Hitachi P50V701 blowing capacitors
  • c_hegge
    • Sep 2009
    • 5219
    Re: Hitachi P50V701 blowing capacitors
    The board markings are not damaged there. I can tell from that picture that both caps are installed in the correct polarity. It seems that there is a fault with the power supply which is over volting the cap. It does seem odd, though that the other cap doesn't blow up, since it appears to be in parallel with the one that does.
    • R_J
      • 9588
      Those look like c552 & c553 they are connected in parallel and are for the +90 volt supply. How much voltage do you measure on CN64 pin 8,9 or10 to ground? That should be the vs voltage, you said you measured 86 volts which is close enough and not over voltage.
      You may want to check d550, d551 and d552 make sure one of them is not shorted suppling ac to the caps. but I dought that. What value cap are you installing?
      There is a lot of protection on these supplies to protect with over voltage etc.
      (vr380) VS1 is the adjustment for VS voltage
      • KevinCro
        • May 2014
        • 104
        First off, thanks so much for everyone's help so far. The caps are 100v 3300uf. I checked the components that you mentioned and none were shorted. I bought the caps off of amazon.com. I read the reviews of people that had purchased them before. One person said that they installed the cap and it blew 4 minutes later. I would be inclined to think that I just got some bad capacitors, but this is the second one that has blown in the same spot. Both caps were from the same seller though. It just seems odd that only the one cap is blowing. I think I might just put the board in and see if the next one blows too. I guess that's really the only option left. I checked the x and y boards and nothing seemed out of place. I would think that if either of those boards had a problem, then the tv would show symptoms when it powers up, but the screen is clear with no lines, sparkles or any other distortion. What do you guys think? I'm nervous because that cap popped like a rifle.
        • Agent24
          I see dead caps
          • Oct 2007
          • 5036
          • New Zealand
          The sleeve length on the capacitors don't match up, which seems unusual for a good quality capacitor company like NCC, they should have better quality-control.
          Maybe they are fake...
          -David VanHorn
          • Shinju
            • Mar 2014
            • 1239
            Or don't bother puttng in that other possible crappy cap and just get a quality cap and try.
            • KevinCro
              • May 2014
              • 104
              Where is the best place to buy caps?
              • Shinju
                • Mar 2014
                • 1239
                Digikey or mouser.
                • KevinCro
                  • May 2014
                  • 104
                  okay thanks
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    sounds like crappy caps to me too. that cap along with the other one that's original are wired in parallel which means that if one goes the other one could be bad too. With that blown cap out of circuit and the good one still in circuit measure across the two leads and make sure you don't have a 0 ohm short before installing a new one. Although I'm pretty sure your power supply is OK.
                    but if I were you in your going to order well known good capacitors from a well known website. I would order both that are in that circuit even though the good one hasn't blown doesn't mean that its not causing a problem or it has been severely strained by blowing the other cap
                    • KevinCro
                      • May 2014
                      • 104
                      The two capacitors are the same in that circuit. I bought 4 of them from mouser. I will update this once I install them and see what happens.
                      • ibgm
                        • Oct 2013
                        • 63
                        • usa
                        #31
                        I worked on a power supply one time and noticed when I removed the caps that the polarity marking on the circuit board was wrong! I always use a sharpy to mark the negative when I remove them. I've only seen that one time. Try and find a good picture of the board somewhere and see if you can confirm the polarity. Try E-Bay or any of the other sellers, I'm sure you can find a decent detailed picture somewhere. Good luck and keep us posted. I'm sure that must have sounded like a cannon when that went off! I would be on the other end of a 50 foot extension cord with this one!
                        oops! sorry I missed the earlier post where the polarity mount down was confirmed. If I could delete this I would.
                        • freakaftr8
                          • Oct 2012
                          • 3743
                          50 foot extension cord. ..I love it. Think we have all been there once!
                          • KevinCro
                            • May 2014
                            • 104
                            caps are installed and the tv is working. It's been on for 25 minutes and no bangs. Lesson to be learned? Do not buy cheap parts!!!
                            • KevinCro
                              • May 2014
                              • 104
                              Tv has now been on over an hour so I feel confident in saying that it's fixed. Thanks guys for all the help.
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                Good to hear!
                                • Shinju
                                  • Mar 2014
                                  • 1239
                                  Heck yes! I am glad you got her up and running!
                                  I wish I knew why my VA/VS voltages are almost double of what they should be.
                                  How is the picture on yours? Notice any maldischarge sparkling?
                                  • Shinju
                                    • Mar 2014
                                    • 1239
                                    Also don't forget to retake and adjust your voltages VA/VS with a solid white screen with dynamic setting and 100 contrast after 20min of use.
                                    • dragon3x
                                      After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                      by dragon3x
                                      Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                      power on.
                                      Here are some examples :
                                      (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                      switching supply area).
                                      (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                      than 6.3 V.)
                                      1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                      I replaced capacitors with aluminum-polymer.
                                      3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                      03-21-2025, 02:46 PM
                                    • slybunda
                                      AA and AAA battery charger capacitors?
                                      by slybunda
                                      hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                                      it has inside:
                                      2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                                      2 x 470uf 16v LZ105c branded as G.Luxon
                                      not heard of these brands are they any good?
                                      iv attached photos of the charger and the board inside for an idea on the type of...
                                      12-24-2023, 04:41 AM
                                      by sam_sam_sam
                                      After all of...
                                      07-13-2024, 08:14 PM
                                    • Cama
                                      Solar Inverter - SMH-II - 2 missing capacitors
                                      by Cama
                                      I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
                                      My model is : EASUN SMH-II 7 KW
                                      Mother Board : P/N 18947-002401250250
                                      Maybe the EASUN SMH-II 4.2 KW have the same capacitors
                                      Thank you...
                                      09-12-2025, 02:50 AM
                                    • Jaime Morillo
                                      Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                      by Jaime Morillo
                                      Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                      The TV was stuck on the logo and I couldn't access the update menu.
                                      I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                      The image result was good, but the image is inverted.
                                      The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                      Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                      08-18-2025, 11:38 AM
