Sony KDL-55HX820 5 red blinks
  • Clutchbox
    Cap Clutcher
    • Sep 2011
    • 41
    • The Netherlands
    Re: Sony KDL-55HX820 5 red blinks
    Originally posted by ntehicks
    I just Picked up this TV. I would really like to fix it. I turn it on and get 5 red blinks. I understand this error means T-Con but I was also told it could be a panel. I will take some pictures when I get the back off and post them as well.
    I see at your first startpost after opening of the TV, that the connector on the T-con (from the cable between mainboard and T-con) is not seated correctly. Such a thing could just give you the '5-blink T-con' Error from the start.
    Was that picture taken when you first opened the TV?
    • ntehicks
      • Mar 2011
      • 272
      I think I have removed and reseated the Cable between the mainboard and the T-con but when I get home tonight I will double check this again.
      I have tested several fuses on the main board and they are all testing good. where should I test?
      • Sevenqi
        • Jul 2011
        • 292
        I fixed a kdl-46hx820 same error code, what I did was to unplug the cable fron main board to t-con, press the power button, it could turn on, then power off, connect back the cable, tv worked again.
        This is not a way to fix tv, but it's simple and worth a try.
        • ntehicks
          • Mar 2011
          • 272
          I will try that as well and see what happens.
          • ntehicks
            • Mar 2011
            • 272
            Ok tonight I came home and disconnected the cable between the T-con and main board. I plugged in the TV and the standby light came on. I then pressed the power button and the standby light went out. I pressed the power button again and it went green for half a second and then red 5 blinks pause red 5 blinks over and over.
              • 12206
              • U.S.
              #26
              heres a question, does both of your power supply boards give you the 10.8 volts where you should have 12 volts?
              • ntehicks
                • Mar 2011
                • 272
                I will test both of them when I get home tonight just to double check. I have purchased both power boards and tested with them and I get the same results. I have a new main board coming.
                • ntehicks
                  • Mar 2011
                  • 272
                  ok so this tv has a vacation switch. so when I plug in the TV and then turn on the vacation switch while having my meter connected to the power supplies 12v I get 12.7 volts for about a second and then it drops to 10.7. This is while the tv is in standby so before I hit the power on. Then when I hit the power on button the 10.7 jumps back up to 12.7 for 1 second and then drops to 0. this is when the TV starts to blink for 5 times.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    If I remember well, there it should be a shorted special VDO near the PS connector.
                    After replacing that, I had to replace the mainboard too. Wrong voltage, damaged something on the mainboard.
                    • ntehicks
                      • Mar 2011
                      • 272
                      are you talking on the power supply board or on the main board? do you know what the part should look like?
                      • tibimakai
                        • Jan 2012
                        • 3680
                        On mine(different model though-55EX720), it was on the power supply. It was a 5 pin voltage regulator.
                        • ntehicks
                          • Mar 2011
                          • 272
                          so the last board that the service manual suspects is a very small board. the HLT2 board or other words the IR board. part numbers 1-732-388-11 or 1-883-757-11. I have looked for this board and don't know if I will find one. If I can find one I will purchase and install and see if that resolves anything.
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            Make sure the ribbon cable going from the main board to tcon is OK where the plastic clip holds it to the main board. I have seen the ribbon cable get pulled from the plastic retainer clip before and caused damage to the cable.
                            • ntehicks
                              • Mar 2011
                              • 272
                              Well this one is going to go. I have replaced all of the power supply and main board. tested voltages and still no go. so I am sending this one packing.
                              • ALittlebit
                                • Feb 2015
                                • 51
                                • United states
                                #35
                                Hey every one did we ever find a cure for this annoying 5 blinks issue?! I got mine from a pal and he said he changed main, and PS, and still got nothing better as results. I was thinking tcon board seeing how he never replaced that one. But who is to say he didn't get a bad main or ps off line. So anything helps thank you guys!
                                • thelankanguy
                                  Sony KD-55X9000F TCON Issue
                                  by thelankanguy
                                  The TV shows a black screen with no image.
                                  TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                  Later both ribbons were disconnected and TCON voltages were tested.
                                  12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                  There is also a short to ground in this circled inductor.
                                  Is this a TCON issue or something else ?...
                                  12-13-2024, 12:27 AM
                                • bbrain
                                  Sony KD-55AG9 TCON?
                                  by bbrain
                                  I have this problem with my Sony 55' AG9.
                                  It flashes 4x.
                                  I have found the service manual, and seems it is the TCON.
                                  Before I buy a TCON can someone check the vid?
                                  Thanks in advance!...
                                  09-19-2024, 10:50 AM
                                • Nicktronic
                                  Sony XBR-65X850D 2 Red Blinks
                                  by Nicktronic
                                  I have the subject TV and it will work normally sometimes but suddenly go black and give the 2 red blinks blink code. When this happens, I check the power supply board voltages and all I have is the Standby 3.3V and BL_ERR 2.2V. When it's working normally, all power supply board voltages look normal and stable. I've checked the backlights with a tester and they all test good. I've also read that the 2 red blinks is a faulty power supply board, so could it be throwing up an erroneous BL_ERR?
                                  Any Sony experts out there that can help??...
                                  11-19-2023, 06:51 AM
                                • rimwall
                                  Sony KD-65x8500b - bad Tcon or panel?
                                  by rimwall
                                  Hi, hoping for some views on this one which I've not come across before. The TV generates an image that has 12 noticeable bands across it. The image is still there and accurate, but the colour (or perhaps the brightness) changes gradually across each band which creates a noticeable 'step change' at the edge of each band. Given it's a 4K TV with 2160 rows of pixels, I'm guessing the 12 bands correspond to 12 gate drivers of 180 rows each. If this guess is right, then perhaps:
                                  a) all the gate drivers are malfunctioning the same way (which seems unlikely), or
                                  b) the Tcon board is malfunctioning,...
                                  10-24-2023, 07:58 PM
                                • x_orange90_x
                                  TCL 50S535 bad tcon or panel issue?
                                  by x_orange90_x
                                  Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                  03-29-2025, 11:02 PM
