Is There Some Earthly Reason my Meter Can't Read Vsc and -Vy ???
  • mmartell
    • Oct 2013
    • 3189
    This has happened several times now on different sets so now I'm positive there is something wrong with this thing. Reads Va Vs Vzbias etc fine.
    It is some Korean unit I've had forever - was given to me by an electrician who may have had a few "oops" with it back in the day. For all I know it was snuck over the border from North Korea before getting here on the slo boat.
    Does this have anything to do with floating ground nature of these voltages ?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Is There Some Earthly Reason my Meter Can't Read Vsc and -Vy ???
    Let's see a picture of your meter. A picture of the insides (pcb), both sides, would also help.
    It would also help to describe where you are putting the black probe (ground) when measuring. Some people don't realize there are two grounds (hot and cold). Or they don't know where hot and cold ground are.
    --- begin sig file ---
    --- end sig file ---
    • mmartell
      • Oct 2013
      • 3189
      It reads voltages with respect to cold and hot ground fine. I'm talking about Vsc and -Vy which have a pair of test points on the ysus board.
      I can't post pics atm will try to find an online pic.
      • retiredcaps
        • Apr 2010
        • 9271
        Okay, I think I understand now. Something like this diagram?
        So if your multimeter can read positive and negative readings fine with with respect to ground, what is it showing when you try to read Vsc + and - test points?
        • mmartell
          • Oct 2013
          • 3189
          Yes exactly like that. One reads a lower, fluctuating voltage. The other reads nothing until I flip the scale up to 1k (from 200v) then reads about 1700 ! Can't remember which is which and these readings were from working sets.
            Yes, if you Meyer has inadequate shielding you will find it hard to measure things on a plasma, especially the floating ground parts. What meter do you have?
            • mmartell
              • Oct 2013
              • 3189
              It's an RCC510, at least that's what it says on the front. Not at home and there was little on the www last time I looked.
              • mmartell
                • Oct 2013
                • 3189
                This probably doesn't help but here's an image I found.
                http://thumbs2.picclick.com/d/l400/p...ith-probes.jpg
                  You should consider investing in a better meter. I'm sure retiredcaps will have something to add but the Fluke 17B is worth a look.
                  • mmartell
                    • Oct 2013
                    • 3189
                    Haha ok thanks tom. Btw what type of radiation is interfering with the function of the meter ?
                      Electromagnetic radiation...Interference from the plasma panel and sustain boards. Just bring an AM radio near a plasma set with the cover off... it will overpower most stations.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        The original design manufacturer is a Fine Instruments 201.
                        http://www.finest.co.kr/html/pro_10.html
                        Fine also makes some DMMs rebadged under UEI and Klein.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          The newer 17B+ is out now for the same price as the 17B. It has a bit more functionality and larger LCD display digits.
                          A fellow Canadian now living in New York just posted a video review/teardown.
                          http://www.youtube.com/watch?v=OCbAWbqiygg
                          Note: I don't have this meter so I can't give first hand comments about it.
                          PS. A budget would help narrow down the selection criteria.
                          • mmartell
                            • Oct 2013
                            • 3189
                            There it is ! Thing of beauty, isn't it ? Lol.
                            So would a few well-placed pieces of conspiracy foil allow me to take some measurements until I can go through the process of procuring a replacement ?
                            • mmartell
                              • Oct 2013
                              • 3189
                              Well quite honestly we're not building Space Shuttles here but I would say under $100 would be about right.
                              I would like a large lcd screen, continuity beep and auto-ranging is nice as well. Are any of the ones with thermocouples reliable ?
                                The foil would only work if it was inside the meter and connected to the common terminal. However this would compromise the safety of the meter if it was not designed in in the first place (flashover distances, etc.)
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  For $100, you certainly have a number of choices.
                                  1) I know tom66 has the BK2709b and he is happy with it. It is the winner of the $100 eevblog shootout.
                                  http://www.eevblog.com/2010/07/11/ee...i-t-part-1of2/
                                  2) For $50 CDN, you can get a basic new Fluke 101. It is their lowest cost meter and for the purposes of badcaps repairs, it will meet most of the needs especially if there is another meter to measure current which is rarely required.
                                  I talk about here.
                                  https://www.badcaps.net/forum/showthread.php?t=42109
                                  As I mentioned, the Fluke 107 in Martin's review is identical to the 101 but without all the extra functionality found in the 107.
                                  3) If you are not opposed to buying used, you can get a number of good second hand Fluke meters in the $100 range either locally on kijiji or with patience on ebay.
                                  You want to put these Fluke models on your radar: 115, 117, 77IV 175, 177, 179, 83 III, 85 III, 87 III, 83V, 87V, 187 and 189. All have largeish lcd digits and fast continuity speed. Yes, I have used or own the above listed.
                                  For the 115 and 117, try not to pay more than $70 CDN.
                                  4) BTW, I know some people will comment that brand xyz offers more bang for the buck. While that may be true, probing around plasmas with 200V+ voltages, the safety of the multimeter should be primary concen. If there is PFC circuitry involved, voltages approaching 400V are common on the SMPS hot side.
                                  You will, like I, have an oops moment, and you want both yourself and the multimeter to survive.
                                  Trying to measure the nearly 400 DCV large filter capacitor, but your multimeter is set to measure resistance. Oops.
                                  Trying to measure the ACV of the inverter transformer going to the ccfls on a LCD which is possibly more than 1500V during initial power up. Oops.
                                  Trying to measure the power mosfet on the hot side to see if it is shorted, but forgot power was on? Oops.
                                  Trying to measure voltage, but your probes are in the amps jack. Oops.
                                  5) For non Fluke alternatives, I own a Greenlee DM-200A (made by Brymen). It has nice big lcd digits, fast continuity, proper input protection and is UL listed. I got mine used for $21 USD total (a great deal). I really like the large digits and compact size. You can see a picture here
                                  https://greenlee-media.precis5.com/0...18865aa693cc24
                                  If I could get more for $21 USD, I would buy them.
                                  6) For those wanting to know more about input protection, Dave does a good tutorial using the Fluke 27. Most people, incorrectly, just think that the fuses protect the multimeter.
                                  Note the Fluke 27 doesn't have a very large lcd display and very slow continuity speed. However, if you can get one for $40 or less, it is built to last.
                                  http://www.eevblog.com/2012/10/19/ee...tion-tutorial/
                                  http://www.eevblog.com/2012/10/26/ee...iode-followup/
                                  7) Anyway, I gave you enough to think about and to keep you busy for a couple of hours. You can ask more questions once you narrow down your choices a bit.
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    I had a few occasions where I have used them and they work. I'm not sure how accurate they really are, but I'm happy with the ballpark reading for my purposes.
                                    I also picked up an used Fluke 62 for $20 CDN locally. The deals are out there. You just need to know what is below market value and have patience.
                                    • mmartell
                                      • Oct 2013
                                      • 3189
                                      That IS alot of options. Will look into them. Thanks.
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        I agree with Tom to NOT modify the multimeter.
                                        One thing that might help/work is to get a set of really long test probes so you can place the multimeter farther away from the TV. However, this might be a two person job unless your eyesight is really good.
                                        • chth96
                                          by chth96
                                          03-09-2024, 10:03 PM
                                        • jorpec
                                          by jorpec
                                          Hi
                                          Thnaks
                                          01-23-2023, 10:37 AM
                                        • Stephan Mathers
                                          EDMI ATLAS MK10 Electronic Meter Discussion
                                          by Stephan Mathers
                                          Greetings, new guy here but always interested in the crazy universe of modding
                                          We just finished construction of around 25 vacation houses, all inside the same private area.
                                          Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
                                          The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
                                          Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
                                          05-20-2025, 09:09 AM
                                        • eccerr0r
                                          lowest current galvanometer/analog meter (passively powered!)
                                          by eccerr0r
                                          Most analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
                                          On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and...
                                          04-16-2025, 12:41 AM
                                          Bought a volt multi meter that is capable of data logging Hantek 365C USB/Bluetooth Data Logger
                                          I have had this in my wish list for quite a while now and I might need to test BMS protection board with this device because of the limitations of the battery testing machine that I have been using
                                          https://www.aliexpress.us/item/32568...yAdapt=glo2usa
                                          What this will allow me to do is use my load testing machine that is having issues with the voltage cutoff set/ current meter monitoring system and I decided not to try to replace it or repair it I just going to use a very primitive load testing...
                                          03-30-2025, 11:05 AM
