Another Samsung Another Audio-But-No-Display Issue
  • Michale32086
    • Nov 2011
    • 1453
    Re: Another Samsung Another Audio-But-No-Display Issue
    Originally posted by budm
    May be its time to get Cap meter that can do capacitance and ESR testing if you are going to do more repair works.
    Abso-tively!!
    Thanx for getting me to this point.. Very much appreciated...
    • Michale32086
      • Nov 2011
      • 1453
      I'd be replacing it anyway...
      Yea, it looks a little wanky...
        This cap should work:
        http://www.digikey.com/product-detai...202-ND/1981474
        Or:
        http://www.digikey.com/product-detai...737-ND/3878307
        • Michale32086
          • Nov 2011
          • 1453
          Awesome.. Thanx BudM.. I need to place a DigiKey order anyways, so I'll just add that..
          I'll followup and advise if this fixes the unit..
          Thanx again..
          • Michale32086
            • Nov 2011
            • 1453
            Nice ta get a win every now and again!!
            I was going thru some old boards and found a comparable .47uf Poly cap.... The voltage was a bit lower, but I figured for testing purposes.....
            Hooked it in and the unit came up nice as you please!!
            Get the right ones ordered from DigiKey and replace the test one...
            It's good to know that it's just that one little part and not the whole board or even worse.. The display!!!
            Time ta throw a few into the BadCaps' kitty...
            Thanx again for the assist!! VERY much appreciated.
            • Michale32086
              • Nov 2011
              • 1453
              Could you recommend an inexpensive cap meter???
              Thanx
              • zomi
                • Nov 2011
                • 509
                #27
                A reasonably priced meter is DER EE DE-5000 just have a look on ebay for it
                runs about $90 or so.
                • Michale32086
                  • Nov 2011
                  • 1453
                  Thanx for the info, zomi.. I'll check it out... Although my cash flow took a hit with the recent Rigol purchase...
                    EEVblog on DER EE DE-5000
                    https://www.youtube.com/watch?v=ji-UT7HJm0Q
                    • Michale32086
                      • Nov 2011
                      • 1453
                      I love that guy!!!!
                      • tom thumb
                        • Jul 2013
                        • 66
                        add another one fixed same problem same cap c1818 works great now
                        • DXseekerMO
                          • Feb 2018
                          • 1119
                          • US
                          #32
                          I thought that PSU looked familiar. I had an LN52C530S1FXZA (similar) with that exact same cap, with that exact same bulge, replaced the cap and it worked like a charm! That C530 of mine even picked up CIII in Bancroft, Ontario CA and a whole host of other TV stations both analog and digital up and down the east coast, Cuba, the Dominican Republic, Miami, Las Vegas and Rapid City SD this year during E-Skip season.
                          I am in southwest Missouri BTW
                          They call me......."threadkiller"
                          • Kjell
                            Samsung Series 9 - BIOS issue
                            by Kjell
                            After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                            Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                            08-01-2025, 09:15 AM
                            09-07-2024, 05:50 AM
                          • Nairolf
                            Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                            by Nairolf
                            I have a Samsung DM32D display.
                            When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                            Here’s what I have tried so far:
                            1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                            2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                            3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                            From these tests, I suspect the problem might be on the mainboard. Could anyone...
                            08-24-2025, 03:47 AM
                          • vincentedel
                            Samsung SyncMaster 740n Phase Control Issue
                            by vincentedel
                            I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                            I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                            04-22-2025, 12:33 AM
                          • Manucsl
                            QE65Q800TATXXC Samsung TV Issue
                            by Manucsl
                            Hello.
                            My TV is a QE65Q800TATXXC Samsung TV.
                            Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                            Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                            Any ideas to check would be very appreciated 😊
                            After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                            02-19-2025, 07:47 AM
