LG 60PS80-UA Plasma: All HDMI Inputs Show "No Signal"
  • DelawareGuy
    • May 2014
    • 17
    Re: LG 60PS80-UA Plasma: All HDMI Inputs Show "No Signal"
    tom66 & other awesome Badcaps gurus:
    10 months after successfully replacing the main board on this LG 60PS80 the blue streaks are back (another issue fixed by replacing the main board in addition to the HDMI input problem listed above).
    I don't mind (too much!) replacing the board again, but is there something else that could be causing the main board to fail in this manner?
    Thanks for your thoughts and comments.
    Also - tom66 -- you published a list of brands in order of quality, etc. once upon a time... Do you have a link to that? Just in case I have to pull the trigger on a new unit.
    Thanks and God bless you,
    D. R.
    • Eddiekaes
      • Jan 2017
      • 3
      Good morning. This above thread is the closest thread I've seen regarding my problem. I got into the service menu ok, but I'm afraid I did something wrong once inside. My TV does start up but I get no picture whatsoever. The screen is on and dark gray. I'm hoping I didn't turn it into a brick. I Can't access any menu. I have a LG60ps80-ua. Any help in resetting it?
      • ictc
        Philips MDP 3380/12 Blu-ray Player – No Power, Reset Signal Always High
        by ictc
        I'm troubleshooting a Philips MDP 3380/12 Blu-ray player that shows no signs of life. The display remains off, and no buttons respond.
        Inside, the power supply is working correctly, and all expected voltages on the mainboard match the service manual specifications. The CPU warms up slightly (checked with a thermal camera), the crystal oscillator is functioning, but the reset signal remains high at all times.
        The reset circuit appears to consist of two NPN transistors, one driven by 5V VCC and the other by 3.3V STBY, as shown in the attached schematic. Should the reset...
        02-25-2025, 12:15 PM
      • CoinCoin88
        Garage door RX unit (Cardin S38C) does not short relay to send opening signal
        by CoinCoin88
        I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
        Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
        09-15-2025, 03:36 AM
      • ktmmotocross
        Lenovo T61 Fan working, Q81 makes FAN_FRQ signal, but system still show FAN ERROR
        by ktmmotocross
        Hello.
        Have this old Lenovo T61 that shows FAN ERROR, but Fan working, sensing works, Q81 makes FAN_FRQ signal, but system still show FAN ERROR
        any hint?
        05-01-2023, 12:41 AM
      • MasterCap
        AVR-2802 no audio, chip questions
        by MasterCap
        I do some hobby repairs mainly of my own junk, and I don't know much programming level repair/mods.
        I got the AVR-2802 over the weekend, sold as working of course, and it worked for 1 night, using EXT. IN 5.1CH jacks, then after power down, the audio never came back. I've reset it, and get nothing on EXT IN or PHONO, despite having everything set right, hooked up right. I can hear lots of relays work tho.
        I just want it for 5.1CH analog inputs , for PC surround sound. I'm not worried about the video or most of the digital stuff for now.
        So far I've traced...
        01-15-2024, 10:52 PM
      • howardc64
        Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
        by howardc64
        Failure Symptom
        No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
        Where is the short?
        Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
        Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
        05-27-2025, 02:56 PM
