Coby TFTV3225 - Standby light, no power
  • Lobo
    • May 2010
    • 59
    There's a similar model with similar problems (big surprise) https://www.badcaps.net/forum/showth...=Coby+TFTV3227
    This Crappy, I mean Coby that I'm looking at now is just as laughable and also failed to power up after "warming" up. It's the TFTV3225. A 32" steaming pile of feces.
    I chuckled too when I saw a ground wire attached with a piece of foil tape. lol
    The power supply has no visibly bad caps, but I'm sure there are some. When I plug it in, the standby light comes on but the TV fails to power on. Put your ear to back panel and you can hear the familiar whining of failing PCB components.
    Upon further inspection and troubleshooting, I found it much more cost effective to just buy a new 32" TV. They're so cheap now.
    In the future, stay away from Coby products. That's assuming they are still in business. I'm not even gonna waste my time googlin' that.
    Or maybe I'm wrong. Maybe someone has spent their valuable time narrowing this problem down to a $.60 fix. Post it here if you have.
  • AleMonti
    LG 55EG910V - no power and no standby light
    by AleMonti
    I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
    I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
    The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
    After checking the basics I did the following:
    • I measured all voltages and as expected the only active supply is the 3.5V standby. It
    11-04-2024, 05:02 PM
  • SkishyIshy
    Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
    by SkishyIshy
    Hey All,
    I have a Sony 65x900f that I purchased cheap because of a no-power issue.
    I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
    I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
    03-17-2021, 11:44 AM
  • noinimod
    Sony 55X900E no standby light, no power. Replaced mainboard already
    by noinimod
    No standby red light, nothing
    This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
    Disconnected JK3 power board from main board, checked voltages on all the pin outs
    At a few pins I can see the power supply providing 19.5V to the main board
    Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
    LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
    12-22-2021, 12:58 AM
  • lapfix
    HP OMEN NO power no light
    by lapfix
    HP OMEN : DAG35DMBAD0
    NO power ,no short ,no corrusion
    Consumption : when charger plg in = 0.004 amp
    Only 3/5 vl are present when charger connected..when i put my red probe at the coils of 3/5volts and power on with my power suplly it try to rise than 0v.
    when try to power on using power button i note this starnge value : 3v then 0.300v then 3v !
    No light at power button led
    All coils resistances :
    Pl 2001 =3v measured with kohm.
    pl 2004 = 5v measured with kohm
    pl 6001 = 49.7ohm
    pl 4012 = vccsa = 24.4 ohm
    pl 3001 =...
    11-03-2025, 07:48 AM
  • x_orange90_x
    Vizio E550i-A0 no power, no standby light
    by x_orange90_x
    I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
    11-20-2023, 09:49 AM
