General ? concerning PS_On and other DC voltages from PS to MB
  • Nick's Tvs
    • Jan 2014
    • 621
    Re: General ? concerning PS_On and other DC voltages from PS to MB
    That resistor has he same 1.2 voltage on both sides.
    q1 and q2 seem to have 0.663 volts on the lower right pins, so they are splitting the voltage? I replaced Q1 earlier but no difference. did not replace q2.
      Q1 looks to be driving the U1.
      What DCV do you have on the Collector of Q2, Q5, and Q7?
      • Nick's Tvs
        • Jan 2014
        • 621
        Q1
        Collector 0v
        emitter 0v
        Base .661v
        Q2
        Collector .661v
        emitter 0v
        base 0v
        Q5
        collector 3.2v
        Emitter 0v
        base 0v
        Q7
        Collector 0v
        Emitter 0v
        Base .637v
        All the pins on the right side of U1 are all 5.06 volts pin 1 and 4 on left side are also 5.06 volts and pin 2 and 3 are 0v don't know if that helps at all.
        • Nick's Tvs
          • Jan 2014
          • 621
          Also just for fun, I went back to see what the voltages would be when forced on with the main plugged in, and the tv did not turn on this time. Well I had all the PSB voltages but the no backlight no picture.
            Originally posted by Nick's Tvs
            Q1, this transistor is BIAS on so Collector is 0V
            Collector 0v
            emitter 0v
            Base .661v
            Q2: this transistor is NOT BIAS on so Collector should be at 3~5V depends on VCC. It is not right
            Collector .661v
            emitter 0v
            base 0v
            Q5: this transistor is NOT BIAS on so Collector is 3.2V
            collector 3.2v
            Emitter 0v
            base 0v
            Q7: this transistor is BIAS on so Collector is 0V
            Collector 0v
            Emitter 0v
            Base .637v
            Remove Q2 and see what DCV you get at the Collector pin.
            We are getting so close to where the problem is, just have to locate them switched transistors.
            • Nick's Tvs
              • Jan 2014
              • 621
              Same thing .661 at collector when Q2 is removed
              Also wanted to make sure but you did see post 24 correct?
                Yes that is because the pin 1 on the main board is not allowing PS-ON to go high, it is pulling down the Voltage that you forcing on (you did use resistor for force on right?) if you tie the PS-ON pin to the STBY Voltage directly and then plug in to the main board, the device on the main board can be damaged.
                'Same thing .661 at collector when Q2 is removed' so if you check PS-ON on pin 1, do you still see 1.2V, if you do then Q2 may not be related to the PS-ON signal path.
                • Nick's Tvs
                  • Jan 2014
                  • 621
                  No resistor used but it still turned the set on and I did turn it right off after no more than 5 seconds of it being on.
                  Q2 removed and we still got the 1.2v so it seems like it may not be related to the signal path.
                    OK, you did not damaged anything.
                    So you will have to some how find out where that 1.2V is coming from, it is going to be time consuming but we need to find it.
                    Other trick that may be used is to find an active pin that goes high and stay high when power switch is turned on and goes low when power switch is tuned off and use that as the PS-ON signal source.
                    I hate to replace the main board if is due to just a bad switching transistor some where.
                    So none of those 4 transistor E-B Voltage change state when TV is turned ON and OFF?
                    • Nick's Tvs
                      • Jan 2014
                      • 621
                      Nope huge edit
                      So with it out of circuit, I get the same voltage on that collector pin, but in this post that I just deleted and am editing, I said all voltages stay the same whether the power button is turned on or not. That was a mistake. All voltages on all of those transistors drop to 0 when I press the power button.
                        I am confused now.
                        • Nick's Tvs
                          • Jan 2014
                          • 621
                          Sorry budm, I had a big work day yesterday until 3:00AM and a pretty big day today as well so I am not thinking properly. I am done for the weekend and will get back to the shop monday so that we can start fresh. Sorry. Thank you for helping as well.
                          -Nick
                          • Nick's Tvs
                            • Jan 2014
                            • 621
                            Ok I am ready to tackle this guy again. So this time with a resistor in place, I am still able to get the tv to turn on and show proper video so no damage done. Same thing I only let it stay on for about 5 seconds and then shut it off after I could tell the tv was on with logo and all. However I obviously have to force on the set for it to come on.
                            Back to the last post.
                            When I first plug in the set, all voltages on transistors Q1 Q2 Q5 Q7 are all at 0v on all legs. Once the set is turned on, they go to the voltages posted earlier. After pressing the power button again they drop back to 0vdc.
                            Now in an earlier post you had stated
                            "find a pin that goes high and stays high when power switch is turned on and goes low when power switch is tuned off and use that as the PS-ON signal source."
                            So are you talking about a 3.3v line and just shorting the PS-ON line to that? Or do you mean use it to back track to other components?
                            Sorry for taking so long on this one, but thanks for sticking with it. Very much appreciated!
                              OK, just to be clear on the Q5 Collector DCV reading when the TV is off, it is at 0VDC and when the power switch is turned on then the Q5 Collector DCV goes up to 3.2V as indicate in post 23. Correct?
                              • Nick's Tvs
                                • Jan 2014
                                • 621
                                Yes that is correct. Just rechecked right now.
                                  OK, remove the force on resistor you have on the PS-ON wire, then connect one end of 1K resistor to the Collector of Q5, the other end of resistor will be connected to that PS-ON wire, what we are doing is to use the Collector Voltage of Q5 as the PS-ON signal to turn on the power supply.
                                  • Nick's Tvs
                                    • Jan 2014
                                    • 621
                                    Sorry had to wait for the iron to get hot to solder a wire to the resistor. But yeah it works as if the tv was working normally.
                                    Where do you think we should go from here?
                                      The hardest problem right now is to locate the path of that PS-ON pin signal line to where it goes to, you may ending up spending lots of time trying to locate the connections or use it as is with this mod for now, at least the power supply will go into OFF mode when TV is turned off instead of being on all the time using the force on resistor.
                                      • Nick's Tvs
                                        • Jan 2014
                                        • 621
                                        would it be safe to use with the mod? How long would that last?
                                          The mod should work fine and we barely drawing any current through the Collector resistor, only about additional 3mA.
                                          Since one function of the board already failed, then it have some other section that may fail later on, I would it until it dies before spending the money on new main board.
                                          You have already verify ALL the TV functions work, right?
                                          • Capacitorial
                                            Powersupply has all the voltages - Monitor still no power
                                            by Capacitorial
                                            Hello guys,
                                            I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                            I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                            On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                            The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                            The weird thing is, that the Power LED is powered over the TCON board.
                                            On The TCON...
                                            12-28-2024, 02:12 PM
                                          • triplefour
                                            General question about LVDS voltages. Blank Backlit Screen.
                                            by triplefour
                                            im trying to understand how mainboards send data to tcons and tcons send data to panel boards and how panel boards control the panel itself.
                                            but starting at the beginning: if i have a tv with symptom: blank backlit screen, i want to verify if the mainboard is functioning properly first. its easy to see if its sending 12v to the tcon...but im pretty foggy on what the other lines of the LVDS connector should have on them.
                                            and also should they have the same voltages on them regardless of if the t-con is connected?
                                            and also how do you probe these pins easily? they are...
                                            12-18-2022, 02:45 AM
                                          • gjgib
                                            Help reading schematic voltages input/output
                                            by gjgib
                                            Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
                                            I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
                                            I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
                                            I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
                                            05-06-2024, 08:11 PM
                                          • RossMoodley1967
                                            HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
                                            by RossMoodley1967
                                            Hello
                                            Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
                                            Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
                                            03-01-2024, 06:07 AM
                                          • karlp028
                                            MSI Z390-A PRO missing VCORE voltages
                                            by karlp028
                                            I've got an MSI Z390-A Pro motherboard that starts up fine, but it's missing the VCORE (and VGT) voltages. All of the other voltages are present (e.g. VCCSA, VCCIO) and I know the CPU (i7-9700k) is good. Now, the original PWM controller (UP9521P) had an internal short and I replaced it with a new one. All of the enable signals look good. The problem seems to be the PWM signals going to the MOSFET drivers. I checked them with an oscilloscope and they are all flat 1.5V with no pulses. I don't know why this would be and I'm not sure where to look next.
                                            06-23-2025, 01:25 AM
