SAMSUNG -LE37A450C2 Bad Pic.
  • Stanislav
    • Dec 2012
    • 135
    • Bulgaria
    Re: SAMSUNG -LE37A450C2 Bad Pic.
    1-0,1745
    2-1.64
    6-1,72
    7-1,84
    8-5,15
    10-5,68
    11-5,9
    12-7,1
    13-7,3
    15-6,75
    16-6,5
    17-4,8
    21-4,48
    22- 3,95
      The results confirm the "AS15" gamma chip on your board is bad. It is under one of the square yellow pads. If you have the equipment you can replace it (the chip is a few dollars), otherwise you can replace the whole board (can be expensive due to high demand though) and the problem should be resolved
      • Stanislav
        • Dec 2012
        • 135
        • Bulgaria
        Tom thank you
        unfortunately I do not have such equipment,everything I do is save from garbage another TV.
        will look for new board and will write again
        • Stanislav
          • Dec 2012
          • 135
          • Bulgaria
          Hi Tom
          I found AS15F only I decided to try to change it
          I downloaded grossly old (of course without damage to the circuit board)
          Then install the new
          Finally everything works. Thank you my friend
          • CapLeaker
            Leaking Member
            • 8351
            thanks for the follow up!
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4535
              • Italy - Milan
              #26
              Stanislav do you tell me how one can evaluate a defect with a miniature picture of screen??
              Tom66: is there any other posts that explains here how can evaluate the goodness of the vgamma voltages?
              • selldoor
                Slow Learner
                • 7870
                #27
                Well Tom obviously did?
                See here might help
                https://www.badcaps.net/forum/showth...ighlight=gamma
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4535
                  • Italy - Milan
                  #28
                  i don't understand Selldoor, is for me the comment?
                  ok now i watch the link , good, thanks..
                  • Smuggler
                    • Sep 2012
                    • Uk
                    #29
                    I'm just trying to understand the procedure. Could I just ask how the conclusion of those voltages being bad was reached? I've just looked at datasheet and can't tell what those voltages should be? Or maybe i'm missing something?
                      09-07-2024, 05:50 AM
                    • TR103
                      by TR103
                      - it keeps rebooting
                      01-22-2025, 04:12 PM
                    • JJAAMM
                      by JJAAMM
                      Problem
                      07-06-2023, 06:01 AM
                    • Mgiffune
                      by Mgiffune
                      06-09-2024, 10:28 AM
                    • Dodgethis
                      Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                      by Dodgethis
                      Hello all,
                      This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                      09-11-2024, 07:39 AM
