test y buffer for short? part# ebr38447802
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    was wondering if anyone could provide me with an easy way to test this y buffer for short
    i have attached a photo
    i do have a DVM
    thank you
  • shelby5041
    • Feb 2009
    • 1505
    Re: test y buffer for short? part# ebr38447802
    i did some research and saw some mentioning of the round copper pads and using diode test but that was for a diff part#,,,so not sure what do do here..any help would be appreciated
    • tw2005
      • Oct 2011
      • 6458
      Ok, unusual to start a new thread? but try setting the meter to diode/continuity, place one on the Vfg points where the screws would go and then slide the other probe slowly across the pin contacts for the panel ribbons and see if it shows short or constant beep.
      • shelby5041
        • Feb 2009
        • 1505
        ok doing that test upper buffer is shorted on one of the cable connectors...even the one i bought from shop jimmy and all are shorted on same connector location
        • tw2005
          • Oct 2011
          • 6458
          What do you mean on the same cable connector location? any chance a photo of how you did the test or of the bad connector?
          • shelby5041
            • Feb 2009
            • 1505
            i touched floating ground pad where screw goes then ran other probe alone each cable connector and on the last connector it had shorts....the connector where panel ribbon cable goes....there are 4 connectors.......this kind of backs up my tezy i did 4yrs ago the uppers were bad using a diff test ...coppell tv .....but the upper i got from shop jimmy is now appears to be shorted
            • shelby5041
              • Feb 2009
              • 1505
              if upper is shorted and lower not.....wouldny i get a pic on bottom screen and if upper is shortrd why isnt top half screen black?
              • mmartell
                • Oct 2013
                • 3189
                On some sets the signal cascades from top buffer to bottom. So short on upper means no pic because signal is not making it to the bottom buffer. And if top buffer not installed but good bottom buffer installed still no pic for same reason.
                • shelby5041
                  • Feb 2009
                  • 1505
                  can anyone very how to tedt short on y buffer....i tried srtting to diode...then one prob on floating ground pad and other probe running across all pins on each ribbon cable connector and i keep getting readings on the top connectors which means shorted?....or am i doing something wrong?
                  • finntricky
                    • Jan 2014
                    • 449
                    https://www.youtube.com/watch?v=51SZ...Y&noredirect=1
                    try that
                    • shelby5041
                      • Feb 2009
                      • 1505
                      yes i tried that and i also get readings which means shorted.......i put probe on any 1 of the input voltage pins and then other probe ran across each of the 4 ribbon cable connector pins and i do get readings.........
                      i jsut want to verify if this works on all y buffers and not jut certain ones
                      i bought it on ebay and need to verify board is shorted for a refund
                      thanks
                      • shelby5041
                        • Feb 2009
                        • 1505
                        i also used diode mode and probed 5v pin and then other probe on ground pin and i get a reading which means shorted correct???
                        • sordids999
                          • May 2013
                          • 2161
                          have you watched toms video?
                          you will here a beep once you run your multi meter along the pins which will highlight that you have a shorted buffer
                          • shelby5041
                            • Feb 2009
                            • 1505
                            beep/reading same thing
                            yes i have done this and i get a reading/beep when i run along pins on connector s for ribbon calbes '
                            one probe on ground and one probe on connector pins.........and i get readings on various pins so this means shorted????
                              Yes that would be a shorted buffer board
                              • shelby5041
                                • Feb 2009
                                • 1505
                                thanks
                                ok thats what i thought...bought it on ebay just got it and tested it shorted
                                have to ask for refund....seems the upper boards are more prone to short on this tv..is that an accurate statement
                                can i also test for short on buffer board by just probing 5v pin and probing gnd on same incoming power connector and if it beeps....board is shorted?
                                  A lot of newer plasmas will damage the buffer board when the screen gets cracked... sellers stick them on eBay without testing them
                                  No, you need to check to the output pins to be sure
                                  • shelby5041
                                    • Feb 2009
                                    • 1505
                                    by out put pins you are referring to the numerous pins on the 4 ribbon cable connectoirs?...if so what do i use for ground?...the gnd pin on the incoming power connector or the floating ground pads where the screw mount the board?
                                    i used the floating ground pads....and gnd on incominmg pwr connector and came up shorted also
                                    i did that.....
                                      I use the floating ground pins to the output pins, yes those are the ones connecting to the ribbon connector.
                                      • shelby5041
                                        • Feb 2009
                                        • 1505
                                        and lots of sellers put z and y boards on ebay that are defective and they dont know that........its frustrating trying to troubleshoot tvs when boards you buy to try to fix...dont work.....
                                        • G-Sting
                                          iPad Pro A1876 SHORT Part Identify Help Needed
                                          by G-Sting
                                          So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                                          So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                                          i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                                          SO My main concern is what part should i order what should i search the name for ?
                                          on Ipad...
                                          05-15-2025, 09:30 AM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • vbogoev
                                          Lenovo S6000 won't turn on. Data recovery needed.
                                          by vbogoev
                                          Here I have the mentioned tablet with motherboard s6000-mb-h401. The tablet won't turn on, no display, charging normally. I manage to connect to UART port and got this output when I try to start it:
                                          Code:
                                          [PWRAP] pwrap_init_preloader
                                          [PWRAP] pwrap_init
                                          [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=0 rdata=5AA5
                                          [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=1 rdata=5AA5
                                          [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=2 rdata=5AA5
                                          [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=3 rdata=5AA5
                                          [PMIC_WRAP]wrap_init pass,the return
                                          06-20-2023, 06:36 AM
                                        • Stephen
                                          MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                                          by Stephen
                                          I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                                          02-06-2025, 12:03 PM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
