What might of caused these main caps to bulge so badly?
  • Dang
    • Aug 2013
    • 440
    As you can see from the photo they are much domed and as I result I believe this is why I have no VE, I've noticed by CN8002 that Diode D8044 has a resistance reading of about 3 ohms in both directions, I don't believe this to be normal as surely it should go off the scale one way and give a reading somewhere near 400 or so the other?
    Re: What might of caused these main caps to bulge so badly?
    Can you push the plastic dome down?
    • Dang
      • Aug 2013
      • 440
      Hi Tom66, yes, there's certainly air space there and I've looked on Ebay for a reference as to how they should look, all were flat as you would expect.
        Try cutting the disc or pulling it off and seeing if the actual capacitor is bulged underneath. It is sometimes common for the disc to bulge upwards as a result of heat build up in these TVs. Doesn't mean it's bad.
        • Dang
          • Aug 2013
          • 440
          Hi again, removed the domed plastic caps and indeed you are right, the cap heads are perfectly flat so I guess these are fine, which still leaves the question, why no VE? is that diode faulty?
          I should explain that when the Tv is first turned on 3 green LEDs on the PSU light up after both relays have clicked on, there is also a green light that comes on on the logic board, within about 5 seconds these relays click off with 2 of the 3 greens lights going out and the logic board light turning red, I believe this gives an error code but not sure what it is, this is to come next...
          • selldoor
            Slow Learner
            • 7870
            Make and model might help?
            • Dang
              • Aug 2013
              • 440
              It's a no brand plasma with Samsung parts, a Firstline FS4211HI, quite old I think, only paid a fiver for it so thought it worth a shot.
              Seems this is by Hisense which I believe is a name started by Ebuyer.
                Loss of Ve would not cause no image. It would cause pink/maldischarged/grey image. Is that what you see?
                Some of these power boards have Ve pin, but it's not electrically connected.
                Could also be shorted Ve on X-main.
                • Dang
                  • Aug 2013
                  • 440
                  OK, I've tried tracing VE from the connector back to it's roots, as far as I can tell it disappears under the two main caps described above, where it goes from there I don't know. I don't see any picture but a momentary select flash of sparkles when it decides to turn off, I can see other flashes from time to time but it doesn't last long, just a few seconds.
                  I have disconnected all the obvious boards, one at a time, so the X-sus, the Y-sus and also the Z-sus, I've even had both the Y-sus and X-sus off at the same time, the power supply acted the same way with LED8001/LED8002 (LED8003 always stays on) extinguishing and LED8004 turning on red so I don't think any of these boards are at fault.
                  Can I go back to this diode, can I assume by a lack of response to this idea that all is perfectly normal?
                    The diode might be bad. May be worth removing it from circuit and testing it out of the board.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5037
                      • New Zealand
                      I see that diode looks a bit browned... could just be dirt on it though.
                      -David VanHorn
                      • Dang
                        • Aug 2013
                        • 440
                        Hi again, OK, so after some research it seems the VE area of the board(pictured) is at fault, firstly the diode looks like it's blown short, the main capacitors are also suspect with one most definitely short across both it's terminals in either direction(C8071), it's the one right besides the aforementioned diode. Now all three of these I shall be replacing but not too sure what rating diode to use as a replacement and will two 250v, 150uf caps be OK to the replace the 250v, 100uf caps already present?
                        Thanks.
                        Just to add: It would seem a possibility that this shorted cap might be responsible for the two main caps bulging as it seems that VE originates from there, any ideas?
                          Again, the bulging of the disc is a normal thing for some capacitors to do - it does not mean the capacitor is bad.
                          Cannot say for sure if increasing the capacitance will upset the circuit, best to use the correct values.
                          Please verify if you get Ve fault symptoms (dim/pink image) or something else?
                          • Dang
                            • Aug 2013
                            • 440
                            Basically this is how it reacts, I took this information from a Polish website:
                            1) disconnect SSB; * in addition to which the tape drive. + 5V ssb goes for the control and returns to the power supply,
                            2) turn on the jumper J8003, J8004, BJ8902,
                            3) turn on the plasma should light 8001, 8002, BJ8902; * if you do not light the UPS entirely to exchange,
                            4) for a few sec drive should appear in August, given above,
                            5) then leds 8001, 8002 extinguish,
                            6) LED should blink.
                            1x - V_A OVP, UVP
                            2x- 12V OVP, UVP
                            3x - V_SCAN OVP, UVP
                            4x - D3V3 OVP, UVP
                            5x - V_S OVP, UVP
                            6x - V_G OVP, UVP
                            7x - V_SET OVP, UVP
                            8x - V_E OVP, UVP
                            9x - Over-temperature (> 105 ° C)
                            10x - PFC_OK UVP (> 330 V)
                            11x - 5V2 OVP or Active DC_PROT
                            13 x- D5VL OVP, UVP
                            A little sketchy I know, I haven't done the jumper thing but mine turns on as soon as the plug is attached, I don't see any [main] power switch.
                            The Tv never properly turns on or holds stable, it just cycles the same way every time it try's to. I've tested most if not all other voltages while it's starting and all seem to reach their stated values, so Vscan, VA, VS etc just no VE. As stated above there's a definite short in the VE area and the cap and diode seem to be the problem, I can't find any other problematic components so these will have to be my first port of call.
                            • Dang
                              • Aug 2013
                              • 440
                              So I've removed both caps and the diode, not really that surprised to see both caps measuring seemingly OK(DMM goes of the scale in diode mode), the diode on the other hand still measures bad, it's this one here: http://www.datasheetcatalog.com/data...BYV26EGP.shtml.
                              • Dang
                                • Aug 2013
                                • 440
                                I also have this one, are they interchangeable?
                                https://cdn.badcaps-static.com/pdfs/...d9225d077f.pdf
                                  If yours is RGP15M type yes.
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    I am just answering this in case you are tempted to try it before Tom gets back:
                                    Iwouldnt have thought so if you have the 15A version looks to be only 50v where the one you need looks to be 800-1000v peak reverse.
                                    EDIT
                                    Too little too late
                                    • Dang
                                      • Aug 2013
                                      • 440
                                      Thank you, yes, it's the RGP15M. OK, so here goes, be back soon and fingers crossed.
                                      • Dang
                                        • Aug 2013
                                        • 440
                                        Success, a simple change of the diode and all is working, for now, it's been about 20 minutes so early days but looks good, stable picture too.
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • ygorsan
                                          by ygorsan
                                          🧩 Problem Summary:
                                          • I
                                          07-28-2025, 08:34 AM
                                        • ktmmotocross
                                          Acer 515-54G badly burned Main power -After repair ACDET is pulled to GND when apply
                                          by ktmmotocross
                                          Acer 515-54G
                                          DA0ZAWMB8G0
                                          Board have badly burned Main power and second mosfet After repair ACDET is pulled to GND when apply power
                                          i dont uderstand this. Charger ic BQ24780S
                                          ACDET 6pin have voltage devider set to R1 110Kohm and R2 20Kohm. pin ACDET have 20K to GND. But when apply power R1 have 19V on one side and 2.3ohm on other side.
                                          What is pulling my ACDET down when i apply power even without BQ ic...
                                          12-02-2022, 12:03 PM
                                        • Asraf Atb
                                          by Asraf Atb
                                          01-27-2025, 05:02 PM
