power flickerd today and now the set doesn't power.The red led isn't lighting and no relay clicking when i plug it in.I don't see any visual issues on the psu(B159-201). The set did this once before and after a few hours passed with power cord unplugged it worked again. I've read threw the forum and seen mention of the TCZAA6755U IC ref (U203) going bad. Anyone willing to walk a newbie threw some testing to attempt repair. Thanks in advance.
panasonic tc-p42x5
Re: panasonic tc-p42x5
Why not just get the IC and give it a go. Sounds like the symptoms, nil power after outage. Can't talk from experience though,power flickerd today and now the set doesn't power.The red led isn't lighting and no relay clicking when i plug it in.I don't see any visual issues on the psu(B159-201). The set did this once before and after a few hours passed with power cord unplugged it worked again. I've read threw the forum and seen mention of the TCZAA6755U IC ref (U203) going bad. Anyone willing to walk a newbie threw some testing to attempt repair. Thanks in advance. -
check anything labeled F on your power supply board, F for fuse, with a digital multimeter, be careful working with powersupplys, HIGH VOLTAGE. a pic. with more detail would be good, my camera only has 5mp, I can't get a decent pic., must need 8 or more mp for good clear pics., I guess.Comment
check fuses in diode mode, should read 000 or close to it, ol or no change of reading is probably bad fuse.Last edited by nomoresonys; 12-17-2014, 04:12 AM.Comment
I'll post better pics of the board in a bit. Charging camera.
@nomoresonys...i only seen the one big white fuse and it meters fine. I'll double check for another fuse.
@tw2005 trying to rule out any other issues. All of the links i've found for the replacement part are locatedin the uk. Any thoughts on where i can get my hands on it state side.Comment
check digikey maybe.I'll post better pics of the board in a bit. Charging camera.
maybe grab a manual, tom66 has his manual link stuck on his posts, and see if all your voltages at the connectors on your power supply are correct, some might require using the ac setting and some should be dc setting, maybe someone here has worked with this same model.Comment
No programming necessary. Try reading the part # off the IC directly with a magnifying scope. Should be fairly cheap from digikey/eBay...Last edited by tom66; 12-17-2014, 03:35 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Shouldn't matter. Probably a lead free termination style, not important for someone hand soldering.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Pretty crook when a part is no longer available on a 2012 TV but dug this up. They have it listed with it's real number.
FAN6755UWM which would make it FAN6755UW , you should be able to get it from here.
http://panasonic.encompass.com/item/.../FAN6755UWM/IcComment
tom66 i had my eye on these earlier today. Do you think they will work ?
http://www.ebay.com/itm/171364799349...%3AMEBIDX%3AITComment
by WizenGreetings All
I have Panasonic CF-D1NW200TZ,
SN: 8GTSA90529
The BIOS (MX25L12873F) is password-protected. I want to remove the password. I created a backup using NeoProgrammer and removed the password. Then, I restored the unlocked BIOS file using CH341A, removed the protection, performed a full wipe, completed the process with a blank check, and then wrote and verified it. Everything seemed fine, but now the tablet won't start. Only the power and Wi-Fi LEDs are lit, nothing else. The fan isn't spinning, and nothing else happens.
tried to write back...-
Channel: BIOS Requests ONLY!
Today, 02:33 AM -
by BigPeteI picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
Unfortunately the whole machine has to come apart to fix it.
I have... -
Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
...1 Photo11-20-2024, 08:52 PM -
by AquaMan UaHello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...2 Photos
by stecosHi everyone!
For my passion for technology I'm now collecting several... - Loading...
