Toshiba 42HL196 - Clicking relay, Power Board
  • abdekader
    • Jul 2014
    • 73
    • Turkey
    #41
    Re: Toshiba 42HL196 - Clicking relay, Power Board
    change all capacitors after it's working , i repaired it
    if not working change PFC STR
    Electronic Engineer from Syria,Aleppo
    • MEB
      • Sep 2013
      • 371
      Hello, hey budm. I have been busy with this board and will update what I have done. Since we were having intermitttent activity involving the 5V always on portion of the power supply, I took a little magnifier and examined every component and solder joint. I resoldered everything that looked marginal, but nothing changed. I went ahead and replaced all the rest of the capacitors on the board, even the big ones with Rubycons and Panasonics. Still the same.
      This is the current state of the board. It is on the table, I have 2-100 ohm resistors in parallel for the 12V load. I have a 10 ohm, 7W resistor for the 5V load. I have removed the force-on resistors as I can not obtain a steady 5V1. At one time I did have 5.091 steady at 5V1, but never since the soldering and capacitor change. The 5V1 standby voltage fluctuates from 0 - 4 volts or so which was causing the 5V relay to click on and off. I have removed R8310 to keep the relay from clicking.
      It seems as though the board is trying to achieve 5V but continuously cycles. This continues for a period of minutes until it eventually stays at 0V. Removing AC for 10 minutes or so is required before the cycling resumes as if maybe heat related? I am currently looking at page 4 of the schematic and trying to understand Q840 and T840 as to what role they might have in this problem but do not have enough circuit knowledge. I have begun writing down some measurements when 0V and cycling V and will try to organize those to assist. Thanks in advance.
      • MEB
        • Sep 2013
        • 371
        Looking at page 4 of the schematic, which is where I am currently snooping around, there is a Q840 (STR-A6169) which I believe is involved to allow T840(TPW3565AS) to provide 5V. Yes, I am grasping at straws, but I don't know what else to do. Below are some voltage measuremnts at these 2 devices, which I am hoping will provide some insight to someone.
        When I have the cycling 5V (0-4) up and down, I read:
        Q840
        Pin 2 (Vcc) fluctuating 10-16V
        Pin 7,8 fluctuating 157-358 V
        T840
        Pin 2 fluctuating 157-358V
        After I lose 5V, I read:
        Q840
        Pin 7,8 stable 157.3V
        T840
        Pin 2 stable 157.5V
        From Q840 data sheet, Vcc Turns on/off around the fluctuating 10-16 volt limits I receive so maybe if this was steady, I might not get the cycling 5V? I wish I understood more, but I could use some direction. Please comment if you will.
        • CapLeaker
          Leaking Member
          • 8326
          Just some stupid brain fart I got. By any chance you wouldn't have the power supply plugged into a light bulb in series as for protection in case of a short? What would happen is that when you turn on the power supply, the light bulb would light up and then the power supply shuts down and the process starts again.
          I wonder if the two 100 Ohm resistors in parallel are still hocked up?
            https://www.badcaps.net/forum/showpo...7&postcount=23
            I look at the diagram again and see that 5V is rated at only 250mA not 1/2A as I thought so 10 Ohms loading is too much, it should be able to handle 20 Ohms load.
            • MEB
              • Sep 2013
              • 371
              Nope, no lightbulb and yes 100 ohms still hooked up. Thanks for the thought.
              OK budm, thanks a million. Thought maybe you were tired of this old board. I will go get another 10 ohm resistor and report back in a little bit. I knew being too cheap to buy more than one would be a mistake.
              • CapLeaker
                Leaking Member
                • 8326
                remove those two 100 Ohm resistors and put a fuse in. I don't think you had blown fuses to start with?
                • MEB
                  • Sep 2013
                  • 371
                  Capleaker, I must have confused you. All fuses are in. The parralelled 100 ohm resistors are in there to make an equivalent 50 Ohm load for the 12V circuit. They are still in there for now.
                  budm - things have changed as shown after adding another 10 ohms to the 5V load.
                  Q840
                  Pin 2 (Vcc) stable 28.59V
                  Pin 7,8 stable 421V
                  T840
                  Pin 2 solid 424V
                  5V1 to ground is now 4.987V
                  She is staying on thus far.
                  • CapLeaker
                    Leaking Member
                    • 8326
                    Yep, got confused with those resistors location... I hope you get it to work though after all this work!
                    • MEB
                      • Sep 2013
                      • 371
                      Thank you.
                      • audiofreak19
                        • Apr 2013
                        • 556
                        • usa
                        #51
                        Yea these tv's are a pain in the ass to work on. I had one with same issue. To be able to still profit on the tv I ended up buying a power supply. Keep at it I wanna see how this turns out
                        • MEB
                          • Sep 2013
                          • 371
                          Thanks for the encouragement audiofreak19, I won't give up.
                          I got called back in to work so I didn't get to work with the board any more, but tomorrow I hope to have more information. I will solder R8310 back in, force on the board and see if that darn relay quits clicking. Thanks again budm.
                          • MEB
                            • Sep 2013
                            • 371
                            Couldn't stay away. Went to solder in that resistor and with magnifying glass in one hand, soldering iron in the other and dental pick in the 3rd, I shot that resistor off into space and can't find it. I know it is 22K SMD, but I don't have a clue what to order and know absolutely nothing about SMD. If someone reads this, would you please give me a part number from Mouser or Digi-Key? The schematic says CHIP, 1/20W 22K OHM J and I think it had 223 printed on it. Sorry, I'm an idiot.
                            • mmartell
                              • Oct 2013
                              • 3189
                              I know it's small but i believe you can use a standard 22k 1/8w resistor in its place if you have one.
                              • MEB
                                • Sep 2013
                                • 371
                                Thanks mmartell. I don't have any and I don't think I want to solder 22 1Ks together as that is as close as I can get. I will run out and find one but I still would like to get a replacement SMD. I will read up and see if I can figure what to get. So this will be a temporary delay in the progress, but I will be back. Thanks to all.
                                • CapLeaker
                                  Leaking Member
                                  • 8326
                                  Digikey part number: RHM22KCBCT-ND
                                  or this one : 541-22.0KAABCT-ND Vishay Dale CRCW020122K0FKED
                                  Do one of these look similar?
                                  • MEB
                                    • Sep 2013
                                    • 371
                                    Thanks for the info, but I already ordered 100 each of CRCW060322K0FKEA and ERJ-3EKF2202V for a whopping $1.80. I did some reading and think those match the original case size and have a pretty good probability that I can get 1 out of 200 on the board. Man they are little. I am off to the local parts house to see if I can find a through hole to stick in there so I don't have to wait for those to arrive. Thanks again and maybe I will have more to report later this evening.
                                    • MEB
                                      • Sep 2013
                                      • 371
                                      OK, closest I could find at this time to 22K is a 25K which measures about 24.5K. I hope that is close enough and I soldered it in. Firing up the board I still have 5V standby, but as soon as I force on, the relay starts it rhythmic clicking. Assuming it is not the value of the resistor I added, it seems the board is still up to its old tricks. But I do now have 5V standby which is one good thing. I shut it down for now and am going to think about what to do. Please share any thoughts. Thanks.
                                      • MEB
                                        • Sep 2013
                                        • 371
                                        Alright, I decided it best to repeat all the steps budm had me do before we ran into the 5V standby cutting out. Now I have 20 ohm load in the 5V circuit, 50 ohms load in the 12V circuit and the force on resistors in. Repeating everything in the previous posts, when I get to post 29 and pull the D826 while monitoring 5V1 to Gnd, the 5V is now stable at 4.978 VDC. So now that will make sense to him. I think he was having me do that to show that removing Vcc to that Q820 might mean that something in that PFC circuit was causing trouble. Wish I knew what that means, but I will start by trying to find a datasheet for that SRX2039. I'll be back.
                                        • MEB
                                          • Sep 2013
                                          • 371
                                          Wish everyone was here right now, but especially budm cause I'd be buying beer for everyone. God, I love this place. Seriously, my life has changed for the better finding you guys. I'm hooked. I really don't know shit, but hanging out here makes me feel like I do.
                                          Well anyway, I believe this board has been fixed. Yipee!! I started this by replacing the 3 ICs everyone suggested with this Toshiba and with bud steering, I finally suspected it must be Q820 which was one of the 3 I bought from ebay and replaced originally. Luckily I saved the original and ended up putting him back in tonight, and what the hell, it worked! Everything works, I have all voltages I should have and I am so fucking excited. Thanks to budm and all of you for providing the spark and audiofreak19 for keeping the fire going.
                                          I'll let you know how the rest of the TV turns out.
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                            by sam_sam_sam
                                            I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                            Found shorted diodes on main controller relays there are 3 of them that...
                                            01-07-2023, 05:43 PM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • slimmy182
                                            [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                            by slimmy182
                                            Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                            I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                            Looking on google I found this:...
                                            01-14-2023, 11:55 AM
