I just replaced the HDMI chip on a Panasonic plasma. I will update the correct post when I have the board installed and working. I tried to make a video to document the procedure, but the camera didn't want to cooperate. I did manage to get some pics tho. It looks like there are no solder bridges. All pins appear to be attached to the appropriate pads. Enjoy.
My first 144 pin IC replacement with ChipQuik, success I hope
Tags: None
Re: My first 144 pin IC replacement with ChipQuik, success I hope
Good job! I wish i still have good eyes and steady hands.Never stop learning
Looks bang on .. well done.. I would have liked to see the video... Why dont you upload whatever you have?Comment
There's 16 seconds of me explaining what I was gonna do. I didn't even get to the flux or ChipQuik. There's really nothing to see.Comment
So what's the chipquick worth and where did you get it? last time I looked at my end it was very expensive and then i was worried of fakes?
So it stays molten long enough for 144 pins? So would it be a good choice for buffer ICs?Comment
With buffer ICs usually having a solder pad then hot air is the only viable option IMHO.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
I paid 12.99 with free shipping via eBay. It came with the flux and some alcohol wipes. It wouldn't work on a buffer IC. At least the one that I attempted had a pad on the bottom too.Comment
One of the Samsung repair briefs I read suggests you flow solder through the holes on the bottom of the board to get it to the bottom of the buffer ic. I have done both this and have used hot air with a bit of solder paste. In either case you are going on faith that the process was completed properly as of course you are flying blind.Comment
I do the final touch up to the pins with a fine soldering iron tip and candle wax as a flux. I find the candle wax stays on the pins for a long time allowing the joints to be reflowed as often as needed til they look right. It washes of with turps.Comment
I first saw this procedure done on the excellent Youtube Channel RetroGameModz
Excellent post... Was the repair a success, btw?Comment
Yes it was. That ChipQuik is amazing stuff.Comment
I have managed to replace a 144 pin micro controller in a Kenwood navigation unit as well, a little while ago. It came out very nice, specially it was the first time for me too.
I have removed it with hot air and re-soldered it, with the iron.
The repair it wasn't successful(yet), because I work blindly without help.
I have managed to replace a TSOP48 nand flash and revived my first Kenwood DNX6190HD nav unit and it's already soldComment
Not all that hard to make your own 'chip-quick' (Which IMHO is a complete Rip Off for what it is!)
Just get some Bismuth, Lead and Tin, alloy them together, and there you go, Low melting-point, about 120-130 deg C and fully compatable with the hideous lead-free solder used these days.....
Damned site cheaper too!TELEFIX
PLEASE DO NOT EMAIL ME PRIVATELY FOR REPAIR ADVICE. QUESTIONS BELONG ON THE FORUM!Comment
ChipQuik supposedly melts at 58 degrees C. I haven't confirmed this but it stayed molten for 13 seconds after it melted.Comment
Great Job, I have a LG 60 smart tv that I need the chip for, where did you get your replacement chip?Comment
I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
Well, my decice specs are the following:
Model: Acer Nitro 5 AN517-54-55T5
CPU: Intel Core i5-11400H
GPU: NVIDIA GeForce GTX 1650
Motherboard: GH51G LA-L181P Rev:1c
The symptom:
When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...05-26-2025, 10:49 AM -
by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM -
Before I go further down the rabbit hole, I'd like to know if I have created a dead-end in my repair process. I am attempting to reflash my Lenovo X1 Extreme Gen 2's BIOS chip after a power interruption corrupted the BIOS data during an update.
I do not have backups of the data I pulled off the chip using a CH341A 24 25 Series EEPROM https://www.amazon.com/Organizer-Soc...Q%3D%3D&sr=8-5
I also wrote to the... -
by the_remHello guys,
I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow... -
by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... - Loading...
