General safety question for working on TVs
  • tucocaps
    • Apr 2013
    • 331
    • United Stated
    I know this is discussed in all sorts of TV repair guides, but I'm still a bit confused on the electrocution risks when working on plasmas and lcds. I've forgotten to unplug, and seen some arcs and sparks because of that. I think I've also seen what appears to be some capacitor discharge. So far, I have not even felt a shock, despite messing up a few times.
    How great is the risk of getting a dangerous jolt from a set, and what do you do to consistently protect yourself from that when working on TV's? Can even touching the top of a capacitor with your body cause a discharge? Thanks for any advice on this.
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: General safety question for working on TVs
    The top of the capacitor can is tied to the negative side of it, so yes, it is part of the circuit and potentially can discharge depending on it's use in the circuit and the condition of the circuit. Now bear in mind that you are working on a piece of electronic gear, there is something wrong with it to begin with so there is quite possibly electrical potential where it is not supposed to be, so you take precautions against the unknown and follow the standard safety guidelines.
    Wear non conductive shoes (rubber or plastic soles) and when working near high voltage put one hand behind your back and take measurements with the other. The idea being that if you DO contact a live spot the current will not pass across or near your heart.
    The most reported injuries suffered from high voltage shocks when working on electronics are lacerations on your arm or hand from it involuntarily spasming and hitting something sharp, like the chassis, case or something in the work area.
      You should at least plug what you are working on into the GFCI outlets.
      • tucocaps
        • Apr 2013
        • 331
        • United Stated
        I do have a GFCI because it's in my garage. The circuit sometimes blows anyway, because it's a newer house and they tie the exterior outlets to the interior gfci's. I have been too lazy to caulk my outlet on the back porch, so it's probably got some water in there again. Have replaced it , and not sure if I did a 20 amp or 15 amp outlet , or if that makes a big difference for safety risks.
        I usually wear sneakers, crocs , or sometimes plastic bottom slippers with the fur inside. I never thought about footwear when working on a TV
        • SteveNielsen
          Retired Tech
          • Jun 2012
          • 2327
          Garage translates into concrete floor. Concrete is conductive. I'd throw down a rubber mat or at least some carpet remnants in front of your workbench to stand on.
            A conductive floor can be a lifesaver as it is lower impedance than going across your chest vs going down your leg. Which would trip the GFCI.
            You just need to be careful. That is all.
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              I use a home-made Isolation Transformer.....
              Two 600VA 55V Toroidal Transformers connected back to back isolates from the mains but won't prevent electricution--by stupidity!
              Always Unplug the set when removing leads, boards or anything else--Only have attached to mains supply when taking measurements/setting voltages--Only takes a second to pull the plug--About the same amount of time--it takes you to die if you dont and do summit daft!.
              TELEFIX
              • MMH3
                Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
                by MMH3
                i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
                Never ever i experienced problems with that.
                Now i have one 5050sff machine, where this jumper isnt working at all.
                I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
                The history of the machine is that i used it in my office...
                03-23-2025, 09:28 PM
              • DynaxSC
                GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                by DynaxSC
                I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                The board is generally working now, all PCIe ports are working, Windows installs normally.
                However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                03-10-2025, 12:27 PM
              • obelix24
                Macbook Air 2020 (a2179) - touch id not working
                by obelix24
                Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
                I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
                02-09-2025, 12:57 PM
              • hopkok
                Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
                by hopkok
                Hi masters, I need your help.
                I am working on Lenovo Legion 16ITHg6
                Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
                INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
                My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
                AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
                Power LED is not working as well, power button working well.
                UI26 ??? is there any firmware too? Powered by +3VALW_AG.
                Motherboard...
                05-04-2025, 09:35 AM
              • bociub
                laptop freezes, usb 2.0 not working, usb 3.0 working
                by bociub
                Hi there,
                It is sunday and I got a faulty hp pavilion 15-cs1006na. No available schematics on the entire world. It flashed 5 long 4 short and no post then I discovered the usb 2.0 2. pin in one of the usb-a socket bent backwards and been shorted to 2. and 3. pin of the 3.0. after removing this short in the port the laptop came alive.
                Now the laptop freezing randomly. The webcam, the built in mic and according to the device manager one more thing not working which are connected to usb. If I connect anything what have usb 2.0 plug that wont work if i plug anything what...
                08-25-2024, 03:44 PM
