General ? concerning PS_On and other DC voltages from PS to MB
  • Nick's Tvs
    • Jan 2014
    • 621
    Re: General ? concerning PS_On and other DC voltages from PS to MB
    ok so that question got answered pretty quick. Stopped working. So it looks like Q5 is no longer giving out any voltage and neither is the PS-ON when I press the power button. I just get 0v no matter what. 5 volt line is still active but that's it. I unplugged it and left it unplugged for the last 15 minutes, and it seems like that may have gotten it back to square one with the 1.2 volt appearing again and the 3.2 appeared again. But it seems like if I do this jumper and keep the tv on, the board doesn't like it and just shuts down pretty much for a while.
    Thoughts?
    • Nick's Tvs
      • Jan 2014
      • 621
      So this is what I found out. I can turn the tv on and off as many times as I want with the mod. But if I unplug and plug it back in, the tv is inoperable for about 4 or 5 minutes maybe less. I am thinking the vizio logo actually is "blinking" like some vizio tvs do when you first plug them in, and is initializing before I can turn the set on. So the mod actually does work fine I think.
        If that Q5 Collector is at 0V then I do not think it is related to what you are seeing then since is not active when it is at 0V, you can verify again as to what Collector Voltage is when you unplug and replug the power back in. Q5 may be doing some kind of reset when TV is unplugged and plugged back in.
        If that is the case then we need to find other Active device that can be used as a source for the PS-ON signal.
        • Nick's Tvs
          • Jan 2014
          • 621
          Also additionally the IR sensor does not turn on meaning I can only use the buttons on the side and the remote does not work with the set.
          the IR connector J6 is the bottom one left right next to the logo connector J5 that goes from amber to white when turned on. Neither of those are activating. The logo stays a very dim amber with .9 v going to it and the infrared sensor gets 0volts no matter what.
          • jts1957
            • Dec 2008
            • 38
            #45
            I also had a VF550M (Main= 3655-0062-0150 (4C)) with 1.2 volts at PSON. Applying 3.3 volts from an external power supply would allow the set to work.
            Trying to follow a foil trace that at times feeds through from one side of a PCB to the other is a challenge. Best I can speculate is a pin on the large heat sinked (Micro?) puts out a voltage that goes to R11/C19 junction AND along the way heads over to Q5 base/Q7 collector.
            Anyway, checking for a convenient point that has zero volts with the set OFF and 3.3 (to 5) volts with the set ON led me to U9 (VIN pin - 3.3 volts). Soldering a jumper wire between that pin and R11/C19 junction allows PSON to turn Power supply ON/OFF as required.
            • Capacitorial
              Powersupply has all the voltages - Monitor still no power
              by Capacitorial
              Hello guys,
              I have a Philips 240B7QPJEB. The monitor seems completely dead.
              I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
              On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
              The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
              The weird thing is, that the Power LED is powered over the TCON board.
              On The TCON...
              12-28-2024, 02:12 PM
            • triplefour
              General question about LVDS voltages. Blank Backlit Screen.
              by triplefour
              im trying to understand how mainboards send data to tcons and tcons send data to panel boards and how panel boards control the panel itself.
              but starting at the beginning: if i have a tv with symptom: blank backlit screen, i want to verify if the mainboard is functioning properly first. its easy to see if its sending 12v to the tcon...but im pretty foggy on what the other lines of the LVDS connector should have on them.
              and also should they have the same voltages on them regardless of if the t-con is connected?
              and also how do you probe these pins easily? they are...
              12-18-2022, 02:45 AM
            • gjgib
              Help reading schematic voltages input/output
              by gjgib
              Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
              I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
              I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
              I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
              05-06-2024, 08:11 PM
            • RossMoodley1967
              HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
              by RossMoodley1967
              Hello
              Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
              Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
              03-01-2024, 06:07 AM
            • karlp028
              MSI Z390-A PRO missing VCORE voltages
              by karlp028
              I've got an MSI Z390-A Pro motherboard that starts up fine, but it's missing the VCORE (and VGT) voltages. All of the other voltages are present (e.g. VCCSA, VCCIO) and I know the CPU (i7-9700k) is good. Now, the original PWM controller (UP9521P) had an internal short and I replaced it with a new one. All of the enable signals look good. The problem seems to be the PWM signals going to the MOSFET drivers. I checked them with an oscilloscope and they are all flat 1.5V with no pulses. I don't know why this would be and I'm not sure where to look next.
              06-23-2025, 01:25 AM
