T-con proplem
  • rkm
    • Sep 2014
    • 17
    • ICELAND
    Re: T-con proplem
    Ok I got a nother T-con from aliexpress seller "He decided to send me another one." And the status is diffrent now with new T-con. I have good picture for 10 minutes after I turn it on, cold. After this 10 min "tv warm" The picture start to bleed with some red. I have tried to clean the cable to t-con bud with out success. Is possible that it is somthing else ? something on main board or powerboard ? I dont see any bulp caps by the way.
    • rkm
      • Sep 2014
      • 17
      • ICELAND
      Re: T-con proplem
      here are some picture after the tv have warmt up
      • rkm
        • Sep 2014
        • 17
        • ICELAND
        Re: T-con proplem
        Anyone ?
        • CAIIIA
          • Mar 2012
          • 14
          • Russia
          Re: T-con proplem
          http://monitor.net.ru/forum/viewtopic.php?t=375748 There are a lot of useful information for your problem. Please read it.
          • rkm
            • Sep 2014
            • 17
            • ICELAND
            Re: T-con proplem
            Ok thanks. We are on the right way. I maid a cirkle around 2 parts which had a bad solder now are picture ok bud sound are somtimes missing. When I turn tv on and after 2-3 hours the sound are in and out
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              #26
              Re: T-con proplem
              Eee Gads, VESTEL crap gets as far as Iceland.....!
              Looks like a 17MB26 or summit like that. Utter junk.
              Send that T-Con back and get another with the correct part-number, pref. from a UK seller--at least it'll be original.
              TELEFIX
              • rkm
                • Sep 2014
                • 17
                • ICELAND
                #27
                Re: T-con proplem
                T-con is working fine at least not a proplem at the moment and if you read all the post there was maid changes to T-con.
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
                • advant
                  by advant
                  02-03-2020, 12:25 AM
                • Stanley1843
                  by Stanley1843
                  06-29-2024, 11:54 AM
                • Daren87
                  Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                  by Daren87
                  I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                  08-13-2023, 03:25 PM
                • x_orange90_x
                  TCL 50S535 bad tcon or panel issue?
                  by x_orange90_x
                  Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                  03-29-2025, 11:02 PM
