Sony KDL-55HX820 5 red blinks
  • Clutchbox
    Cap Clutcher
    • Sep 2011
    • 41
    • The Netherlands
    Re: Sony KDL-55HX820 5 red blinks
    Originally posted by ntehicks
    I just Picked up this TV. I would really like to fix it. I turn it on and get 5 red blinks. I understand this error means T-Con but I was also told it could be a panel. I will take some pictures when I get the back off and post them as well.
    I see at your first startpost after opening of the TV, that the connector on the T-con (from the cable between mainboard and T-con) is not seated correctly. Such a thing could just give you the '5-blink T-con' Error from the start.
    Was that picture taken when you first opened the TV?
    • ntehicks
      • Mar 2011
      • 272
      I think I have removed and reseated the Cable between the mainboard and the T-con but when I get home tonight I will double check this again.
      I have tested several fuses on the main board and they are all testing good. where should I test?
      • Sevenqi
        • Jul 2011
        • 292
        I fixed a kdl-46hx820 same error code, what I did was to unplug the cable fron main board to t-con, press the power button, it could turn on, then power off, connect back the cable, tv worked again.
        This is not a way to fix tv, but it's simple and worth a try.
        • ntehicks
          • Mar 2011
          • 272
          I will try that as well and see what happens.
          • ntehicks
            • Mar 2011
            • 272
            Ok tonight I came home and disconnected the cable between the T-con and main board. I plugged in the TV and the standby light came on. I then pressed the power button and the standby light went out. I pressed the power button again and it went green for half a second and then red 5 blinks pause red 5 blinks over and over.
              • 12330
              • U.S.
              #26
              heres a question, does both of your power supply boards give you the 10.8 volts where you should have 12 volts?
              • ntehicks
                • Mar 2011
                • 272
                I will test both of them when I get home tonight just to double check. I have purchased both power boards and tested with them and I get the same results. I have a new main board coming.
                • ntehicks
                  • Mar 2011
                  • 272
                  ok so this tv has a vacation switch. so when I plug in the TV and then turn on the vacation switch while having my meter connected to the power supplies 12v I get 12.7 volts for about a second and then it drops to 10.7. This is while the tv is in standby so before I hit the power on. Then when I hit the power on button the 10.7 jumps back up to 12.7 for 1 second and then drops to 0. this is when the TV starts to blink for 5 times.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    If I remember well, there it should be a shorted special VDO near the PS connector.
                    After replacing that, I had to replace the mainboard too. Wrong voltage, damaged something on the mainboard.
                    • ntehicks
                      • Mar 2011
                      • 272
                      are you talking on the power supply board or on the main board? do you know what the part should look like?
                      • tibimakai
                        • Jan 2012
                        • 3680
                        On mine(different model though-55EX720), it was on the power supply. It was a 5 pin voltage regulator.
                        • ntehicks
                          • Mar 2011
                          • 272
                          so the last board that the service manual suspects is a very small board. the HLT2 board or other words the IR board. part numbers 1-732-388-11 or 1-883-757-11. I have looked for this board and don't know if I will find one. If I can find one I will purchase and install and see if that resolves anything.
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            Make sure the ribbon cable going from the main board to tcon is OK where the plastic clip holds it to the main board. I have seen the ribbon cable get pulled from the plastic retainer clip before and caused damage to the cable.
                            • ntehicks
                              • Mar 2011
                              • 272
                              Well this one is going to go. I have replaced all of the power supply and main board. tested voltages and still no go. so I am sending this one packing.
                              • ALittlebit
                                • Feb 2015
                                • 51
                                • United states
                                #35
                                Hey every one did we ever find a cure for this annoying 5 blinks issue?! I got mine from a pal and he said he changed main, and PS, and still got nothing better as results. I was thinking tcon board seeing how he never replaced that one. But who is to say he didn't get a bad main or ps off line. So anything helps thank you guys!
                                • iglitare
                                  by iglitare
                                  09-04-2025, 07:13 AM
                                • rimwall
                                  Sony KD-65x7500D - double image - Tcon or Panel?
                                  by rimwall
                                  This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                  I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                  11-18-2025, 02:09 AM
                                • thelankanguy
                                  Sony KD-55X9000F TCON Issue
                                  by thelankanguy
                                  The TV shows a black screen with no image.
                                  TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                  Later both ribbons were disconnected and TCON voltages were tested.
                                  12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                  There is also a short to ground in this circled inductor.
                                  Is this a TCON issue or something else ?...
                                  12-13-2024, 12:27 AM
                                • GoodCapDude
                                  Sony XBR-75X940E intermittent 6 blinks error code
                                  by GoodCapDude
                                  Hi everyone. First post on Badcaps!
                                  I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                                  09-20-2025, 06:07 AM
                                • bbrain
                                  Sony KD-55AG9 TCON?
                                  by bbrain
                                  I have this problem with my Sony 55' AG9.
                                  It flashes 4x.
                                  I have found the service manual, and seems it is the TCON.
                                  Before I buy a TCON can someone check the vid?
                                  Thanks in advance!...
                                  09-19-2024, 10:50 AM
