Vizio sv470xvt1a won't come out of standby
  • freakaftr8
    • Oct 2012
    • 3743
    picked up this TV last week for free in the previous owner stated he went to bed and then in the morning it wouldn't turn on anymore. Being relatively familiar and vizios and fixed a few in the past I first started checking voltage regulators on the mainboard they all seem to be within spec. Oddly if I jump 5 volt standby to PS-ON I get all the voltage is coming off the power supply including 12 and 24 volts to the inverters but the inverters will not power up since the main board is still in standby. Is this an EEPROM issue? I noticed somebody else on the forums has a 42 inch version having the same problem.
    Btw yes I tested all fuses as well
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Vizio sv470xvt1a won't come out of standby
    I ordered an eeprom. I feel that this is it. Anyone else have a clue?
      I was looking at SHOPJIMMY last night to see if they have EEPROM for this model but it is not listed.
      • freakaftr8
        • Oct 2012
        • 3743
        okay I couldn't happen to notice that all the voltage regulators between pin 1 and 2 are receiving 1.243 volts
        Is this a little shy of 1.25 Volts?
        Yes the eeprom replacement didn't work.
          The spec is +/-3% so you are OK.
          • freakaftr8
            • Oct 2012
            • 3743
            I have a voltage regulator in question u21 Pin 1 is 0v pin 2 is 1.24v pin 3 is 2.5v. is that correct?
            this is an adjustable 1117 regulator
            • freakaftr8
              • Oct 2012
              • 3743
              nevermind I read up in another post if somebody fixing the same exact model TV that his regulators were running the same voltage and it appears that there okay.
              I'm thinking probably a bad processor or a faulty BGA connection as I am NOT getting any PS on or back light on signal from the main board although I can jump right things and get back to work in the power supply rails to come up.
              • fharris1977
                Vizio D50u-D1 Dead Set No Standby
                by fharris1977
                Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                12-28-2023, 10:25 AM
              • p-top
                Vizio, E60u-D3, no standby light, no ps_on
                by p-top
                Have vizio E60u-D3. No standby light. Have searched and read all D??u-D3 posts. posts with same symtoms fixed by new power supply, one guy needed back lights also.
                main boards are kinda spendy and, out of stock alot of places. i would like to fix my board.
                PS voltages
                1 VSNS -2mV
                2-5 LED-OUT -2mV
                6-10 GND -2mV
                11 +16VS 16.29V
                12 AC-DET 3.929V
                13PS-ON -3mV
                14 +16VS 16.29V
                15 +16VS 16.29V...
                11-27-2023, 10:44 AM
              • x_orange90_x
                Vizio E550i-A0 no power, no standby light
                by x_orange90_x
                I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
                11-20-2023, 09:49 AM
              • shelby5041
                vizio d40f-j09 no pic no sound standby always clear
                by shelby5041
                hi
                anybody have experience with this model tv
                07-19-2025, 06:58 AM
              • tvguy12012012120
                by tvguy12012012120
                02-07-2025, 05:13 PM
