T-con proplem
  • rkm
    • Sep 2014
    • 17
    • ICELAND
    Re: T-con proplem
    Ok I got a nother T-con from aliexpress seller "He decided to send me another one." And the status is diffrent now with new T-con. I have good picture for 10 minutes after I turn it on, cold. After this 10 min "tv warm" The picture start to bleed with some red. I have tried to clean the cable to t-con bud with out success. Is possible that it is somthing else ? something on main board or powerboard ? I dont see any bulp caps by the way.
    • rkm
      • Sep 2014
      • 17
      • ICELAND
      Re: T-con proplem
      here are some picture after the tv have warmt up
      • rkm
        • Sep 2014
        • 17
        • ICELAND
        Re: T-con proplem
        Anyone ?
        • CAIIIA
          • Mar 2012
          • 14
          • Russia
          Re: T-con proplem
          http://monitor.net.ru/forum/viewtopic.php?t=375748 There are a lot of useful information for your problem. Please read it.
          • rkm
            • Sep 2014
            • 17
            • ICELAND
            Re: T-con proplem
            Ok thanks. We are on the right way. I maid a cirkle around 2 parts which had a bad solder now are picture ok bud sound are somtimes missing. When I turn tv on and after 2-3 hours the sound are in and out
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              #26
              Re: T-con proplem
              Eee Gads, VESTEL crap gets as far as Iceland.....!
              Looks like a 17MB26 or summit like that. Utter junk.
              Send that T-Con back and get another with the correct part-number, pref. from a UK seller--at least it'll be original.
              TELEFIX
              • rkm
                • Sep 2014
                • 17
                • ICELAND
                #27
                Re: T-con proplem
                T-con is working fine at least not a proplem at the moment and if you read all the post there was maid changes to T-con.
                • advant
                  by advant
                  02-03-2020, 12:25 AM
                • Stanley1843
                  by Stanley1843
                  06-29-2024, 11:54 AM
                • Daren87
                  Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                  by Daren87
                  I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                  08-13-2023, 03:25 PM
                • x_orange90_x
                  TCL 50S535 bad tcon or panel issue?
                  by x_orange90_x
                  Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                  03-29-2025, 11:02 PM
                • alltvrepairs
                  Lg TCon test pins for screen test
                  by alltvrepairs
                  i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                  Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                  Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                  Appreciate your help....
                  06-13-2025, 06:33 AM
