Vizio E321VL "2 seconds to black"
  • ChIck3n
    Dell u2311h 20000 seconds to black issue
    by ChIck3n
    So I've had this monitor for probably a decade now, and it's finally starting to fail. Began with a little sporadic flickering, then eventually started going black (power LED stays blue, can still see image on screen with flashlight). A power on/off fixes it for a bit, but then it happens again. Once it got to the point I was dealing with this every few minutes, I opened it up and just replaced all the caps (minus the big one) on the power board with new Panasonic ones. All the old caps tested fine on an ESR meter, and this worked for 5 days. But the screen just went black again today, so...
    09-09-2024, 11:44 AM
  • Bob1394
    Vizio M65-C1 | Logo appears for 10 seconds then off
    by Bob1394
    I have used the search, and am stumped.
    My Vizio M65-C1, Vizio logo appears for about 10 seconds then goes off.Power LED blinks 15 times then the TV powers down.
    I have read through many threads on the M65-C1 including the following threads. I feel like I must be looking right past the solution to my problem:
    https://www.badcaps.net/forum/showthread.php?t=81088
    https://www.badcaps.net/forum/showthread.php?t=84241 (not clear on the Eprom actions)
    Observations
    1) [Interaction] Power turned on via TV button (or remote)...
    02-08-2023, 01:03 PM
  • bobbyskillz
    Vizio E321VL - 2 Seconds to Black
    by bobbyskillz
    Hello, friends.
    I've been making progress with a Vizio E321VL that was victimized by an apparent power surge. On the PSU it took out the fuse, a SMPS IC (FSQ0465R), and a MOSFET (FQP13N06L). Now I have two seconds to black. After replacing those components, all the power at the cable going to the main board seems proper, except VBR_B drops from 3.3v to 2v gradually after the backlight goes out.
    I've poured over other threads here to get some clues, but none appear to have a solution for the same problem. I've tried disconnecting the IR receiver board; it didn't work....
    10-05-2018, 07:25 PM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • DrankinSAW
    LG 37LG5020 and the tale of 2 seconds to black.
    by DrankinSAW
    I bought an LG 37LG5020 with a very strange issue.. it turns on, the display looks fine, but still, after 2 seconds, the TV shuts the backlight off..
    However, if i leave it plugged in for 20-40min.. the time it takes to shutdown the backlight, doubles (to 4 seconds)..
    I bought a new inverter, set to arrive on December 13th
    11-22-2023, 01:10 PM
