proscan pled3216a upside down picture (mainboard replaced)
  • Shinju
    • Mar 2014
    • 1239
    Just like the title states, installed the new mainboard old one wasn't working and now that when I turn it on the pictures upside down I don't see any orientation settings in the menu so what could happen?
    Re: proscan pled3216a upside down picture (mainboard replaced)
    If you look up the LCD panel model number to get the spec sheet, it may show one pin for the display orientation.
    Does this new board have the same PCB assembly as printed on the barcode or on the sticker?
    You may want to go to Shopjimmy to see which board is compatible with your chassis.
    • R_J
      • 9530
      There could also be a setting in the service menu for this, I know others have it.
      Try this Menu+1147
      • Shinju
        • Mar 2014
        • 1239
        Mainboard was purchased from SJ, the panel number and board number match. Funny part the original board had a different number.
        I tried to do a factory reset but I don't have the remote I think it requires a physical enter key not able to do so with the side buttons.
        • Shinju
          • Mar 2014
          • 1239
          If anyone has any information to get into the service menu that would be great I tried looking up at Tom manuals and I couldn't find anything for this.
          • Shinju
            • Mar 2014
            • 1239
            The old MB numbers all match except the T315XVN01.1.
            Panel number: T315XW06 V.3
            SJ replacement MB: T315XW06 V.3
              Hmm, did you contact shopjimmy to see what they would suggest?
              • Shinju
                • Mar 2014
                • 1239
                They were closed when it came in. I will call them in the am and see.
                This is strange , factory reset does nothing, seems like something in a service menu that might be able to change this but I cannot find any thing. Being that RCA makes proscan maybe the RCA service menu button access works on this unit.
                • Shinju
                  • Mar 2014
                  • 1239
                  I will upload some photos, there is a AUO LVDS adaptor board.
                  • Shinju
                    • Mar 2014
                    • 1239
                    Mainboard
                    • Shinju
                      • Mar 2014
                      • 1239
                      Everything.
                        I look at the spec sheet of your panel, there is no control pin for the picture orientation setting.
                        • Shinju
                          • Mar 2014
                          • 1239
                          So it's all software then, wonder if there is a way to access the SM and change it.
                          I have never run into anything like this before.
                          Thank you budm for taking the time to research that.
                          • Shinju
                            • Mar 2014
                            • 1239
                            Boo, they are closed on Saturdays!
                            Oh well, if anyone knows how to access a Proscan service menu please chime in!
                            Seems this mainboard is used in several lower end brands, Westinghouse, RCA, Seiki, and a few others.
                            • Shinju
                              • Mar 2014
                              • 1239
                              Just got off the phone with SJ and they have no clue so they sent me a complimentary return refund instead of charging me shipping and a 20% restocking fee.
                              Guess this one is going to the recycler, I cannot find my version of the mainboard at all.
                              Mainboard Originally installed in the unit.
                              L12100204
                              T315XVN01.1
                              Panel Number:
                              T315XW06 V.3
                              For other users that might run into this for future reference.
                              Bummer, first panel that I will be scrapping that doesn't have a busted screen.
                              • R_J
                                • 9530
                                Did you try Menu+1147 ?
                                • Shinju
                                  • Mar 2014
                                  • 1239
                                  Is that the button combo to get into the service menu? I take it this is imputed when the panel is on?
                                  • R_J
                                    • 9530
                                    Thats what I understand from another forum, press ( menu - 1 -1- 4 -7) thats the only one I found.
                                    • Shinju
                                      • Mar 2014
                                      • 1239
                                      I was able to get in. But I don't see any setting for screen orientation. I did see an option for LVDS odd or even the panel set to ODD if I put it to even then the screen goes blank back light stays on.
                                      I see some options for mirror mode, debugging and advance debugging but when turned on I don't see any extra screens I'm not sure how to access that stuff.
                                      • Th3_uN1Qu3
                                        Believe in
                                        • Jul 2010
                                        • 6031
                                        • Romania
                                        Stupid suggestion, i know, but do you have any reason why you can't just mount the LCD upside down? It might take a bit of mechanical work to have it all fit correctly, but should be doable.
                                        A working TV? How boring!
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • stylishconsultant
                                          un60j620dafxza - Samsung No Display Problem
                                          by stylishconsultant
                                          Hi All,
                                          Need help.
                                          I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                          So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                          problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                          might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                          09-04-2024, 03:26 AM
                                        • garrymc123
                                          Luxor TV board input board change but picture upside down
                                          by garrymc123
                                          Looking for some advice changed over the video input board due to bad hdmi ports but now the picture is upside down tried the service menu but can't find anything to do with flip the picture..
                                          Is there anything I can do to flip the picture or do I need to change the board again..
                                          Garry...
                                          08-29-2022, 04:53 AM
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
