LN46C630K1FXZA BN94-02701G main board replacement question
  • allenrw
    • Jul 2013
    • 19
    Hi all again,
    I have been struggling with a main board (P/N BN94-02701G) in a Samsung LN46C630K1FXZA (no version #)TV for a while.
    The problem was easy to locate but difficult to fix as one of the larger ball grid array mounted video chips had developed intermittent joints. I tried reflowing it three times which worked for brief periods of time the first two attempts.
    My repair attempts are in another thread, just search for my user name: allenrw
    So now I am in search of a replacement main board, P/N BN94-02701G, which is relatively hard to find and there is the concern that this defect will exist in a replacement of the same number.
    I am finding that certain resellers like shopjimmy are listing substitutes
    So the questions are:
    Is this substitute list valid?
    Are any of these boards upgrades that may have had the problems worked out?
    From Shop Jimmy
    Substitute Parts BN94-03446D
    BN94-02701K
    BN94-02701B
    BN94-02701C
    BN94-02701D
    BN94-02701E
    BN94-02701H
    BN94-02701J
    BN94-02701L
    BN94-02701M
    BN94-02701P
    BN94-02701R
    BN94-02701S
    BN94-02701T
    BN94-02701W
    BN94-02701X
    BN94-03446C
    BN94-03446E
    BN94-03446F
    BN94-03446G
    BN94-03446J
    BN94-03446K
    BN94-03446L
    BN94-03446M
    BN94-03446N
    BN94-03446P
    BN94-03446Q
    BN94-04045A
    BN94-04045B
    BN94-04045E
    BN94-04561A
    BN94-04562A
    BN94-04564A
    BN94-04567A
    BN94-04570A
    BN94-04571A
    BN94-04573A
    BN94-04610A
    BN96-19187A
    BN96-19188A
    BN96-19190A
    BN96-19191A
    BN96-19193A
    BN96-19194A
    BN96-19195A
    BN96-19196A
    BN96-19197A
    BN96-19198A
    BN96-19199A
    BN96-19200A
    BN96-19201A
    BN96-19210A
    Bob
  • truep
    • Aug 2010
    • 373
    Re: LN46C630K1FXZA BN94-02701G main board replacement question
    Shopjimmy is pretty reliable. If they listed it and it's not compatible they will take it back.
      Shopjimmy is really good about their services, you can also ask them if anything is needed to be done after installing the new board.
      • ygorsan
        by ygorsan
        🧩 Problem Summary:
        • I
        07-28-2025, 08:34 AM
      • jb_Bak
        by jb_Bak
        CN6401
        Pin 01 NC
        Pin 02 NC
        Pin 03 "BL_ON": 0V
        Pin 04 "N/C"
        Pin 05 "STBY 3.3V": 3.5V
        Pin 06 "GND": N/C
        Pin 07 "AC_OFF"...
        09-27-2021, 04:52 PM
      • tuner2000i
        Philips 65PUS8518/12 distorted image after main board replacement
        by tuner2000i
        hello everyone,
        I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
        The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
        07-15-2025, 01:15 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • JDC
        by JDC
        ONN 100012588
        Long answer:
        07-15-2022, 07:39 AM
