I have an lg plasma 60pa5500 that the y sustain board burnt up in. I just replaced the y sus board. A picture now comes on but it's not clear and now the tv cuts off shortly after cutting the tv on. When I unplug the power to the y sus board the tv will come on and stay on with sound. Any help is appreciated.
Lg plasma 60pa5500 picture issues
Re: Lg plasma 60pa5500 picture issues
Ok for these tests you'll need to set your meter to DC volts (DCV) 1000V scale.
Red lead in Volt/mA jack, black in COM.
Place leads across Vsc and -Vy resistors on Y-sustain. These will be marked usually. The Y-sustain is the large left hand board (looking from the back).
Tell us what you measure.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
164 hv with the com on the -vy and the volt/ma on the vscLast edited by Nrollins04; 01-20-2015, 10:38 PM.
not sure what the little plastic screws that go in to the vac and -vy do but I turned them all the way counter clock wise and it came on and stayed on. But he screen was still not right. Pixels were showing rainbow and still had a big black spot In one corner. Thinking there are two more plastic screws on the y-sis board what can it hurt to turns those as well and the picture appears to be fixed. Can someone tell me what those plastic screws do ? Thanks in advance
It is a bad idea to adjust those controls without knowing what they are supposed to be set to. I hope you remember the original position. Put them back in to that position and test Vsc and -Vy as mmartell suggests.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Better pics of each board will us help you figure out where to test each voltage.
PSU usually has test points for the VS and VA voltages. Top of board clearly marked. If these are not to spec then other voltages will be off. The value is on the sticker on the panel. Vsc and -Vy are on Y sus, VE is on X sus.
These voltages can be enough to KILL so be careful when testing.
When testing volts on the boards ground lead goes to the metal chassis of TV positive lead to the various test points.
The plastic screws are potentiometers for fine tuning each voltage to spec.
If the volts get too high the panel will be damaged beyond repair.Last edited by MagicSmoke; 01-26-2015, 07:59 PM.
Ok thanks. I'll put a pic of y sus board up. When I installed the new y-sus board I turned the plastic screws all he way right thinking I was tighting everything up. I turn them all the way left and everything started working correctly wish I had know what they were from the get go. Glad I came back here to see what u guys said.Last edited by Nrollins04; 01-26-2015, 09:01 PM.
