Proscan 42la 45h low power supply voltage and no sound
  • pro_leonk
    • 22
    • US
    Greetings all,
    I picked up a 42" Proscan 42la 45h that was reported not to have sound. Upon inspection, it powered on and was buzzing really loud, video is good. I fixed the buzzing - it was the big 450v 150uf capacitor that was bad. Now I am able to hear some sound, but it is very faint on max volume and it is crackling. I did replace some capacitors on the power supply since I had them, but none of them did look bad(Replacements have line trough them diagonally). No improvements though.
    The power supply board is: (HLP-45A01 or RSAG7.820.968/ROH ver. H
    The main board is: E/RSAG7.820.997A Ver. D
    Troubleshooting done:
    With TV on, I get 24v as expected on the top right. I believe these are for video/ inverters. Half way down on the right side, i get good 12v, 5v, but where I am supposed to get 28v I only get 15.72v. I am a bit unsure about the 28v, as I thought there are only 5v, 12v, and 24v generally in TVs. The 28v is printed on the power supply board...
    There is no other obvious damage on the board or components
    See attached pictures.
    Glad to take more pictures in more detail or do troubleshooting steps.
  • mmartell
    • Oct 2013
    • 3189
    Re: Proscan 42la 45h low power supply voltage and no sound
    Does the 28v go to the mainboard ? If so it will explain why your audio is acting up.
    You may have more capacitors to replace yet.
    • pro_leonk
      • 22
      • US
      Yes, it does go to the main board.
      I am reading up more on the troubleshooting guides - could it be a voltage regulator that is acting up?
      • leggot
        • Oct 2014
        • 50
        It very well could be a voltage regulator, check all the voltages as they are likely culprits.
        • freakaftr8
          • Oct 2012
          • 3743
          Replace capacitor C809. 390mfd. Trust me.
          • pro_leonk
            • 22
            • US
            This one already got replaced, it was the first one. It had obvious damage and was leaking.
            Going to go over the voltage regulators one by one.
            • CapLeaker
              Leaking Member
              • 8226
              Disconnect the 28V on the main board and turn the power supply back on. Force it on, if you have to and check if the 28V are back. Maybe something is dragging the 28v line down on the main board.
              • pro_leonk
                • 22
                • US
                I did that and I get a minor improvement, now I get 16.96v instead of the 15.72v.
                  Can I see good clear picture of the bottom side of the that clearly show the traces?
                  As shown on the board, the label shows it has 28V output at 1A or 14V at 1.5A this output is not regulated, that is lots of power. I wonder if it is used for the Audio power amplifier circuits.
                  You should check the current draw on this output.
                  • pro_leonk
                    • 22
                    • US
                    Did some measuring on the voltage regulators (all on the cold side)
                    See bottom for more info
                    The next two are on the right side.
                    Center.
                    2576t-adj
                    RVA744 G
                    PIN 1 23.92v
                    PIN 2 12.13v
                    PIN 3 0v
                    PIN 4 1.19v
                    PIN 5 0v
                    Top
                    SP744
                    U1620G
                    AKA
                    PIN 1 0v
                    PIN 2 24.1v
                    PIN 3 0v
                    These are on the left side of the heatsink
                    Top
                    SP744
                    U1620G
                    AKA
                    PIN 1 0v
                    PIN 2 23.98v
                    PIN 3 0v
                    Center
                    SP744
                    U1620G
                    AKA
                    PIN 1 0v
                    PIN 2 16.96v
                    PIN 3 0v
                    Bottom
                    SRF1560
                    I will have to look up how to test that in more detail, appears to be a diode/ SCHOTTKY BARRIER RECTIFIER
                    The center left one seems to be very close to the voltage of the one where I am supposed to get 28v. This was the voltage with the main board (just where the 28v is plugged in is) disconnected. With it connected I got15.9v on the center pin. Appears that I narrowed down the issue a bit further.
                    At this point should I order a replacement part, or will I go down further the circuit and do more testing - like the resistors next to it, given that they are on the same circuit.
                    Cheers
                    • pro_leonk
                      • 22
                      • US
                      Here is the board for now. I will check the current draw tomorrow.
                        Thanks for the bottom view picture but I cannot tell which pins are which, I cannot see the pin labels on the top side of the board due to the cables are in the way. I am trying to see which winding of the transformer generates the 28V.
                        • CapLeaker
                          Leaking Member
                          • 8226
                          What part number is N811? Just to clarify to make sure it is the one that is supposed to make the 28V.
                          I think it is a MURF1620 ultra fast recovery diode. Did you take it out and check it with your diode tester?
                          both diodes (pin 1 and 3) should read the same (to common pin2).
                          Those are a pretty common rectifier
                          • CapLeaker
                            Leaking Member
                            • 8226
                            Back side of the board pic, right under the middle board mounting hole, the first 2 pins from top to bottom are the 28V, next two pins are GND.
                            • pro_leonk
                              • 22
                              • US
                              They are L807 (the larger top one) and L810 (the smaller bottom one)
                              • pro_leonk
                                • 22
                                • US
                                Hi, it is the 2576t-adj RVA744 G. Voltage readings are in the previous post. The
                                MURF1620 is VD812. I still have to test it out of circuit.
                                • CapLeaker
                                  Leaking Member
                                  • 8226
                                  uff... where did I get the MURF1620 from being in N811 spot? Dang... must have been asleep or something got cross-eyed ... lol
                                  • pro_leonk
                                    • 22
                                    • US
                                    Problem solved. I managed to fry something on the main board (the volume amplifier while testing there). Got a replacement board from eBay and the sound is back.
                                    Appears that the power supply was good, even tough the voltage seemed lower...
                                    Thanks for all your help. I learned a few things for future troubleshooting.
                                    • johnboy1313
                                      • Nov 2012
                                      • 1959
                                      Are you sure it wasn't a 250V 390uf cap? I just fixed the same set with the same power supply. Mine had a 259V 390uf big cap. Your picture definitely has a 390uf cap. I can't tell the voltage. I swapped that cap and the buzzing ceased.
                                      • pro_leonk
                                        • 22
                                        • US
                                        I did replace that cap because it was buzzing pretty loud, but it did not improve the sound issue that I had.
                                        I just looked at the pictures I posted, and yes, it is indeed a 250v 390uf (it was already replaced at the time of the picture) so I must have mixed it up with a other cap.
                                          Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
                                          by sam_sam_sam
                                          I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
                                          https://www.ebay.com/itm/116497313155?var=416785404161
                                          Here are some of the description from the eBay seller
                                          The main parameters:
                                          1. Product name: High-power non-isolated DC boost module power supply.
                                          2. Product model: 100A2000W.
                                          3. Input voltage: DC12V-60V.
                                          4. Input current: 100A (maximum)....
                                          05-18-2025, 09:45 AM
                                        • Jembang
                                          coocaa 50S5G smart tv dropped voltage when connecting power supply to mainboard
                                          by Jembang
                                          good day hoping someone can lend a hand, im repairing smart tv 50 inch, status when turning on back light is dim but you can see the tv logo then slowly fading out to black, i check the supply to tcon, i only read 5+v, must be 12v, i removed lvds cable and check voltage to mainboard turned on its also 5v, then i remove the cable mainboard to power supply, i read 12v in power supply, thinking that the problem is in the mainboard, coz theres 12v in power supply, i also check while turning on checking volts in main board 12v dropping to 5v, im just new repairing in TV, hope someone see my post t...
                                          11-01-2024, 09:55 AM
                                        • stylishconsultant
                                          un60j620dafxza - Samsung No Display Problem
                                          by stylishconsultant
                                          Hi All,
                                          Need help.
                                          I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                          So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                          problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                          might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                          09-04-2024, 03:26 AM
                                        • Andreas_de
                                          Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                          by Andreas_de
                                          Hello!
                                          i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                          Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                          Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                          04-12-2025, 10:38 AM
