Panasonic TH-P50U30A SC Board TNPA5351 AF failure
  • jeffecor
    • Sep 2014
    • 78
    • kent
    Re: Panasonic TH-P50U30A SC Board TNPA5351 AF failure
    I have a Fluke 115 and it was set on ohm m. I pulled all mosfets Q403,Q402, Q423,Q422 and the two diodes D401 and D421 tonight. I'm going to check the resistors. Tw2005 I was asking what was the finished ohm reading when the board was fixed. I know 2.784mohm means there is not a short that and the reading was after replaced the mosfets.
    • tw2005
      • Oct 2011
      • 6458
      you did not write Mohm, hence my question. sounds about right, 3meg sticks in my mind
      • jeffecor
        • Sep 2014
        • 78
        • kent
        Sorry I didn't post it right. Just trying to fix the board and seen you and tom66 know a lot about these's board TNPA5351 as where its my first SC board like this setup.
        • tw2005
          • Oct 2011
          • 6458
          I can only go with the info i read so I was unsure but sounds like it might be on track. I've done 1 of these boards and was very relieved and happy with just 4 igbts to get it going. I got more experience with thw 2010 5081 and they're never that easy.
          hard to give 100% green light but if you've probed every smd igbt and diode and nothing else is shorted and those resistors are fine it might be worth the gamble.
          Fet drivers are the only other things to watch for, not sure how to tell with these as they use different devices than in the past ( 8 pin I believe)
          and those tiny 5 pinn smd transistors usually near those drivers (3Y)
          • ricosavy
            • Jul 2012
            • 457
            • united states
            Jeffcore did you get your board fixed?
            • jeffecor
              • Sep 2014
              • 78
              • kent
              #26
              Yes, same issues that are in the repair kit on jimmy. It was a one of the hardest to remove the mosfets and diodes but its working once again and hopeful sold too fixed the gounding pads too. I changed the voltage going to the boards to 213v and let the tv run for a week. I found a good board reads in the 5 ohms on the high voltage plug.
              • tw2005
                • Oct 2011
                • 6458
                what do you mean? 5 ohms across SC2?
                • jeffecor
                  • Sep 2014
                  • 78
                  • kent
                  #28
                  I don't know if it the 216v wires that plug into the SC board have a name, but put the mutlimeter in ohms and neg - to gound and + to the pins of the board one read should close to zero and one should get a ohm read around 5 is what I found.
                  • jeffecor
                    • Sep 2014
                    • 78
                    • kent
                    #29
                    https://www.youtube.com/watch?v=GFE14ElXz7g
                    samething I'm doing in the video
                    • Alastair E
                      Chief Womble
                      • Mar 2013
                      • 1963
                      • U.K.
                      #30
                      Err 5 ohm--Board has faults!
                      5 Meg-Ohm, prob board is OK....
                      Damned auto-ranging meters are a pain sometimes, and if you aint used to 'em can mis-lead.....
                      TELEFIX
                      • tw2005
                        • Oct 2011
                        • 6458
                        approx 2800hrs and 1000 cycles since repaired, will be 2 years, in december
                        • howardc64
                          by howardc64
                          07-24-2025, 05:17 PM
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                        • m1ch43lzm
                          by m1ch43lzm
                          05-12-2025, 08:37 PM
                          After all of...
                          07-13-2024, 08:14 PM
                        • canadaboy25
                          Panasonic TC-P54VT25 No image. A or D board?
                          by canadaboy25
                          I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                          I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                          01-17-2021, 01:06 AM
