As the title says, I picked up a 42" tcp42c1 with a 1 blink fault today. It looks like the a board is the fault. There are repair services available. Anyone have any insight to what the repair may be?
Looking for info on repairing Panasonic TNPH0800 A Board. TC-P42C1 1 Blink.
Tags: None
Re: Looking for info on repairing Panasonic TNPH0800 A Board. TC-P42C1 1 Blink.
My only experience with 1 blink and I discovered this by accident was on what would be your equivalent p42C2 and that was a corrupt / faulty eeprom which I believe was the panel data.
I'm sure it could probably be a number of things but that's all I got. -
The service manual can be downloaded from Tom's website, but it does not give any usefull information on 1 blink:
No particular check point
Panel status
STB 5V SENSE time out
Do you hear any relays click in the power supply?Comment
There's a relay click at power on. The LED goes solid. Then the relay clicks again and the LED starts flashing.Comment
When you found the corrupted eeprom, how did you remedy the situation?Comment
Ordered an OEM from panasonic parts supplier. This model A board of yours does seem to pop up time to time with 1 blink. Does make me wonder if it's going to be eeprom or I thought some time ago someone suggested a bad ceramic cap on an A board but I can't remember enough as to what model. i wish i could to dig up the post.Comment
Thanks for the info. I'll do some digging. At least I have a place to start.Comment
Tri-State Module had this board for $90 with an additional 10% off and free shipping. New board installed and the set is back to working. I found this one in a dumpster with the base, power cord, and remote.Comment
Just a follow up here in case someone sees a 1 blink error code, but I did fine a short on two capacitors on the top left side of the board. Unfortunately there is no location number for those caps. They are just below and to the left of the IC9806. I removed them out of circuit, and tested them again and no shorts. I tested the circuit itself with both caps removed and the short was still there. I then removed the mentioned IC9806 and checked for shorts again. Shorts were once again still there. I checked the other parts near it and couldn't find the source of the short. Not sure what is the source of the short but there is one there.Comment
by clooI recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
After doing a factory reset this problem was gone and the picture was back to...01-06-2025, 06:02 AM -
by VebririonHi everyone,
I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report... -
by nervxYears ago my tv gave a 7 blink code which turned into 8 during diagnosis. I had ordered a replacement ss board but somehow the tv started working again and i never used the board. Now a week ago my tv flickered and shut off at random and gave the 8 blink error code. The same issue it had all those years ago. The only difference this time is that over the last few months there has been some purple and green tinge that comes and goes in more solid colors such as white.
Anyway i checked all the screws and replaced the ss board with a known good one and still got 8 blinks. I saw a... -
by SentraDudeGreetings from SoCal
I am new to this forum but not new to forum world. I come from Automotive end of side which is my main passion in life. Give the automotive nature, I love fixing and restoring things and I have in the past fixed many simple electronics, soldering, etc.. but this is a bit more involved so I found this forum, and I am very glad I did.
I picked up a Panasonic TC-P60VT60 with the 7 BLINK error.
Upon removing the back plate I found spider webs, dead spiders, and an amazing amount of dust. I did my best to clean the surface of the boards with a portable vacuum... -
by BigPeteI picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
Unfortunately the whole machine has to come apart to fix it.
I have... - Loading...
