Sansui LCD does not power on
  • vusi
    • Jan 2015
    • 9
    • South Africa
    Hi friends
    i have been fixing a Sansui LCD TV (model SV3220) that did not not power on, first i repaired the power supply(200-P00-HM150h): checked the FETs, caps, transistors, diodes, resistors, and all the transformers, was a bit of a job, i replaced on cap that feed the inverter transformer. i can measure 5v stb on one of the supply rails, and the FET that drive the inverter transfomers read 141v on the drain, and i can find 22v in one of the lines, to me it looks like all is fine. but if i put it back to the set it does not work can it be the main board how do i establish if it is the main board, please help.
  • CapLeaker
    Leaking Member
    • 7971
    Re: Sansui LCD does not power on
    can you make a hi res picture of the power supply and the main board? This one is to small, I can't see anything. Also on the power supply make another picture of the pin outs that go to the main board.
    To test the power supply, you know already that the standby voltage 5V is already there. Now we have to figure out the rest. If you unhook the main board from the power supply and force the power supply on with some jumper resistors (1k ohm), and another jumper from BLON to 5V, should power up all of the power supply.
    • vusi
      • Jan 2015
      • 9
      • South Africa
      Thanks CapLeaker . please see from the pics, the problem is i cant figure out from the pins how to force this power supply on because i cant see any power on or relay on please check the pin outs
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Firstly replace all the caps on the psu as they are the type to go bad with out bulging and can cause the psu not to start, I worked in one of these Ipos150s with the same symptoms repaired it by replacing every cap on the psu with high quality panasonics try that first.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Note the primary cap will look bulged but its just the top casing thats domed the cap probably isnt, its the same on all these models.
          • vusi
            • Jan 2015
            • 9
            • South Africa
            what do you say about the 141v on the drain of the 2mosfet feeding the two inverters and the 22v to feed the audio and video circuits? Those must appear on the pin outs when the main board is activated, do i miss a point now i have a headache my friends
            • vusi
              • Jan 2015
              • 9
              • South Africa
              Primary Cap is ok and it has the correct voltage across it and it holds the voltage proof for not being leaky
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Im saying replace the all the other smaller capacitors on the board as some of them may be bad and will cause the psu not to start.
                From my photo you can see that on the board I worled on I replaced all the capacitors.
                • CapLeaker
                  Leaking Member
                  • 7971
                  I see now that you power supply has the inverter for the back lights on board. Thus there is no BLON pin. The 5VSB should always have 5v, regardless if power supply on or off. The STB pin should be the same as PSON. So if you jumper 5VSB to STB with a 1k ohm resistor, the power supply should turn on all the rest of the voltages on that connector.
                    It still needs BL_ON signal, PS_ON on turns on the PFC and the rest of the power supply to run the inverter circuits but the inverter circuit still needs to be turned on, this BL_ON signal is on the connector to the left of the big connector with pin labeled as BK_ON for BacKlights ON.
                    https://www.badcaps.net/forum/attach...3&d=1420747563
                    Common failure on this board is the failed 10uF 450VDC caps next to the inverter transformer.
                    BTW: "and the FET that drive the inverter transfomers read 141v on the drain" What did you use as the GND ref for the meter probe, the chassis? If that is the case, the measurement is invalid.
                    The DCV on the main filter cap should be around 330VDC and it should jump up to >360VDC when the power switch is activated and the main board sends the PS_ON (stby in this case) to turn on the PFC Voltage booster circuit which the Inverter drive section needs to run.
                    When making measurement in the primary side of the board you MUST use the Negative leg of the main filter cap as the GND ref point for you meter.
                    • vusi
                      • Jan 2015
                      • 9
                      • South Africa
                      Thanks for the advice and i really appreciate, i just want to mention that i did try to force the power supply on by putting a jumper between the 5stb and the
                      Stb pin but there was no success. today i will start all over again. i will change the caps and replace with a very reliable brand, can anyone make a suggestion for a reliable brand. what must i use as reference when testing the drain of the mosfets inorder to get a reliable reading?
                      • selldoor
                        Slow Learner
                        • 7870
                        It will depend on what you can get where you live?
                        If possible panasonic FR FM and FC series or Nichicon and Rubycon equivalents. Check the physical size to make sure they will fit. Probably best not not buy from ebay - many fakes about.
                          "i did try to force the power supply on by putting a jumper between the 5stb and the
                          Stb pin but there was no success" Did you remove the wire going back to the main board first? If it is still connected then the main board will keep that line low and you can also damage the switched transistor on the main board.
                          • vusi
                            • Jan 2015
                            • 9
                            • South Africa
                            "Did you remove the wire going back to the main board first? If it is still connected then the main board will keep that line low and you can also damage the switched transistor on the main board."
                            yes i did remove the main-board connectors when i tried to force the power supply on, right now i am waiting for the new caps i ordered and will go over the whole process again, i hope for the best now.
                            what can i use as reference to test the drain voltage of the mosfets? i heard that if i use the chassis as reference it will be unreliable.
                            • Ltank
                              • Jun 2013
                              • 776
                              I worked on a different Sanusi Tv yesterday. They are difficult to find boards bit the P.S. looks exactly like it's from a Sanyo Tv
                                OK, you need to get the PFC Voltage booster circuit to work first, so with force on applied, you must verify that you do have >360VDC RIGHT AT THE TWO LEGS OF THE MAIN FILTER CAP. The inverter circuits needs that Voltage to run, this MEGMMET POWER supply is known for having two bad 10uF 459VDC caps in the inverter section.
                                  by sam_sam_sam
                                  03-31-2024, 02:12 PM
                                  by sam_sam_sam
                                  07-01-2024, 06:34 AM
                                • JimBanville
                                  Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                  by JimBanville
                                  The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                  Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                  I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                  I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                  09-13-2023, 07:21 AM
                                • Dani_2024
                                  by Dani_2024
                                  10-28-2024, 05:06 PM
