Samsung LN32C540F2DXZA: Won't turn on, PS and Inverter OK
  • beedoola
    • Dec 2012
    • 35
    I have a 32'' Samsung. The power supply voltages test fine and when I connect the PS board to the Backlight inverted and plug give it all power, the backlight comes on.
    When I hook up the main board back up with the PS and Inverter, I get nothing.
    Blinking red light on the front panel.
    Is the Main board just toast, or is there anything I can do to troubleshoot it?
  • beedoola
    • Dec 2012
    • 35
    Re: Samsung LN32C540F2DXZA: Won't turn on, PS and Inverter OK
    anyone?
      You can do some real good visual inspection and check some voltage readings on the voltage regulator IC and that's about it.
      Did you try heating and cooling of the main board yet?
      • beedoola
        • Dec 2012
        • 35
        Heating it how?
        Notice how the large heatseek is titled slightly? I'm wondering if that chip heated up too much.
        I have a heat gun.
        • beedoola
          • Dec 2012
          • 35
          Can someone tell me the Pinout of this connector on the main board?
          When the power board is connected, something from the main board shorts all power - measure the voltage on the PS board and I get nothing (with the MBoard connected), unplug the main board and the voltage on the PS board reads 24v, as it should.
          I need to know the Pinout for the main board so I can see if I can track down the short.
            The pin out is just right of it.
            Please upload photos to this site or to IMGUR as I cannot view full image on photobucket.
            • beedoola
              • Dec 2012
              • 35
              Yes, I see the legend on the PCB, but there aren't any numbers near the pins to say which is Pin 1, etc.
              I'm not sure if they go: 1, 2
              3, 4
              or
              1
              2
              3
              4
              etc.
                "When the power board is connected, something from the main board shorts all power - measure the voltage on the PS board and I get nothing (with the MBoard connected), unplug the main board and the voltage on the PS board reads 24v, as it should." That is because the main board is forcing the PS_ON to go low and not allow the power supply to turn on.
                I use hair dryer to heat up the board.
                • beedoola
                  • Dec 2012
                  • 35
                  Should I heat up the board by itself or plugged in to the PS board?
                  Do I heat up the whole board or sections?
                    boards are all connected, no power to the TV then use hair dryer (heat gun will be to hot and may melt the plastic) to heat up the whole main board for 2~3 minutes then apply the power to see if it will come on.
                    • steves7839
                      • Nov 2014
                      • 200
                      The legend follows the pinout. You can confirm this by checking the connector socket. Pin 1 is usually marked with a triangle or circle molded into the connector, and with silkscreen on the component side of the board.
                        See the picture attached.
                        • beedoola
                          • Dec 2012
                          • 35
                          I heated up the board and that did not get it to power.
                          Pin 2 - Switch Power and Pin 16 - SW Inverter both are shorted to ground when the PS is hooked up.
                          When measuring the Main board without the PS connected, or anything else, those pins to do read as shorted to ground.
                          • myfastgti
                            • Aug 2014
                            • 32
                            I had Samsung with similar problem and it turned out to be SDRAM was defective.
                            First heat the SDRAM with heatsink (Big red circle)chip for 30sec and see if the TV turns on if not check the 4 pin mosfet besides the RAM, sometimes it short.
                              Do the resistance show as <1 Ohm? No Tv is not plugged in, right?
                              • beedoola
                                • Dec 2012
                                • 35
                                Tried that and nothing happened, no shorts, as far as I can tell.
                                plugged in, Pin 2 is 54R, Pin 16 is 25R
                                unplugged they drop in resistance, after powering pin 2 is around 10M and drops, Pin 16 was less and drops over time.
                                  unplugged they drop in resistance, after powering pin 2 is around 10M and drops, Pin 16 was less and drops over time."
                                  When you do the resistance testing, DO NOT have power applied to the unit, you can also damage the meter if the unit has power.
                                  • Ltank
                                    • Jun 2013
                                    • 776
                                    Sometimes when Main Board Silkscreen does not show pinout. Simply go to P.S. connection to main board. P.S. is labeled and trace it to the main board wire by wire. A royal pain but you can see what is supposed to be on that pin
                                    • beedoola
                                      • Dec 2012
                                      • 35
                                      4 Pin Mosfet or the 8 Pin IC you have circled?
                                      I tested the pins on that IC and I can't tell if they're supposed to be but pins 5 and 6 are connected. I can't tell on the PCB if they're supposed to be.
                                      pin 7 and 8 are also connected (i.e. show continuity test on my DMM) but I can clearly see they share trace.
                                      • myfastgti
                                        • Aug 2014
                                        • 32
                                        Yes its a 8 pin dual n-channel mosfet from Alpha and omega number AO4800BL or AO4801. There should be 12 v or 11.8 v at pins 5,6,7 and 8 when the power button is pressed. If not check if you have any voltage at pin 2 and 4.
                                        Usually these fet's don't fail but so far I've only seen one failure
                                        • Asraf Atb
                                          by Asraf Atb
                                          01-27-2025, 05:02 PM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • Lee M.
                                          Samsung UN75RU8000FXZA bad main board?
                                          by Lee M.
                                          When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
                                          11-08-2023, 07:46 PM
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
