
    • united states
    I was given a LG 42g30-UD, because the picture doesn't work. With the help of this forum I was able to repair my Samsung Plasma so I thought I'd give this a shot also.
    I've searched on here but need some direction to troubleshoot further, as other sets close to this model seem to be "-UA" and have more boards in the back.
    when you power on the set there is no flicker or flash of backlight, just dark, but there is sound. With a flashlight, I am able to "see" snow on the screen and also the input options if I scroll though them. I've added a couple pics of the opened back for reference.
    thanks in advance!
  • KevinCro
    • May 2014
    • 104
    Re: LG 42lg30-UD... no picture
    There is a fault somewhere with the backlight system. Either a bulb is bad or the power to the backlight is not being supplied. Can you post a close up of the power board front and back? The inverter board might be bad because usually the screen will light up for at least a few seconds.
    • CapLeaker
      Leaking Member
      • 7967
      Need hi res pics of the whole power supply and areas with the cables unplugged so we can read the pin outs.
      Basically you have to see if the inverter board is getting the supply voltage and the BL ON voltage. If either is missing, the backlight is off.
      • stratos976
        • Apr 2014
        • 21
        • united states
        Ok I'll work on the pics. I'm assuming the power supply board is the tan one, would the board on the far left under the metal cover be the inverter board?
        • CapLeaker
          Leaking Member
          • 7967
          yes
          • selldoor
            Slow Learner
            • 7870
            Please post the pictures using manage attachments so that they appear as thumbs so we dont have to have them open unless needed.
            • stratos976
              • Apr 2014
              • 21
              • united states
              Here are pics of Inverter board front and back. I took a close up of the caps as the connections to me looked like they got hot. This board is getting
              24.8v on pins 1-5,
              pin 11 (VBR-A) was 1.6v,
              pin 12 (on/off) 1.4v,
              pin 13 (VBR-B) 2.6v,
              pin 14 (errout) 0v
              Can the output to the bulbs be checked?
              • stratos976
                • Apr 2014
                • 21
                • united states
                These are power supply pics. I checked voltage out on all the pins, I wrote down what I saw but I really don't know if they were proper or not. Nothing on the board to me looked visually bad or that it had become overheated. both fuses were good. pics are clockwise around board starting at bottom right corner where power enters.
                • CapLeaker
                  Leaking Member
                  • 7967
                  Yep, but need those pics from the power supply so you can force the power supply and the backlight on.
                  Can you make another one of the 2 connectors so we can see the writing?
                  • stratos976
                    • Apr 2014
                    • 21
                    • united states
                    Here are connectors on power board.
                    • CapLeaker
                      Leaking Member
                      • 7967
                      Looking at what you have posted so far is that the on / off voltage for the inverter is too low to turn on the back light. I'd expect more than 2.5V there.
                      All in a nut shell, you have to disconnect the main board so that only the inverter is hooked up to the power supply. Then you have to jumper the PWR ON and the ON/OFF pin through a 1k ohm resistor to the 5V Stanby.
                      With that the power supply is forced on and the backlight should light up.
                      • stratos976
                        • Apr 2014
                        • 21
                        • united states
                        Thanks for the manual!
                        A couple questions.
                        on the double pin connector of the power board the 16.5v pin is only putting out 15.6v, could this be a problem?
                        the on/off pin on the double pin connector has 2.8v, the pwm-dim has 1.6v.
                        the PWM-dim pin of the inverter has 2.6v, while the on/off only has 1.4v
                        Are the ON/OFF and PWM-DIM pins the "same" on the double pin connector and the inverter cable connector? seems weird to me to have 2.8v at ON/OFF and 1.6v at PWM at the double pin connector, then at the inverter connector have 2.6v at PWM and 1.4v at ON/OFF, like they swapped??
                        just to clarify this, what I'm trying to do is take the 5v standby and with a 1k resistor put more than 2.5v onto the on/off and PWM-dim inputs of the inverter board to get it to turn on.
                        • stratos976
                          • Apr 2014
                          • 21
                          • united states
                          I tested as posted, I forced on the inverter by jumping the 5v standby voltage trough a 1k resistor to the on/off signal of the inverter board. This powered up the inverter board and backlights ARE working.
                          Where would the problem be that would keep the inverter board from getting the on signal, in the power board or the main board? or something else
                            The main board generates the BL_ON and dimming signasl to turn on and control the inverter circuit, the main board also generates the PS_ON signal to turn on the main power supply.
                            • stratos976
                              • Apr 2014
                              • 21
                              • united states
                              Thanks, so next step would be to replace main board I assume.
                              • CapLeaker
                                Leaking Member
                                • 7967
                                I am glad you narrowed down the problem!
                                Either it is main board replacement time, or you try to figure out why the back light on signal isn't generated properly.
                                • stratos976
                                  • Apr 2014
                                  • 21
                                  • united states
                                  What things or where would I need to check to see if the signal isn't being generated properly. That sounds like an internal board thing, but it may be something I could fix?
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    You need to find the BLon pin on the main board and try and trace it back. See if you can find it in the schematic and see where it goes. ( usually main processor eventually)
                                    Post good clear picture of the main board and the area 3-4 inches around the blon pin
                                    • stratos976
                                      • Apr 2014
                                      • 21
                                      • united states
                                      To update thread, I went ahead and purchased a mainboard from a seller on E-bay. It arrived today and I installed it. Set is working all looks good so far.
                                      Thanks for the help!
                                      • CapLeaker
                                        Leaking Member
                                        • 7967
                                        Thanks for the follow up!
                                        • PNI E.
                                          tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                                          by PNI E.
                                          hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                                          02-20-2025, 08:36 AM
                                        • dronerat
                                          Samsung UE48JU6400W - back light on, sound on, sometimes picture.
                                          by dronerat
                                          Hi Guys,
                                          This forum has been in great help to me, but I stumbled upon a strange problem with a salvaged Samsung TV that I am banging my head to troubleshoot.
                                          PSU: L48S6 FHS BN44-00807D
                                          T-Con: BN95-01937A
                                          Panel: CY-GJ048HGLVLH
                                          MB: NA (Currently as the TV is assembled and forgot to take picture)
                                          As I said earlier I have some issues with the TV I got from a friend of mine. The TV had no picture, but sound, back light and everything else was working fine.
                                          It was sent to an authorized service for repairs and returned with the...
                                          05-15-2020, 08:03 AM
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          by sam_sam_sam
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-12-2024, 02:30 PM
