Panasonic LCD TV turns off after few seconds! HELP
Re: Panasonic LCD TV turns off after few seconds! HELP
I have a feeling since you swapped the CCFL connectors (No.1) around and the dark area remained in the same postion then it may be defective CCFL tubes which are part of the panel assembly.Comment
Hy, in repairshop they said that its the bad main board, i have a filling that its not. So my question is, if i completly disconnect ccfl inverter and tv still doesnt stay turned on, it can be bad ccfl anyway? thanks!Comment
The picture issue is not the main board. However if the backlight board is disconnected the TV should stay on and you should see something while shining a flashlight into the screen. You can also try to disconnect the backlight and the tcon board and see if it stays powered up.Comment
Hy, it was the backlight problem, plastic behind backlight line was broken, so spark was jumping from + to ground on backplate.The picture issue is not the main board. However if the backlight board is disconnected the TV should stay on and you should see something while shining a flashlight into the screen. You can also try to disconnect the backlight and the tcon board and see if it stays powered up.
But now i have even bigger problem :SSS
I pulled some part out of upper layer of display :S
Can i do something to fix it? here are the pictures
Please help, i feel like shit right now :S
Thank youAttached Filesif you find these attachements useful please consider making a small donation to the site
That's a tab bond from the lcd display. Not repairable.Comment
i resolved problem, PLS remove BD9897fs protectio mode. i put on 17pin diode on ground ant TV work good.
http://english.electronica-pt.com/lcd-repair?p=bd9897fs
https://cdn.badcaps-static.com/pdfs/...a70699e3c8.pdfComment
That is not a fixed, that is bypassing the safety shutdown circuit.i resolved problem, PLS remove BD9897fs protectio mode. i put on 17pin diode on ground ant TV work good.
https://cdn.badcaps-static.com/pdfs/...a70699e3c8.pdfAttached Filesif you find these attachements useful please consider making a small donation to the site
by zklgfsHi,
I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...-
08-11-2025, 02:14 PM -
by PanasTCPanasonic TC-60CX800U with Power board: TNPA6060 1P
The TV starts, the LED lights blink for 2 seconds, and the TV turns off; I tested the voltages on the powerboard, and it looks ok.
Also, I could see HDM in the top corner for a second.
Is it possible that the issue is a bad LED light that forces the TV to turn off? -
by twonk9098Hi all,
I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
I have tried a few new bios but exactly... -
by Rick_1234Good evening, gentlemen.
I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
https://drive.google.com/file/d/1L6S...ew?usp=sharing
Things I tried
- Bought a new AC adapter thinking that was the problem but the problem...-
by riko 656Hello everyone,
I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
Laptop Model:- Model: Lenovo Legion Slim 5 16APH8
- GPU: NVIDIA GeForce RTX 4070
- Main BIOS chip size: 32MB
- VBIOS chip size: 16MB
What I Have Tried So Far:- I
11-04-2025, 05:14 AM - Loading...
