Lg lcd flickering screen after 15 mins help
  • johnjgjohn
    • Sep 2013
    • 87
    • scotland
    Hello all merry xmas
    Ive got an lg lcd when i power up everything works as normal for the first 15-20 mi s then the screen starts to flicker or pixelate ive checked for bulged caps and checked ribbon cables but not sure were to go from here ive got a video can it be uploaded here? Then u can see what its doing it gets worse the longer its on
    Thanks for any help
    • 12210
    • U.S.
    Re: Lg lcd flickering screen after 15 mins help
    can you post good clear pics. of each of the boards, and one of how they are all connected, what is the model number?, use caution when working with power supply HIGH VOLTAGE on primary side.
    • Ltank
      • Jun 2013
      • 776
      Check P.S. voltages on P.S. accoring to silkscreen legend near connectors. 24vdc to inverters should be stable. check backlight on command , PS-on, standby voltage then tell us what you have. Also check the larger capacitors on the inverter boards that power the backlight bulbs. Use a DVM with negative (black0 lead) on chasis gnd
      • johnjgjohn
        • Sep 2013
        • 87
        • scotland
        The model no is 37lc55-za
        • johnjgjohn
          • Sep 2013
          • 87
          • scotland
          Here is some pics
          • johnjgjohn
            • Sep 2013
            • 87
            • scotland
            Close up of psu
            • freakaftr8
              • Oct 2012
              • 3743
              take the power supply off the TV and check for cold solder joints on the transformer the main inverter transformer the one on the top right
              • johnjgjohn
                • Sep 2013
                • 87
                • scotland
                Surely if it was the inverter then i would loose backlight? I tried upload a vid but was taking like 20 mins from my fne then i cancelled it the backlight doesnt flicker or go out its just pixelated like when u have a bad signal on freeview the picture gets lines through it
                • freakaftr8
                  • Oct 2012
                  • 3743
                  sorry missed that part yes it does sound like a main board problem. is it doing this on all inputs or just one?
                  • johnjgjohn
                    • Sep 2013
                    • 87
                    • scotland
                    Ive checked all voltages they all seem to be what is stated and are all stable
                    • johnjgjohn
                      • Sep 2013
                      • 87
                      • scotland
                      Doing it on all inputs when i first turn it on it works fine for about 20 mins then starts flickering a little but gets worse as time goes so must be heat related
                      • johnjgjohn
                        • Sep 2013
                        • 87
                        • scotland
                        Here is a video of what its doing http://youtu.be/hkgiG7O7Jm0
                        • johnjgjohn
                          • Sep 2013
                          • 87
                          • scotland
                          Does anyone know what would cause this have a look at the video above thanks
                          • Ado02
                            Lenovo Thinkpad X1 Gen 10 - Flickering Screen
                            by Ado02
                            We recently replaced the OLED screen on a Lenovo ThinkPad X1 Gen 10. After about a month, the replacement screen began to flicker. Initially, updating the IntelĀ® IrisĀ® Xe graphics driver resolved the issue for about a week. However, when the problem recurred, updating the driver again had no effect.
                            The flickering only occurs once the system reaches the Windows login screen. Interestingly, if we disable the Intel GPU driver or connect the laptop to an external monitor, the flickering stops. We have tried installing two different replacement screens,...
                            12-16-2024, 02:33 PM
                          • Ryan.man
                            by Ryan.man
                            02-04-2025, 12:23 PM
                          • reformatt
                            by reformatt
                            07-31-2025, 08:37 PM
                          • survivalbloke
                            HP ENVY HP 13-aq1013dx - screen flickering black if using touchpad or external mouse
                            by survivalbloke
                            SN: 8CG0213H8W
                            ProdID 3C311UA
                            This device came in due to the screen flickering if you use the touchpad or external mouse. It will flicker black when this occurs. If you use the touchscreen, the behavior does not appear. Also, if connected to external monitor, the external monitor is not affected by the flickering. I did a good amount of research on this, and concluded that it is due to the display driver. HP does not offer Windows 11 drivers for this model so I got the replacement drivers direct from Intel. I installed them and the problem...
                            05-08-2025, 12:21 PM
                          • smic717394
                            by smic717394
                            07-25-2024, 10:16 AM
