samsung LN-S4051D diagnal lines
    • 12235
    • U.S.
    #101
    Re: samsung LN-S4051D diagnal lines
    been checking these ics, the readings seem funny, ic101 from top=1.79v left=2.8mv right=3.34v. ic102 top=2.7mv left=13.3v right=7.9v. ic1702 top=starts at 22 mv keeps going up, left=3.7mv right=5.09v, middle=2.5v, which I thought the middle should equal the top, seems like one or all of these are messed up, thinking this might be causing my snowy picture, any ideas?, thanks.
      • 12235
      • U.S.
      #102
      well this one crapped out again, getting the clicking of the relay every 5 seconds, fixed it once with electro caps replacement and reflow of solder joints, lasted a few months now its back same thing, clicks every 5 seconds. When powerboard is unhooked from mainboard clicking stops but backlights don't come on, when heating area of ics801 for a minute or two tv comes on for 15 minutes or so no clicking, replaced or checked all caps and resistors in that area, anyone know if heating ics801 is making it work for that 15 minutes or should heating it have no effect on the ic as in letting the tv work for that 15 minutes??: sj pic of powerboard: https://www.shopjimmy.com/samsung-bn...ight-inverter/
        • 12235
        • U.S.
        #103
        seem to have a strange reading on bridge rectifier, when tv backlight is on the dc voltage on the outer 2 pins are 106 volts, where I think it should be around 160, all diodes of bridge rec. read correct and inner 2 legs are 120 ac as expected, any thoughts on why the voltage is low?
        • lotas
          • Jan 2016
          • 4710
          • Russia
          #104
          PFC (Power Factor Correction) does not work.
            • 12235
            • U.S.
            #105
            Thanks Lotas.
              • 12235
              • U.S.
              #106
              think i found a bad mosfet, QI802, read funny, took it out, getting 192 ohms from drain to source, isn't that way too low?
              • lotas
                • Jan 2016
                • 4710
                • Russia
                #107
                Discharge its mosfet (short all three legs with a metal object) and check again with a multimeter.
                  • 12235
                  • U.S.
                  #108
                  ok, shorted all 3 legs, it's 197 ohms drain to source.
                    • 12235
                    • U.S.
                    #109
                    I think I messed something up earlier, I was trying to test voltages on that mosfet with tv on, had a probe on neg. of bridge rec. and when I touched drain or source it was one of them, then the backlights went out, now they won't come back on even after heating that small section like before, but the damn thing did quit clicking every 5 seconds.
                    • lotas
                      • Jan 2016
                      • 4710
                      • Russia
                      #110
                      Well, if the mosfet has broken, you need to check all nearby components for breaks and short circuits (resistors, diodes, zener diodes ...). After that, you can install a new mosfet.
                        • 12235
                        • U.S.
                        #111
                        Think I'm on the wrong path, just tested a couple more on a different powerboard, from a different brand and size tv, one was 176 ohms, the other was 90 ohms.
                        • lotas
                          • Jan 2016
                          • 4710
                          • Russia
                          #112
                          The mosfet should not have low resistance between the drain and the source (if a diode and a zener diode are built into them), then a multimeter will show a working mosfet as you check a regular diode.
                            • 12235
                            • U.S.
                            #113
                            ok, I ran some leads out from the main filter cap, there's 171 in standby and 381 when powered on, no backlight and the relay clicking is back, clicks 2 times every 5 seconds.
                              • 12235
                              • U.S.
                              #114
                              no progress going in reverse lol, tried testing voltages with tv on, there's no backlight now, voltages at cnm 801 conector are right on and solid, had 381 0n main cap, was testing voltages on ics801, neg. of main cap for ground, when i touched pin 5 or 6 tv would go off and come back on, could tell by the samsung chime, pin 7 had 14.35, I think thats just a bit low, then was checking icp801 and while checking one of the pins tv went off. checked to see if main cap was still 381 but was only 165 in both stby and powered on, the led on optical out blinks once then is out, led on front behaves like it should solid red for stby and off when powered on.
                                • 12235
                                • U.S.
                                #115
                                clicking 2 times every 5 seconds is gone again, think I either blew something while testing those ic voltages, which doesnt seem like it should have or maybe one of them is bad, maybe a resistor or a bad solder, not sure.
                                  • 12235
                                  • U.S.
                                  #116
                                  I think maybe icp801 is bad, it is the pfc controller: https://cdn.badcaps-static.com/pdfs/...43ef79150d.pdf
                                    • 12235
                                    • U.S.
                                    #117
                                    found 2 tiny resistors on underside of powerboard 75r0 and 82r0 close to cni804 connector both read 39.5 ohms, think those could be causing these problems?
                                    • lotas
                                      • Jan 2016
                                      • 4710
                                      • Russia
                                      #118
                                      If these two resistors (75Om and 82Om) are connected in parallel, then you get just 39.2Om.
                                        • 12235
                                        • U.S.
                                        #119
                                        ok, thanks Lotas, I'm glad those little buggers are alright.
                                          • 12235
                                          • U.S.
                                          #120
                                          seem to have a short somewhere that I can't find, dim bulb tester stays lit.
                                            09-07-2024, 05:50 AM
                                          • Falki
                                            Colorful LCD Vertical Lines on Samsung ue55es8090
                                            by Falki
                                            Hello there, ive recently found an older 55inch Samsung SmartTV.
                                            A similar issue has been posted as well but also with no actual response ...
                                            08-12-2025, 04:19 AM
                                            LCD LED TV Service Menu Codes
                                            ALL LCD LED TV SERVICE MENU CODES
                                            Service Menu Code with Board Name
                                            China Universal Board / Jumper Board Service Menu Code
                                            Changhong Ruba Service Menu Code
                                            Ecostar LED TV Service Menu Code
                                            Orient LED TV Service Menu Code
                                            Haier LED TV Service Menu Code
                                            TCL LED TV Service Menu Code
                                            Samsung LED TV Service Menu Code
                                            LG LED TV Service Menu Code
                                            Videocon LED TV Service Menu Code
                                            Supra LED TV Service Menu Code
                                            Toshiba LED TV Service Menu Code
                                            Symphony LED TV Service Menu Code
                                            Veste/ LED TV Service Menu Code...
                                            10-31-2024, 03:58 AM
                                          • Rubenlily
                                            Samsung QE50Q67TAU - horizontal lines
                                            by Rubenlily
                                            First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                                            I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                                            I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                                            I'm no expert but I've done the tape...
                                            08-16-2023, 01:12 PM
                                          • jeyoung12
                                            Samsung QN50Q60t lines on screen
                                            by jeyoung12
                                            Hi all
                                            I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                                            My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                                            This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                                            It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                                            So....i don't know what end of the C ribbon to work with...
                                            02-26-2024, 10:38 AM
